Old 05-18-2009, 10:57 PM   #1
tractor trailer/cargo carrier conversion?
I've been kicking an idea around in my head for a few months now, and thought I'd finally ask for some opinions here. Now I know, I know... asking for an opinion here is a risky proposition... since nobody here wants to share their opinions. lol
Anyway, crazy crazy idea time....
Has anyone thought about taking a 16' to 18' cargo carrier/tractor trailer trailer unit and converting it to be pintle hitch instead of 5th wheel and using it as the portable garage for carrying your vehicle/bike/tools/garden hoses/whatever? Technically, I think I could go up to a 20' length, and with a tongue length, not exceed the 65' limit.
I figure with a bus that is already configured with air brakes, adapting the bus to feed air to the trailer wouldn't be that involved. The same connectors that tractor trailers use would be just right for that purpose of course.
Also, these units tend to be extremely durable. No need to worry about your car getting tar from the road on it.
I imagine the conversion from a 5th wheel assembly to a pintle hitch assembly would be non-trivial. Removal of the 5th wheel ought not be that difficult, but adding a tongue without compromising the frame might be quite difficult.
I realize that this would likely reduce the cargo capacity of said trailer. However, if it were a unit with 2 positionable axles, you could do a good job of balancing the loads.
For someone with a front engine bus, it would probably be easier to just shorten the body of the bus and put a 5th wheel hitch back there. However, I have a rear engine bus, and I just don't think that'd work out.
Other thoughts I had were that the cargo unit would be shorter than the bus once the bus roof is raised, so perhaps the satellite mount could go on the cargo unit. For that matter, solar panels could go there too, and remove the worry of holes in my planned roof. The cargo unit could be parked in the sun with clear southern exposure while the rig remained in the shade.
Anyway, I know it is one of the crazier ideas I've heard. Just wondered what others think of the idea. Does it have enough merit for me to keep kicking the idea around, or is there some major gotcha that I've missed?
Thanks,
jim
baadpuppy is offline   Reply With Quote
Old 05-18-2009, 11:21 PM   #2
Year: 2012
Coachwork: Need bus-as-home over RV
Chassis: still looking
Re: tractor trailer/cargo carrier conversion?
If I understand what youre asking (i'm not sure) it should actually be fairly easy, have you ever seen the double pup trailers? They make a converter dolly that puts a pair of wheels and a fifth wheel under the trailer and has a pintle hitch off the front which attaches to the trailer in front of it. Theyre normally only used for lighter trailers (28ft is the most common with a single rear axle), i'm not sure what shorter trailers are made.
I was considering on doing something like this if I make my own conversion to haul extra stuff in a trailer behind the bus.
However the problem is the towing weight. Can your bus haul the 10-20k lbs of weight fine?
I'd still kick the idea around a bit. Let me know if you go ahead with anything, the notion of putting the solar on the trailer and say batteries and cabling your power over to the shade is interesting. I'm not planning on doing anything this fancy soon so I wont be researching it much beyond the detail I know above but maybe that can get you started, find out about those converter dollies and pup trailers. They actually shouldn't be all that expensive. A 28ft pup trailer is probably going to be alot cheaper than a 20ft or shorter one due to market abundance possibly to the tune of thousands. I haven't really seen 20ft semi trailers or you'd have to pay to shorten one.
nearhomeless is offline   Reply With Quote
Old 05-19-2009, 01:51 AM   #3
the real problem is the weighmasters etc,
they look at a commercial trailer and say that once it is a commercial trailer it's for commercial use.
