Old 06-30-2012, 04:15 AM   #1
Moderator
crazycal's Avatar
Chassis: 3800
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Please post pictures of your front door lock setup.
Title pretty much says it all. I'm looking for ideas for locking my folding door. Thanks.
I'm hungry!
You Gotta Let Me Fly
Old 06-30-2012, 12:50 PM   #2
Collin Humble's Avatar
Coachwork: Carpenter Crown
Engine: Cummins 5.9L
Re: Please post pictures of your front door lock setup.
I am honestly still using a "temporary" solution... I have a 2x4 that I wedge between the first stair and the door to keep in locked. I enter and exit through the back door, and have a pad lock on that. It's ghetto - I fully realize this.
Collin Humble is offline   Reply With Quote
Old 07-04-2012, 09:05 AM   #3
kimberlink's Avatar
Engine: DT466 / AT545
Rated Cap: 71
I plan on welding my doors together utilizing the forward hinge and having it open like a RV door with a door latch and deadbolt. This is to keep the original look and be less expensive than buying a RV door that you have to modify the opening to fit the door.
The most terrifying words in the English language are: I'm from the government and I'm here to help.
Ronald Reagan
https://s1253.beta.photobucket.com/us...k1961/library/
kimberlink is offline   Reply With Quote
Old 07-04-2012, 09:58 AM   #4
opus's Avatar
Chassis: All-American R/E
I must be missing something, I use the factory door lock.
Old 07-04-2012, 11:17 PM   #5
My bus does not have a lock on the front from the factory, so I have to improvise.
Old 07-05-2012, 11:44 AM   #6
Moderator
crazycal's Avatar
Chassis: 3800
I have a factory lock on mine but was old it was broken. Maybe I should look at fixing it.
I'm hungry!
Old 07-05-2012, 11:51 AM   #7
opus's Avatar
We have factory locks on all the doors. I actually use nylon zip ties on the side doors. You can open and close them in an emergency easily but no one could get them loose from the outside. No need making things difficult.
Old 07-05-2012, 05:01 PM   #8
browncrown's Avatar
Rated Cap: 79 at Birth
My Crown has a ring welded under the front step. The door key that opens the side compartments also has a ring. There is a hole in the front step that the door key slides up into and it goes into the hallow channel on the door frame to keep it locked. This was the standard locking mechanism on all Crowns from the 50's until the end of production in the early 90's.
When I'm inside for the night, I have a wooden brace I place between the door and the first step to prevent the door from opening. The door also has a release mechanism from the inside which will allow the door to open outward in a emergency. I also have two rear exits I can use to get out quickly if needed.
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
browncrown is offline   Reply With Quote
Old 07-09-2012, 09:07 PM   #9
browncrown's Avatar
Originally Posted by richlindquist
For the life of me, I couldn't figure out what those holes in my lower step were for... until now!
Learn something everyday! ....and they also help keep the water drained from the step well when you give the Gillig a good bath
BC
Lock for front bi-folding door timbrass Conversion General Discussions 1 10-12-2014 07:46 PM
Electric door lock somewhereinusa Conversion General Discussions 6 10-27-2011 08:19 AM
this is how I lock my door on the bus lornaschinske Conversion General Discussions 5 12-26-2010 02:20 PM
How do I post pictures? himem777 Everything Else | General Skoolie Discussions 2 05-17-2006 09:20 AM
Rear door lock Kirbystud Conversion General Discussions 22 08-16-2005 03:47 AM
