Old 04-08-2014, 11:28 AM   #1
Engine: DT466 Allison
Newly Purchased Skoolie - Tips for removing rivets and floor
Hey guys! I just purchased a Skoolie and will be picking it up in Texas in 10 days! I need some advice on how to remove the rubber flooring and rivets from ceiling and wall. Also, what steps should I follow? So far I have a plan and builders and the bus! What do I need to do to the bus before building? Here's pictures below of my bus.
Alexlorraine01 is offline   Reply With Quote
Old 04-08-2014, 05:28 PM   #2
turf's Avatar
Re: Newly Purchased Skoolie - Tips for removing rivets and f
elbow grease
welcome to the forum
Turfmobile Build Thread
Old 04-08-2014, 06:19 PM   #3
bapos's Avatar
Engine: DT466E/MD3060
Not sure if you have one but I highly suggest getting an air compressor and a air hammer with a chisel. You can use it on both to get tuff items off. When you remove the rivets from the ceiling you will thank me.
I took off the metal skin interior in my bus in about 45 min to hack mine out. I am going to be taking down the ceiling so I will see how long that will take.
I have a pretty large air compressor so with 175 psi it makes short work of those things.
Old 04-17-2014, 02:07 AM   #4
is there a reason I cant see the OP's photos?
PowerDaniels is offline   Reply With Quote
Old 02-16-2016, 10:30 PM   #5
Coachwork: GMC
Chassis: Bluebird
Engine: CAT 3116
Rated Cap: 71
Air Hammmer
just bought a 1995 bluebird, first project is to remove the seats, would a air hammer work on the bolts holding the seats on. and if not whats my best option.
herb_woof2 is offline   Reply With Quote
Old 07-01-2016, 10:22 AM   #6
I used a 4 inch angle grinder. It worked well but it did take me about 16 discs/blades.
coach21 is offline   Reply With Quote
Old 07-01-2016, 10:36 AM   #7
Wow that's an egregious amount of discs.
Old 07-01-2016, 09:25 PM   #8
karrlot's Avatar
Coachwork: Ward
Rated Cap: 65 passenger
I had to use an angle grinder and a chisel. On the first 900 rivets i spent about 40 hours with a hammer and cold chisel. On the next 200 rivets I used an angle grinder and air chisel. That took about 3 hours and a lot less advil.
I would highly recommend an air compressor and an air chisel.
Please check out my blog-
Follow the (lack of) progress on the Karr Family Kamping Bus Blog
Here is my woefully inadequate build thread:
https://www.skoolie.net/forums/f11/i-...bus-12296.html
karrlot is offline   Reply With Quote
Removing internal rivets timbrass Conversion General Discussions 11 07-01-2015 08:15 PM
registering a newly bought skoolie in Missouri! ClovenLife Titles, Insurance, Registration and Money Matters 1 08-31-2010 04:58 PM
Removing rivets from rubrails jkindt Conversion General Discussions 7 03-07-2010 01:00 PM
Tips for removing bus lettering BUSBOZO Conversion General Discussions 1 02-01-2010 11:49 PM
Removing Rivets oldog12 Everything Else | General Skoolie Discussions 3 05-25-2007 10:45 AM