I follow one of the class 8 truck conversion sites and this info comes from there, it appears that their have been some abuse by race teams and the profit/not for profit issues and that the winnings are income and therefore it is a for profit operation etc, anyhow the current ruling looks like if it looks commercial or it was commercial it is commercial
look closely at a semi trailer, they use the top and bottom rails and skin for the trailer frame, the suspension and axles are on a mini frame that is usually on a slide apparatus that allows the wheelbase to be changed, these trailers are relatively heavy and to cut into the floof and lower rails to onstall trailer axles would compromise the structure.
next look closely at a van box on a straight truck, they rely on the frame of the truck for strength and are lightweight construction, almost begging to be set down on a relatively light trailer frame and have wheel wells cut into the floor and bottom rails leaving an enclosed trailer that is close to the ground, user friendly and doesn't look like a commercial trailer.
it gets even more interesting when my mind starts to wander and i think about using a long trailer tongue and a pintle hitch way forward of the rear bumper up near the rear axle like the euro trucks use, it's got to help the trailer follow better and probably help to smooth out the ride because the trailer has less leverage on the back of the bus
thoughts and comments welcome please.
paul iossi is offline   Reply With Quote
Old 05-19-2009, 08:45 AM   #4
Ahh, that's exactly the kind of thing I was worried about. I definitely *don't* want to be dealing with upset DOT folks.
Yeah, I see a lot of them on my daily commute (an hour each way... *shudder*... but it helps pay for the bus work...), and I've noticed the myriad of designs. Some tractor trailer trailers appear to not be modular, but the modular ones are much stronger looking. And the adjustable axle position is appealing. The biggest thing to my mind is having the air brakes vs electric brakes. I hadn't thought about trying to lower it at all, but with the commercial appearance, that makes sense.
Now that's something I never thought of. That's probably the smartest way to do it. I've seen several old u-haul trucks that would be good for that, with a rollup rear door and everything. Now ya have me thinking!
Paul, I like the way you think. Dad and I have kicked around the idea of having the pintle hitch be beneath the bus body somehow, maintaing the radius such that the trailer couldn't possibly scrub the bus, but so that it would streamline the entire rig. The aerodynamics would have to be improved, no?
Hrm, a decent sized box truck, lowered frame, add air brakes or an air brake axle, pintle hitch underneath the bus, I could go a lot closer to 25' for the box. Maybe 22'. My bus is actually closer to 39' in length than 40', so there's a little wiggle room there.
I'd eventually like to have a decent 4x4 pickup truck (my gf insists on a chevy) and a couple of dirt bikes kept within the box. So assuming the truck isn't too long, that'd do it. And, I'd have more room for more tools, etc.
I definitely want to avoid those adapters. Some states consider that "double towing", which is illegal in some states.
My bus has a GVWR of 33,280. I haven't yet had it empty to go find the current unconverted empty weight, but will be doing that in the not distant future. I also plan to weigh it empty again once the roof raise is complete, and probably at several points during the conversion. This way I will make sure to stay under my weight budget. Granted, the weight budget is pretty high. I know the bus is a bit too light at the front at the moment as I had a few episodes of porpoising when I drove it home from GA. Of course, the bus had no seats or kids, so that might've contributed... lol
Unfortunately, very few bus manufactures included a GCVWR rating back in the day. So, I figure if I stay under 10K behind the bus, with appropriate braking ability, things should be ok. I'm not too worried about getting things moving, but I'm definitely paranoid about making sure things can be stopped.
Around here there are containers in all sorts of sizes all over the place. Whether any of them are available at a reasonable price or not is another question.
thanks for the thoughts guys,
jim
Old 05-19-2009, 09:53 AM   #5
again, I think that a comercial container like an overseas shiping container is going to look commercial and attract attention from the law, but if you want to pursue that route, it can't be to mdifficult to cut the end off of a box, remove a section and then reinstall the endcap either front or rear. just make sure to overlap the skins so that they shed wind and water and don't act like scoops, and funnel the elements into the box.
with some forethought an interchangeable hitch system could be made using reciever hitch type tubes and the trailer could be used as a euro style, regular tag or even a goosneck style trailer, and be used pulled with something other than a dedicated tow vehicle.
imho, a properly setup set electric brake system is as good as or better than air brakes in this relatively light application, easy to install, goofproof to hookup and moisture is not an issue in cold weather, and again air brakes scream commercial trailer and might require a cdl with air brake endorsement.
lots of the rent/lease box trucks are repurposed as vocational trucks with different bodies in their rebirth, good used boxes are available at reasonable prices, look at the truck and truck body dealers for used units.
old mobile homes are a good source for trailer frame material, their axles and brakes are rated for 6,000 pounds each
Old 05-21-2009, 09:00 AM   #6
Paul, thanks for the ideas and pointers.
