Old 11-10-2012, 02:46 AM   #1
Chassis: Blue Bird
Engine: DTA360 Spicer 6+1 Manual
Is there a Charger/inverter/distribution combo?
So I have been looking at charger/distribution panels and am wondering if there are any that also incorperate an inverter?
Just seems like it would be cost effective and very clean to install a true all in one unit.
Thanks In Advance
Tony
rex_1_mn is offline   Reply With Quote
Old 11-11-2012, 09:48 AM   #2
kimberlink's Avatar
Engine: DT466 / AT545
Rated Cap: 71
Re: Is there a Charger/inverter/distribution combo?
I have not seen one, however if you build it we may steal from your design....
The most terrifying words in the English language are: I'm from the government and I'm here to help.
Ronald Reagan
https://s1253.beta.photobucket.com/us...k1961/library/
kimberlink is offline   Reply With Quote
Old 11-11-2012, 10:30 AM   #3
lornaschinske's Avatar
Year: 1986
Rated Cap: 89
We are just adding in dedicated inverters as we need them. Makes it easier to replace when they crap out. I have one $20 750 watt inverter for my LP range electronics, vent for range, ALL my fluorescent lights (so we can use them with no shore power is available). I will probably add another one for the TV & DVD player (clean power... the batteries will filter the dirty generator/shore power or provide a couple hours of TV/movie watching when wanted). But that is just how we laid out our electrical system to suit our specific needs/wants. The big thing is to make sure you get a 3 stage smart charger.
I thought Trace made one for the solar people?
Fulltime since 2006
Old 11-11-2012, 05:06 PM   #4
There are several Iota 3 stage chargers that will supply 50amps of 12v to charge and use...might be an option.
Also if you have the $$ several marine setups can supply the needs
Old 11-11-2012, 08:22 PM   #5
this guys have all sorts of stuff you maybe looking for
http://www.bestconverter.com/
Old 12-09-2012, 12:44 PM   #6
Engine: Cummins 6BTA 5.9
My old Trace 2500 series inverter has a built-in 120 amp three stage charger and automatic transfer switch. A lot of other high-end inverters have a similar setup.
PossumLiving is offline   Reply With Quote
Old 12-09-2012, 01:05 PM   #7
the answer is yes.
i dont know the manufacturer, but one of our friends who shut their electricity off for good, bought a kit that had the entire panel in one unit.
of course, i am talking about solar instillation...
30 amp Portable Distribution Box chev49 Electrical, Charging and Solar 1 06-10-2012 01:02 PM
Simple distribution box Dain Alternative Fuels | Electric, Propane, Wood & Biofuels 1 06-10-2012 03:13 AM
Question about inverter/Charger with generator Ob1 Electrical, Charging and Solar 3 12-30-2010 10:24 PM
Inverter/charger/monitoring systems BUSBOZO Conversion General Discussions 1 02-26-2010 07:23 PM
an other Inverter/charger question swinada Conversion General Discussions 6 07-30-2007 02:16 PM
