10-07-2012, 09:11 PM
Coachwork: Crown by Carpenter
Chassis: Ford B-800
Engine: 5.9L Cummins
Rated Cap: 55
Battery monitoring?
I just got a 2000W inverter today and all it has on it is a fairly useless load meter that simply goes in 200W increments. Obviously with a laptop and a light, it'll never display anything.
I'm wanting something more sophisticated that tells me not just the current battery voltage, but also the current drawn, and a nice pretty visual meter that tells me the remaining capacity of the batteries. Something like this, perhaps:
http://www.clippermarineusa.com/product.php?id=44224
I'm curious what other people are using, assuming something like that isn't already integrated with their inverter. I need to know whether I'm in relative danger of losing power, or if I need to get back on-grid, recharge early on enough, or if I need to plan for installing more panels (currently I'm just trying out battery power with a car charger to replenish it), etc. It would ALSO be good to know what current each thing is actually pulling (by disconnecting everything but one thing), so I can expand my battery bank as needed.
The simultaneous display that this model has is ideal. I don't want to see only one number at a time, and have to click through different display modes to see other numbers. I also would prefer something digital and not just LED with 'full, half, empty'.
10-08-2012, 11:02 AM
Chassis: Ford B-800
Rated Cap: 55
Re: Battery monitoring?
Seems that traditionally (from my research) that people get separate devices to measure each thing. a voltmeter, ammeter, etc.... That may be more cost effective anyway. This Clipper BM-2 only goes up to a 600 amp-hour system, which mine is going to be a bit beyond, anyway.
10-09-2012, 10:02 AM
Rated Cap: 19
Glenn - Your math is good. Connecting two batteries in series doubles the voltage while connecting them in parallel doubles the amp-hours.
I've got a Trimetric battery monitor that does all that the BM-2 does and also lets me monitor my chassis batteries (voltage only), but you have to click through to see the display you want. The BM-2 does have a much nicer display.
The Trimetric unit required some programming too.
10-09-2012, 09:04 PM
Chassis: Ford B-800
Rated Cap: 55
I don't know how realistic it is, but it would be NICE if there was something that could beep an alarm when the batteries are drained past a certain point. I'd prefer two alarms, a warning at 60-75% and a more urgent alarm at 50% (or higher). I'd like to know before it's too late and we're in the middle of nowhere that we should head into town, etc to charge up, before it's too late. The alarms I've seen so far seem to not have much customization to it, ie and some go off at way too low a voltage.
The Clipper BM-2 is a nice display, but I will be having probably 1200 amps eventually, so that unit is not an option. And my inverter runs at 12V so I can't split the batteries into two sets.
I'm actually not concerned about amps as I am about watts. It'd be nice to know the load the inverter is drawing for everything. The inverter itself has a meter on it, but I'd like a digital one as well. And knowing the watts being used only really matters if I know how much longer the batteries will last (to 50%) at that load. Not just in percent, but also in minutes, hours, etc. That piece is critical.
I'd also want an analog voltage reading with the appropriate color coordinated ranges, ie 'charging' vs 'low' vs 'fully charged', etc... A voltage reading doesn't mean much unless it gives me an idea as to whether the level is good or bad, and to what extent.
I'm looking through a book "RV Electrical Systems" by Bill Moeller, which seems to be pretty thorough in monitoring options. Sometimes you need to know what EXACTLY to look for because search engines can often give really useless results.
10-09-2012, 09:16 PM
Chassis: Ford B-800
Rated Cap: 55
http://www.bogartengineering.com/pro...tric_trimetric
I'm looking at Bogart's PentaMetric models, and it seems like those are the ones with the alarms? I don't mind the programming as long as I can get information that means something useful, relatively quickly. If I have to press a few buttons, that's ok, as long as I get warned when things are bad (or almost bad), and as long as the number on the display means something useful, like present load in watts or estimated time before batteries need charging or amp-hour loss relative to the full charge.
I may supplement this type of thing with an analog voltmeter with the right color ranges.