I've been digging around some of those class 8 conversion sites. My pockets are way too shallow to play in their pool.
One important fact I got from there though was that an empty 20 cargo container will weigh about 5400 pounds. That's seriously more weight than I had in mind.
However, I also see from those sites that there are people doing this type of work. Seems their goal is to live within theirs and mine was to haul extra cargo and a vehicle, but the exterior issues are the same.
So, I'm nixing this idea. Also, looking at the availability of truck boxes around here, I don't think I can go that route either.
Another thing I got from the class 8 conversion sites is tips on building from scratch. Things that make you go "hmmm...".
So now I'm thinking my best bet is to keep an eye out for a strong flatbed pintle hitch high capacity trailer for a decent price. Then, I can build my own box on top of it and have things be the way I want from the beginning. With the trailer being already titled, etc, this might just work out great for me.
Frankly, the trailer walls/ceiling don't need to be cargo-container strong. Nor does the unit need to be insulated all that well. So I'm thinking I can knock something out fairly easily once I have a good solid foundation to build on.
Thanks again for all the feedback. I'm glad I asked for opinions here before committing any money to that plan.
jim
Old 05-21-2009, 10:44 AM   #7
my opinion ,for what its worth
is find a 20 or 24' truck box with a good roof skin, should be less than $1500, then find a salvage mobile home frame, if you shop hard enough you can find one that is only 102'' to the outside of the tires, moving the axles and shortening the frame to fit the box is going to be a lot less work and money than building from scratch.
shop the mobile home parks and dealers to find out who is scraping out old trailers, the scrap guy is the place to buy a frame from, you might need to work a deal to have him carefully remove the floor or remove it yourself so that the frame doesn't get twisted like a pretzel, remove all but the front axle, cut the rear of the frame off past your needed length and tow it home, to fit it to the box and move the axles where you want them.
for comparison purposes, my 24' flatdeck gooseneck tandem axle trailer eighs 5400# empty, it,s rated capacity is 14000#.
you should be able to put a frame under an aluminum box and stay at or under 5000#
a 20 or 30 ton trailer, dual wheels tandem axles is going to weigh close to 10000# empty, the beams in the frame are lots thicker and have wider flanges.
Old 05-21-2009, 07:50 PM   #8
Year: 2012
Could someone share some of those "class 8 conversion site" links? I'm curious about this.
Paul, could you expand a bit on the bit with DOT? I dont have any OTR experience so I don't know what gets flagged and what doesnt. I've wanted to eventually use a pup type trailer (shorter big rig trailer) hauled behind a medium duty 5th wheel for personal use only (no commercial hauling for others) but from that description it sounds like I may have a problem registering/insuring or at least being hassled for doing so by nosy DOT inspectors.
To baadpuppy, I do know you'd need air brakes to use any kind of air braked trailer as the origin, there wont be a way to convert one to electric brakes. And you wont be adding air brakes to a truck that didn't have them to start with - thats more cost and work than it's worth. :P Also the pintle hitch adaptors, I cant see how any state would consider that double towing, that's total news to me?? A bus towing a trailer should only be a normal single tow even with adapters. Btw keeping the weight under 10,000 with a big rig based trailer isn't going to be easy - the 40ft trailers alone probably weigh that, a shorter one is less but you probably wont be putting a 6000lb 4x4 in there on top of it. However if you went with a standard box trailer of whatever type (7x16 or 8x24 for instance) such as the car carriers made for hauling behind a 1 ton pickup you would have electric brakes, a designed 10,000lb approximate weight, a non-commercial appearance, etc. It seems like the effort to use a semi trailer instead of an 8x20 car hauler will cost more and require lots of work in the long run.
