Old 07-28-2008, 09:14 AM   #1
RV toilet floor flange
I need to get my grey/black tanks installed and setting the drains will need to be done first. I know that RV toilets are built differently then residential toilets and I plan to use an RV toilet, are the RV toilet floor flanges the same as a residential floor flange, pick one up at Lowe’s and good to go? 3” pipe (drop)? What's the number/measurement off of the back wall (to center of flange) for setting the floor flange? Thanks.
Abbott is offline   Reply With Quote
Old 07-28-2008, 10:28 AM   #2
Re: RV toilet floor flange
Great Jim, thx.
Old 07-28-2008, 09:20 PM   #3
That looks like a 3" flange from Lowe's or Home Depot.
Old 07-28-2008, 09:21 PM   #4
GoneCamping's Avatar
House style flange will work fine, that is what I used. I got one that swivels so I could be a little less precise. However, the RV toilet mounting holes are the same as the china bowl in your house, one on each side!
*Cliff*
You just might be a Redneck if...
...your motor home used to be a school bus!
...Your living room has a steering wheel!
...Your home has brake lights
1994 Jeep Grand Cherokee
1989 Thomas Diesel Pusher (Cat 3208/Freightliner)
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 07-29-2008, 08:43 PM   #5
There is no wax ring, but there is a soft seal that I HIGHLY recommend you use. My TT didn' t have one, and every time I flushed the toitey I'd get some leakage at the base of the unit. When I asked at the RV place about that, they told me about the soft seal and indicated that it should have been installed when the built the trailer.
If you go to the Thetford website and look at the drawings, you can see the soft seal included with the flange bolt kit, it is ITEM #5 ON THIS PAGE
The piece looks like THIS THING
*Cliff*
Old 07-30-2008, 09:47 PM   #6
Yeah, I looked them over. I copied and pasted the links in my browser and they came up fine.
COMPOSTING TOILET bansil Plumbing, Water and Waste 2 10-27-2012 11:07 AM
Any experience with this toilet? crazycal Plumbing, Water and Waste 7 05-30-2010 07:56 PM
Toilet special needs Seeria Plumbing, Water and Waste 5 11-05-2009 07:34 PM
Toilet GoneCamping Plumbing, Water and Waste 1 11-14-2008 06:38 PM
Toilet...which one and why? crazycal Everything Else | General Skoolie Discussions 5 07-10-2008 11:19 AM
