Old 04-19-2014, 07:35 AM   #1
Coachwork: Goshen Sentry
Chassis: Spartan
Engine: cummins 250
Rated Cap: 36
New Bus owner Questions about tractor paint RV style bus
Hi all I recently purchased a 1998 Goshen Sentry 36' passenger bus
The Goshen Sentry is basically a bus built on a RV platform
https://www.carsforsale.com/used_car...?vid=145810441
My bus is very similar but the paint needs attention
I have started to research tractor paint.
I just want a white paint job.
I don't want to destroy the value in the bus and want something that will hold up well.
Does anyone have a recommendation on a easy DIY paint that has pro like results.
Also what should a decent paint job cost in plain white? The windows take up more space then the body panels.
Does Anyone know of a good video system to add to the bus?
Thanks,
1998 Goshen Sentry Pusher 250hp mechanical cummins Allison MT643 w/side radiator (perfection)
https://norfolk.craigslist.org/cto/6138246721.html
Deshet is offline   Reply With Quote
Old 04-24-2014, 07:42 PM   #2
Coachwork: International/Thomas
Chassis: 3700
Engine: 7.3
Rated Cap: 73
Re: New Bus owner Questions about tractor paint RV style bus
These are a few thread that I used when deciding how to paint my bus,
http://www.instructables.com/id/Paint-Y ... Rustoleum/
http://www.meguiarsonline.com/forums/sh ... t-job-quot
My conversion thread, viewtopic.php?f=9&t=466746
BUBB is offline   Reply With Quote
Old 04-24-2014, 08:29 PM   #3
opus's Avatar
Chassis: All-American R/E
If you dont want to destroy the value of the bus, get it done right. If you want something that will last long and look good, skip it. Get it done professionally. Thats a pretty flat bus, should be pretty reasonable to paint. After the hours you would put into prepping the bus for paint, you really wont be saving much, if any. Lots and lots of prep work!!
This comes from experience by the way. ;) But I knew that going into it.
Old 04-24-2014, 11:08 PM   #4
Chassis: TC2000 FE
Engine: 190hp 5.9 Cummins
Buses have no resale value.
This is one of the reasons for changing from a bus cab to a truck cab with my Haul All build. The truck gained $10,000 of value. When I convert to 4x4 it will gain another $10,000 of value.
Medium duty trucks hold their value. Buses just loose value.
Do you really want the hassle of looking after a (nice) paint job that big?
Or like most of us, just use some thing that looks good from 10 feet away, keeps the metal from rusting, and holds up well. Big rock chip, or a fender bender can be fixed with a spray can, or brush. Makes for stress free ownership.
IMO painting a full size bus should cost less than $500.
Nat
Old 04-24-2014, 11:13 PM   #5
Chassis: TC2000 FE
Or if you like bling, how about a vinyl wrap?
Google automotive vinyl wrap.
https://www.google.ca/search?q=automoti ... 66&bih=664
Or Google Bus vinyl wrap.
https://www.google.ca/search?q=automoti ... l&tbm=isch
Or if you like a specific pattern like camo.
Nat
Old 04-24-2014, 11:28 PM   #6
opus's Avatar
I have $350 info my paint job.
A good vinyl wrap on a Prevost is about $10,000.
Old 04-25-2014, 02:08 AM   #7
Chassis: TC2000 FE
Nat
Old 04-25-2014, 04:09 AM   #8
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Well...there goes my idea about wrapping my bus in World War I lozenge camouflage
Hey! That's not an RV, that's a school bus.
Well thank you for noticing, Captain Obvious
Captain Obvious on deviantArt
Scooternj is offline   Reply With Quote
Old 04-25-2014, 06:16 AM   #9
Chassis: TC2000 FE
Price looks like $5 a square foot to me.
http://www.camotruckwraps.com/product/C ... and-Sheets
http://www.metrorestyling.com/Digital-A ... armydg.htm
https://www.google.ca/search?newwindow= ... v2N7UI0OLY
Walls of a bus are approximately 6 feet x the length of the bus. I will go with a 38 foot.
6x38=228 square feet per wall. Rear would be 6x8=48 square feet.
So 2 walls at 228x2=456 + 38 for the rear wall = 494 square feet.
At $5 cents a square foot, we go 494 x $5 = $2479
So a DIY vinyl wrap for a big $ss 38 foot skoolie would cost around $3000.
Disclaimer.
I know nothing about how long this stuff lasts.