I'm confused by the talk of changeable wheelbases and modular trailers though, I don't think i've seen that at all. Unless people are meaning the ISO shipping container haulers which can adjust to haul either 20ft or 40ft containers, which is different than a semi trailer strictly speaking.
Old 05-21-2009, 09:50 PM   #9
I just searched google for "class 8 conversion". I didn't bookmark the sites.
Seriously, if I had the right kind of pockets, a class 8 conversion would be sweeeeeeeet...
On the other hand, I have a bus that falls slap dab into the class 8 classification, as the GVWR is greater than 33,000 pounds.
http://en.wikipedia.org/wiki/Truck_classification
My old pickup truck I just sold had an electric brake controller with a hydraulic line hooked directly into the brake lines. It didn't use any kind of inertial system at all. It was a wonderful brake controller. I really appreciated the true proportional braking.
The inertial brake controllers I've used on other vehicles annoyed me with the inconsistency of responsiveness to braking. Adjusting was also a bit of a pita.
Since my bus has air brakes, I'm willing to bet there's an electric brake adapter somewhere that'll hook right up to the air lines and do true proportional braking... however, I believe the big rigs with air brakes all around have true proportional braking without the extra conversion step. Additionally, a trailer setup with air brakes has a built-in breakaway braking system that doesn't need constant recharging and checking like a battery does. The primary reason I wanted a trailer with air brakes was because I figured it would be at least as good as the setup on the old pickup truck.
I only need my trailer to hold 1 4x4 pickup truck, 2 offroad dirt bikes, some gasoline, a couple generators, some batteries, solar panels, satellite dish, and a bit of miscellaneous materials. It needs to be secure enough to stop the honest people from stealing my stuff. Looking at it from that perspective, I don't need a big rig trailer. The big rig trailer will be heavier, cost more in maintenance, and run the risk of some cop feeling his oats hassling me for not stopping at a scale. Going with a lighter duty trailer seems to make the most sense.
I'm still divided on the whole buy vs build for the box. I think I'll keep my options open for now and just keep an eye out for different things.
My understanding of these is that they attach to the pulling vehicle and provide another axle or 2, and can be pulled independent of having a 5th wheel sitting on it. Also, I believe that with a pintle hitch, it would be able to pivot at the point of the pintle hitch. Since it can also pivot at the 5th wheel plate, that makes a 2 pivot point towing setup, making for 3 individual moving bodies. Whether that is considered towing "double" or not is up for interpretation, and we all know how much room for interpretation there is in the laws.
But legal issues aside, I have no desire to be backing a 3 pivot point system around in a tight area. Ever.
Yep, that's pretty much what was established earlier today.
thanks,
jim
Old 05-22-2009, 12:25 AM   #10
search truck conversion.net
my understanding is that if it started life with a commercial trailer title that you cannot chaange the title or registration to noncom status.
the other thing is the construction of a box semi trailer is frameless or more specifically the top and bottom siderails are the frame and the roof,floor and sideskins are the structural webs in the beams.
looking closely at the underside of a box trailer you will see a pair of perforated framerails on the back half or third of the trailer, the suspension assembly is pinned to this subframe and by locking the trailer brakes and releasing the pins you can slide the trailer front or back on the axles to effectively change the wheelbase or transfer the weight on the axles, fifth wheel hitches can also be setup to slide.
for clarification a pintle hitch consists of the pintle hook on the truck, like a clasp on a necklace, and a lunette eye on the trailer. the wiggle wagons or double bottom trailer setups that you see on big trucks use a fifth wheel setup on the tractor, a pintle hitch on the lead dolly or jeep to the back of the first trailer and another fifth wheel setup for the second trailer to the dolly
a straight truck/skoolie pulling a tag trailer with a pintle hitch is the same as a trailer with a ball hitch, the only difference is that pintle hitches can be had with higher weight capacities and ratings.
