Dog-Nose? Flat-Nose? Conventional? Pusher?
General discussion about conversions. New products, problems, ideas, etc.
Postby CHEESE_WAGON » Wed Sep 04, 2013 4:22 am
As it becomes obvious to me that my current Pace Arrow will suffer the same fate of a failed roof as my 28-footer, I contemplate using the two for parts to build a bus when I have the time and money to do so. However, on reflection, there were some things about the Ford-chassis Blue Bird I previously owned that I found I didn't particularly care for...
1) - The Lucas-Girling hydraulic brake system. JUNK. Absolute, unadulterated, JUNK. Are they still built this way, and if not, when did they stop? While I have no real preference (my understanding is that CDL is not required for motorhomes, even if they have air brakes), when I go bus shopping, I will only buy a Ford-chassis with air-brakes.
2) - The utter inaccessibility of the engine, due to the conventional-type hood arrangement. Therefore, again, while I have no real preference, my criteria for a dog-nose is a one-piece tilt-forward nose, like a semi.
3) - The standard height roof and short rear door through which I routinely entered and exited. I know these things are designed for kids, who generally aren't as tall as adults, but I remember reading that some buses came factory with a higher roof, and I have noticed that many newer ones have a taller rear door, as well as additional side doors. Do only certain manufacturers build this way?
I would like to hear from others on what manufacturers and chassis I should stay away from, as well as any thoughts on the pros and cons of flat-nose buses vs dog-noses, and conventional powertrain/drivetrain layouts, vs pushers.
"Cheese Wagon" <anomaly1976@inbox.com>
Former owner - 1989 Ford B700 BlueBird 64 passenger (Rest In Peace, Cheese Wagon)
Check out my original music page ("Allergic To Air" on Facebook) and YouTube channel (AllergicToAirMusic)
User avatar
CHEESE_WAGON
Mini-Member
Mini-Member
My Bus: Non-Owner
Year: 0
Rated Cap.: 0
Re: Dog-Nose? Flat-Nose? Conventional? Pusher?
Postby somewhereinusa » Wed Sep 04, 2013 8:48 am
1) - The Lucas-Girling hydraulic brake system. JUNK. Absolute, unadulterated, JUNK. Are they still built this way, and if not, when did they stop? While I have no real preference (my understanding is that CDL is not required for motorhomes, even if they have air brakes), when I go bus shopping, if it is a Ford-chassis, it will be air-brake ONLY.
How old was that thing, I don't think Ford has done this for quite some time.
Here again, I think that newer might be better and more likely to have a tilt hood. I think you will also find that the tilt hood may not help all that much since much of the engine may be back further than the firewall with an engine cover inside. Those that have them can better address that. I myself like a Bluebird pusher, the whole back end opens, I believe Thomas is built that way also. I have seen IC's that only had a smaller door in the middle that opened. I can stand on the ground and work on pretty much anything and don't even have to crawl over the tires. The only real things in the way are things I put there.
Thomas and Bluebird both had three different roof heights, I don't know about the others. You just have to look around. I don't know what year, but both of those manufacturers have quit offering anything but the tall ones. I think that the side door exit and placement is probably by individual school corporation and or state requirements.
THIS IS ONLY MY OPINION.
Pros to RE(pusher)
noise is "back there" I can hardly hear mine running.
more interior room compared to overall length of bus
no long driveshaft taking up valuable under bus space
better ride
easier to work on
better overall driver viewing area
wider straight entry steps
no engine cowl to have to get around to get to driver seat.
Pros to conventional
looks like a school bus ???
Dick
User avatar
somewhereinusa
My Bus: somewhereinUSA
Chassis: AARE
Engine: Cat 3116TA 250HP
Rated Cap.: 48
Postby wmkbailey » Wed Sep 04, 2013 9:04 am
Ditto what Somewhere said. :)
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
User avatar
wmkbailey
My Bus: Visvi
Engine: 3126
Rated Cap.: 72
Postby CHEESE_WAGON » Wed Sep 04, 2013 5:39 pm
It was an '89 model. I drove a '96 F650 box truck that had this junk on it as well, and I have not heard of hydraulic-brake Fords being built any other way. Hydro-boost, I can understand to a degree because of diesel engine options, but why not just have a simple engine-driven vacuum pump? :P
User avatar
CHEESE_WAGON
Mini-Member
Mini-Member
My Bus: Non-Owner
Year: 0
Rated Cap.: 0
Postby JDecker » Sun Sep 08, 2013 1:29 am
I'd personally prefer the pusher for the reasons mentioned above, but I can think of two other commonly referenced pros of the front engine configurations: they are more capable off road, due to more ground clearance and shorter wheelbase, and they drive pretty much like any other truck, while the feeling of being so far in front of the front axle(as in the long pushers and especially coaches)is hard for some people to get used to.
JDecker
Mini-Member
Mini-Member
My Bus: Tequila Mockingbird
Chassis: All American RE
Engine: Cummins 8.3
Rated Cap.: 84
Postby Diesel Dan » Mon Sep 09, 2013 11:34 am
One advantage of a front engine bus that hasn't been mentioned here is the capacity for hauling cargo. I deliberately left my center aisle completely unobstructed front to back (except for a door that separates a rear utility/bath room, but can be opened). So I can load very long pieces of material into the bus. For instance, I am about to install gutters on my house, and will be able to easily load the gutters into my bus. Also, I can fit 8x4 sheets of plywood, drywall, insulation, or whatever, through the rear door. Other people have modified the rear end of their front-engine buses to enable the whole rear section to fold down as a ramp so a vehicle can be loaded in there.