Nat
Old 04-25-2014, 08:11 AM   #10
I saw somewhere else on the forum I believe, maybe elsewhere, that a vinyl wrap starts to really fade in 3 years time.
PowerDaniels is offline   Reply With Quote
Old 04-25-2014, 10:11 AM   #11
opus's Avatar
Wraps arent made for long term. They change them about every oil change it seems...well, in the music world at least.
I couldnt EVER imagine putting a wrap on myself! I tinted a window once.......
Then again, my focus is never on appearance, but it sure is on mechanical condition. Son's gals brothers are excellent at "tagging" things, buildings, vehicles. I had half a mind to park the bus and let them go at it. What I get is what I get.
Old 04-25-2014, 07:26 PM   #12
Year: 1977
Coachwork: Chevy
Chassis: C/60
Engine: 350 V8
Rated Cap: 54
Nat
I used DuPont Automotive paint with the proper primer and hardner and was just shy of $400 to do my skoolie. Looks nice and shouldn't fade all too quickly.
Passes everything but gas stations.
bamper is offline   Reply With Quote
Old 04-26-2014, 09:52 AM   #13
bapos's Avatar
Engine: DT466E/MD3060
I plan on using tractor paint from tractor supply as a matter of fact. Going to use my HVLP sprayer to shoot it.
I think its a easy and cheap way out to get it recolored. If you dont like it..... well change it up. Since mine will be the texas flag it will be pretty simple to do.
As said here I dont think you will loose or gain value in a professional paint job for the bus unless you are doing something special with it. I say go cheaper... drive it... enjoy it.
Old 04-26-2014, 06:43 PM   #14
I agree with you, a nice paint job is worth it, I have to redo mine it sucks, it does add to the value, it puts it much more in " better built rv class" then a school bus turned into a camper. We take pride in our interior builds, a pro paint job is icing on the cake
Old 04-26-2014, 09:18 PM   #15
Year: 1977
Coachwork: Chevy
Chassis: C/60
Engine: 350 V8
Rated Cap: 54
It will fade, promise. I've painted literally hundreds of old Farmall's and Moline's (and even a few Deere's ... shudder) and there is an absolute difference between the paint at the "tractor supply" store and actual tractor paint. I've used the cheap paint upon request and it ALWAYS fades in a few years, even when kept inside annd used for parades and what-not only.
There's a very good reason I spent more on paint on my skoolie than I did for the bus itself ...
Do it right the first time, or don't do it at all. Cheap is always more expensive in the long run.
For what it's worth, around 150 hours went into my paint job. 4 of us, two weekends, 10hr days and a "few" cases of beer. Did not sand to bare metal but we fixed all the visable rust, patched what we needed to and prepped it properly. Looks good, won't fade and should outlast my obsession with skoolies (as if).
Old 05-05-2014, 09:05 AM   #16
Chassis: Spartan
Engine: cummins 250
Rated Cap: 36
The bus is not a school bus it is a small coach. It is flat like a Blue bird TC2000. It is a Goshen Sentry. I don’t know the actual value but I would assume it is $15-$20K with the low miles and the Cummins 250hp/Allison MT643 rear engine setup. We are trying to getting it looking as presentable as possible. It will be used to transport youth basketball players to tournaments for a non-profit organization. This is not the type of organization where anyone receives a paycheck.
It is currently white and I want to keep it white. I found a product called Dakota Shine. It looks like thick spray on wax. Does anyone have any experience with this type of product? I watched a few YouTube videos about it and it sounds like a good product. If anyone knows of a similar product that is available in bus sized amounts please let me know.
I have heard of people using mop and glow and things like that but I am skeptical about the long term results and possible paint damage.
Respectfully,
Old 06-24-2014, 09:30 PM   #17
Moderator
crazycal's Avatar
Chassis: 3800
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Don't want to burst any bubbles but you would be hard pressed to get 15-20k.
I'm hungry!
You Gotta Let Me Fly
8.2 Detroit Diesel Questions - Owner Input Sought kamoo Detroit Diesel Drivetrain 19 05-09-2015 09:01 PM
Paint Questions jkindt Conversion General Discussions 15 02-26-2010 07:12 PM
New Owner/Member with Thomas Transit Liner Questions... ezbme Everything Else | General Skoolie Discussions 61 06-13-2009 09:46 PM
can transit bus people post too? jakes and paint questions kbunnystarr Conversion General Discussions 0 11-07-2006 01:52 PM
More questions from a new bus owner Demonknight Conversion General Discussions 15 01-24-2005 12:19 AM