Old 05-22-2009, 12:47 AM   #11
more thoughts,
it's easy to get an assembled trailer title and registration here in michigan, all you need is a weigh slip from a certified scale, any truckstop,grain elevator or scrapyard is a good place to start, depending on the weight you may need to have it inspected by the police to insure that it has all the lights and brakes required, it never hurts to have reciepts for the major components
brake controlers; the good controllers that tapped into the hydraulic brake system were outlawed probably because ralph nader won a lawsuit because someone didn't install a contoler the right way and some inexperienced overconfident driver was talking on the phone in rushour trafic and caused an accident
Old 05-22-2009, 09:05 AM   #12
NewSkewlHauler's Avatar
Engine: 8.2L Detroit N/A, Allison
Here's my 1/50th of a dollar on the subject...I tend to be a thread killer of sorts I've noticed (not because I have anything good to say, though), but here's a thought for what it's worth.
I'm looking at two buses, 86/88 Fords with air brakes. I want to chop of the rear 15' or so off to make a flatbed with a gooseneck to attach and haul a horse trailer or a flatbed for haul. I've been thinking about this since February. Just the other morning, I got to thinking about what to do with the "chopped off" part. I thought about a storage shed in the back yard, but that didn't appeal to me. So the current incarnation of my plan would be to find a wide enough car hauler (just like for your application) and mount the sides of the bus and roof on top of a flat-deck car hauler trailer. This would give me an enclosed box for my horses that should be fairly strong, semi insulated, safety glass, and "free" other than the cost of the bus, trailer, and my own blood, sweat, and tears. I could add a foot or so to the bottom of the bus walls to raise the midpoint of the "new" trailer to 7-8' depending on the roof height of my bus, etc. This would be fine for horses. I'd need to skin the bottom and the front of the box at that point. For your application, you could build a ramp or adapt ones that might come on a car hauler flat deck.
I'm not sure I'm painting a great picture here, but I hope you get the idea. I've sketched it out a few times and I think it'll be cool as all heck. But again, I'm a math teacher of junior high kids...so I have to be a bit loco right?
Ben.
NewSkewlHauler is offline   Reply With Quote
Old 05-22-2009, 09:39 AM   #13
Funny you should mention that Ben. I was thinking something similar myself.
I have an intermediate need for a storage unit of some sort so I can get the items currently stored in my bus out of my bus. I know where some busses are for sale locally for about $1800, which I'm sure I could get knocked down.
I was thinking that it would provide me with a mobile shed for the yard while I do my conversion, and I could put all my conversion goodies in that bus/shed and get other peoples stuff out of my bus and into their sheds where my stuff currently is. Of course, an old box truck would work the same way, just with less ventilation options (and less points for leaks).
Further along in my conversion, the "extra" bus could probably provide more raw materials to use on the conversion bus. I could probably also get something for the driveline/etc to help offset costs.
The more I think about it, the more I like that idea.
I might just stop by there this weekend and take a look at those busses.
jim
Old 05-23-2009, 05:32 PM   #14
I did stop by there today, and bought one of the busses. The other one is still there if anyone is looking for one in the mid-atlantic area.
I'm planning to use it for storage in the short term. Haven't decided whether removing the seats would be helpful for that, but I'm thinking it would. Not looking forward to that task. It was something I managed to avoid on the first bus by buying it already done.
I do keep eyeing that monster sitting out there.... strong frame, great shell, good length (actually, a bit longer than needed). Just changing over to some electric brake containing trailer axles and figuring out a solution for the tongue and I'd have a nice trailer. I'll definitely have to give it some thought. Still plenty of time left before I have to decide anything.
This weekend I don't have anyone that could help me out with working on either bus, so it is unlikely that much will get done.
jim
Old 05-26-2009, 09:17 AM   #15
The more I look at this bus and crawl around in and under it, the more I think it would be perfect as a trailer body behind my main bus.
Of course, I'll need to have the trailer frame first. At that point, I would know what length I would need for the trailer body, and I could just chop the bus at that point measuring from the back of the bus. Supposing that number were 20', then I would take the last 20' of the bus.