User avatar
Diesel Dan
My Bus: Magic Bus
Engine: DT466/AT545
Rated Cap.: 0
Postby bansil » Mon Sep 09, 2013 1:52 pm
Diesel Dan wrote:One advantage of a front engine bus that hasn't been mentioned here is the capacity for hauling cargo. I deliberately left my center aisle completely unobstructed front to back (except for a door that separates a rear utility/bath room, but can be opened). So I can load very long pieces of material into the bus. For instance, I am about to install gutters in my house, and will be able to easily load the gutters into my bus. Also, I can fit 8x4 sheets of plywood, drywall, insulation, or whatever, through the rear door. Other people have modified the rear end of their front-engine buses to enable the whole rear section to fold down as a ramp so a vehicle can be loaded in there.
X2 it is nice to have 20/24 foot pcs of metal instead of cutting it down
User avatar
bansil
Moderator
Moderator
My Bus: La Tortuga
Coachwork: CROWN at heart
Chassis: Heavy pcs
Engine: 12 valve cummins
Rated Cap.: 2
Postby CHEESE_WAGON » Mon Sep 09, 2013 6:04 pm
Well, they are, after all, medium duty dog-nose/cabover truck chassis at their basics... :)
User avatar
CHEESE_WAGON
Mini-Member
Mini-Member
My Bus: Non-Owner
Year: 0
Rated Cap.: 0
Postby syke » Mon Sep 09, 2013 10:38 pm
Pusher.... just sayin. :)
Ryan
Bluebird All American RE
Our build thread: viewtopic.php?f=9&t=10065
User avatar
syke
Rated Cap.: 72
Postby Skunky Bus » Sun Sep 15, 2013 11:40 am
somewhereinusa wrote:Pros to RE(pusher)
better ride
easier to work on
One aspect of the dog-nose that may be a factor for some folks: driving position. The ones I've sat in are enough like my Class C that I'd have to take a tape measure to notice differences in seat height and steering-wheel angle. The flat-nose models I've seen (especially older models) have a more horizontal steering wheel and lower instrument panel. I'm sure I wouldn't like that as much. If I were going for a flat-nose I'd probably want a pusher for the reasons Dick/Somewhere mentioned, esp. the dang doghouse on FE bodies is bigger than my Class C and in the way of my 3-1/2 feet of legs. Could be that some flat-noses have steering-wheel angle more to my liking.
somewhereinusa wrote:Pros to conventional
Dick
I like that school-bus look. Some folks hate it.
"[The skunk] teaches how to give respect, expect respect, and demand respect." – Ted Andrews, Animal Speak
User avatar
Skunky Bus
Year: 0
Chassis: Want a Dodge
Rated Cap.: 0
Postby CHEESE_WAGON » Sun Sep 15, 2013 11:48 am
Skunky Bus wrote:I like that school-bus look. Some folks hate it.
As do I... Guess it's because I grew up with conventional dog-nose gassers ... Loved the look of my old '89 Ford B-series... Too bad I had to get rid of her. Found out it had a brand-new 429 Jasper engine with probably <10k on it. Probably for the better though... It had the crappy Lucas-Girling brakes...
User avatar
CHEESE_WAGON
Mini-Member
Mini-Member
My Bus: Non-Owner
Year: 0
Rated Cap.: 0
Postby bapos » Sun Sep 15, 2013 2:06 pm
That's sucks about your bus having to be gotten rid of. That would be a nice motor to put in a lot of things if your a Ford guy? Things happen for a reason....do as you did move on to better things.
Here is my school bus conversion thread http://www.skoolie.net/forum/viewtopic.php?f=9&t=10282
Pics of my conversion @ photobucket http://s18.photobucket.com/albums/b136/bapos/School%20Bus/
User avatar
bapos
My Bus: Big Ass Pimp Mobile
Year: 1983
Coachwork: Ward
Engine: 366 Gasser
Rated Cap.: 66
Postby CHEESE_WAGON » Sun Sep 15, 2013 2:14 pm
Yeah, kinda thinking about a flat-nose, pusher or not. I really dig the old dog-nose gassers but I suspect that being hard to find will be the least of my problems at this point, and I kinda like the better maneuverability of having the steering axle under/behind you...
User avatar
CHEESE_WAGON
Mini-Member
Mini-Member
My Bus: Non-Owner
Year: 0
Rated Cap.: 0
Postby bapos » Sun Sep 15, 2013 5:06 pm
I agree on all counts. I think if I had to do it all over again I would do a BB flat nose rear engine just do to the space.
User avatar
bapos
Year: 1983
Coachwork: Ward
Engine: 366 Gasser
Rated Cap.: 66
Postby Jarlaxle » Sun Sep 15, 2013 7:32 pm
IIRC, Ford used the L-G brakes until the cabs changed for 1999. Not just Ford, either: some Freightliners also did...all I have seen were smaller shuttle bus/delivery truck type chassis. Good idea, but the reality of it SUCKED!
Regarding the tilt-front, I think all Internationals since the early 70's had that...so did some Fords and GMC's. (My B700 had a tilt hood.)
Jarlaxle
International Genesis, conversion in progress
Optimism is a mental disorder.
Jarlaxle
Coachwork: Ward Genesis
Engine: DT466/MT643
Rated Cap.: 77
Next
Return to Conversion Discussion
Who is online
Users browsing this forum: No registered users and 1 guest