It also sounds like the Pentametric specifically can turn on a generator when needed via a relay. Of course if I can't get my butt outside to flip a switch, then we've got problems.
How do the Trimetric and Pentametrics compare? Are there other manufacturers? Would they handle more than the 600 amp-hour capacity?
10-10-2012, 11:17 PM
Chassis: Ford B-800
Rated Cap: 55
I found these too:
http://www.xantrex.com/power-product...y-monitor.aspx
This honestly seems less COMPLICATED than the Bogarts. It doesn't have a built in audible alarm, but it does have a 1 amp relay that gets tripped when the batteries reach low (which itself is programmable what % that is). The relay can go to any sort of external 12V alarm that is < 1A, visible or audible. Or it can trigger a generator, apparently. The PRO version is also rated for 10,000 amps (the LITE is only 1,000 amps). Amazon has it for about $250. AND it has a bit more screen space for simultaneous display (battery level AND amps consumed).
07-19-2014, 07:29 PM
any updates from users here.....
looking at the same things.... i sure like the looks of bm-1, and the xantrex
not sure but maybe in my circumstance, a simple generator controller would work better than a read out that i have to manually monitor.........
xantrex makes a generator controller:
http://www.xantrex.com/power-product...tor-start.aspx
that senses voltage and runs the generator automatically. the monitor would be redundant.
anybody try these or feed back on any of the monitors?
thanks
07-19-2014, 09:04 PM
I note that the Xantrex requires being mated to a Xantrex inverter, and it has a 3-wire Onan generator control output. Remote start wiring for generators can be 2-wire or 3-wire.
Most old Onans are 3-wire. You hold the "start" wire to "common" to crank the starter until the engine is running and showing oil pressure, which kills the starter and allows continued running. You hold the "stop" wire to "common" to kill the spark until the engine finishes all its sputtering. If you let go of the switch too soon, the genny either doesn't start or doesn't stop. The remote panels for RV gennys are usually a spring-loaded center-off rocker switch for the 3-wire control.
Other generators with 2-wire control have a "common" and a "request to run." You must hold the "request to run" to "common" continuously for as long as you need AC. If you had one wired in an RV, the remote run request switch would just be a common "On" or "Off." Most stationary backup generators are 2-wire, getting a "request to run" from the emergency transfer switch when commercial power fails, and releasing it after a cool-down timer resets a short time after the utility power returns.
Any battery system monitor with a settable external alarm point should be able to be wired as a "request to run" generator controller. A 12-volt relay that can handle the signal current can be switched by the alarm output.
Home brewing 3-wire remote start from a 2-wire output takes more thought. I have used a double-throw relay that holds "start" forever during request to run events, and holds "stop" forever when the event ends and the interface relay releases. But if your interface relay is continuously enforcing the "stop" command, there is no way to run the generator from any parallel switch unless you also provide a way to disconnect the "stop" command from the relay. If I recall correctly, an old Onan will still crank, but shut down as soon as the oil pressure relay engages.
But you have to ask yourself, do you want to give the genny authority to suddenly fire up at 3 AM without warning while you are trying to sleep? It's a choice, and may be preferable to a damaged battery bank. I think I once saw documents on a purpose-built generator controller that had the ability to assign quiet hours, so the genny will wait until a better time to start.
Another option is low-voltage disconnects. These are built into most DC-AC inverters, so if the battery gets too low, they will shut down the AC output and stop drawing DC. External Low Voltage Disconnects can be ordered for other loads, too. You could have one or more LVDs dump unnecessary loads during the night, and attend to the genny when you get up.
The problem with LVD panels when boondocking is that they are generally designed old school, and have a big mother relay that is active and drawing current the whole time that DC loads are authorized to connect to the battery bank. Newer solid-state units may go a long way to reduce this "phantom power" load, but I cannot think of a specific model without doing some research.
Edit 1: Some combination of keystrokes made the reply post before I had finished proofreading it.
Edit 2: I forgot to add that any home brew generator controller that uses a battery voltage set point as a trigger will also need some kind of minimum run timer. Shortly after a charger comes on line, the battery will appear to have a healthy voltage at the monitor point.