As for the chopping, I would remove the panels at that point rather than cutting them, and separate the front and rear sections that way, keeping the rear box intact along with its ribs. Then, it would be a matter of jacking the body up, driving the bus out from under it, and putting the trailer under it and lowering it into place.
I've been thinking it would be neat to put the bus body on the trailer backwards, with the rear of the bus facing the tongue of the trailer. This gives me a ready made door, which is convenient.
At the other end, I would take the next major rib of the bus and put at the very end, then put the panels back on and cut them to match the rib. Then simply frame in a square-ish hole for the garage door (either a bi-fold or a rollup typical garage door), some tail/brake/etc lights, and so forth, and it'll be a nice garage on a trailer.
I don't know what I would do with the remainder of the bus at that point. However, it would probably contribute more parts.
I suspect I would need to raise the roof on the trailer to give enough clearance. I would also want to add a side double door wherever the drivers door of the vehicle inside the trailer would fall, so it'll be easier to get in and out of the vehicle. I've been thinking that a low deck trailer frame would be good, so I would have to put wheel wells inside the enclosed space and make sure the vehicle could safely drive over the humps, which likely means adding some kind of ramp/track inside for the vehicles tires to ride over the humps.
I'd like to keep some of the school bus windows in the trailer, as it would be free ventilation.
So, still an insane idea, but I think a far more practical one than the original idea of converting a cargo container.
jim
Old 05-26-2009, 02:00 PM   #16
look closly at how the outside skins overlap each other, the front of the skin is under the back of the ski ahead of it so that wind and weather flow over the seam instead of the seam acting like a scoop trying to pull the weather into the interior, it's a lot more work but you could remove the rear cap and reinstall it at the front of the body with the proper overlap pattern.
if you don't need extra headroom or a lower floor you could cut the bus frame long and pull the rails together for a tongue, then remove the driveshafts and inner axle shafts and make up coverplates to seal the rear hubs. if the ''trailer''axle has hydraulic brakes install a hydraulic brake actuater in the tongue/coupler, if it's air brakes you will need to install the required valves and plumbing in the tow vehicle
Old 05-26-2009, 02:34 PM   #17
Ack! I knew about that and completely spaced on it when thinking... time for a bit of re-think.
Well, I'm pretty sure I'm going to want the extra headroom. Also, I'm worried about it being too top heavy. There's also the consideration of trying to get a vehicle 36" off the ground with ramps that a mere mortal can lift.
The "new" bus is hydraulic brakes, but I think I'd rather have trailer axles under the frame.
With the frame on a bus being narrow and to the center, do you think that would be a problem, or would it make sense to spread the frame rails apart more, realizing that the cross members would have to be changed, which is of course assuming they're bolted and not welded. I'll have to take a closer look at them tonight when I get home.
I could lose some of the lower side skirting if it meant having a lower trailer. Obviously the frame that the bus has currently is definitely strong enough for my needs, but I do worry about the height involved. Those are some tall frame rails.
ugh, more thinking and planning to do. Still, plan a million times, build once.
jim
Old 05-26-2009, 06:22 PM   #18
So what of this "new" bus? Motor/trans/passenger rating, etc? I can't wait until you get started on this. I want pictures!!!! WHEN I get my bus, I'll be able to point out to the other half that this has all been done before and I'm not reinventing the wheel. I got to thinking today that growing up in Northern Minnesota, the local school district had a trailer that they pulled behind the "sports bus." It was just the last 20' or so of an old bus that they had chopped up. I think they used it a lot during football and hockey season to carry all the extra equipment around in. It looked pretty cool. I think that for your application (and mine eventually), a lower floor height would be the best thing. I thought I saw a LoadMax (maybe another brand) gooseneck car hauler trailer that was 96" wide overall. It was 7' between the fenders of the trailer, so there'd be no "hump" to drive over (unless you have some major super swampers on that 4x4!). The remaining 12" (6" each side) was on positioned in front of and behind the fenders...so it was kind of like having running boards. You could build a 1' tall (or so) 1x2 steel frame to lower the cutoff portion of the bus onto. I like the idea of attaching the rear cap at the front for ease of access and ease of building a door. Detaching and reattaching the rear cap might be a pain, but it will produce a nice finished product in the end. Do your buses have the same coachwork?...that would be sweet if the body styles were somewhat similar. Best of luck.
Ben.
Old 05-26-2009, 08:12 PM   #19
Ben,
the details, including pictures, are in the thread "oops, I did it again" located here: http://www.skoolie.net/forum/viewtopic.php?f=6&t=4271
Yes, both busses are Thomas Built Busses. It is amazing the similarities and differences.
For instance, the pusher has 4 rub rails, while the gasser has 3.
The gasser has some oversize windows, the pusher seems to have a single standard size.
The driver window on both busses seems to be identical.
The pusher had the switch console overhead, and the driver sits really close to the side window. The gasser has the driver sitting closer to the center of the bus, and the switch console between the driver and the side window.
What would've been über cool would have been one of those 20-25' front engine flat faced bluebirds as a "toad". Turn the rear into a drive-in hatch like millicent, put in some fold down bunks, and have a weekend getaway camper behind the main camper. Yep, that's truly insane... yet I toyed with that idea for a while. I think it would look cool going down the road, but I don't know that it would be worth the extra work.
I've been looking at trailer axles online, and found some tandem 14,000 pound axles for a decent price at one location, with electric brakes on each axle (7,000 pound per axle). So really, it'll boil down to getting the frame right.
In any case, with the drizzle here I didn't crawl under the bus for a better look at the frame tonight. Hopefully tomorrow night. Dad and I hope to begin seat removal. I believe we'll start with a wrench on top and an impact driver underneath with an extension. Once we've done all that will work, we'll go back with the angle grinder for the rest. Considering how clean the bus is underneath, and how easily the first two started to come loose, I don't anticipate too much trouble. Before I can do that though, I have to get in there and identify exactly which seats I want to remove. eep! time to plan!
I know it isn't the "normal" way to do things, but I want to plan for having the vehicle backed in, so the axles will be a bit more to the rear than normal. This lets me have the double door on the curb side. Also, it'll be super-easy for someone to just drive straight out. Basically, backing out means starting without being able to see all around you, and moving towards being able to see more. Backing in you start with being able to see all around, and lose visibility as you enter, but you also reduce the danger zone as you enter.
Having the engine towards the rear of the trailer may make this a fun exercise.
I'm really liking the idea of using the bus frame the way paul suggested, and just dropping it onto lower axles. I know that frame is very strong. Your idea of a wider axle is intriguing. I'll have to give that some more thought. It might raise the price a bit much though. I really don't mind wheel humps as long as what is over the wheels is strong enough to handle a vehicle going over it. And that's really up to me doing a good job.
It will be some time before I can start on this particular aspect of conversion. I first have to make some serious progress on the main bus. I also have an old RV to finish destroying, a summer kitchen to help finish building, and some other things going on in my life as well that will be big time and energy consumers. But some of those things might result in more assistance on the conversions, so that's a good thing.
Old 05-27-2009, 02:38 PM   #20
more thoughts;
an internal beavertail like millicent and backing the trailer tires onto a ditch or depression will do wonders for loading deck height.
if you're serious about tandem axles, single wheels, the easy way is back to the used mobilehome frame with the stock 6k axles and take the bus body off of the truckframe and shorten the mobilehome frame to fit.
Cargo Space - Blue Bird CSFE conversion CargoSpace Short-Bus Conversion Projects 32 07-23-2013 11:04 AM
Crane Carrier chassis Serenity Conversion General Discussions 2 06-12-2012 02:59 PM
Raising a (cargo) trailer paul iossi Conversion General Discussions 6 01-12-2010 06:04 PM
"Stealth cargo trailer" TexCaver Everything Else | General Skoolie Discussions 2 12-13-2009 01:32 PM
Armored Personnel Carrier dammitAndy Everything Else | General Skoolie Discussions 4 12-13-2005 08:18 AM
