Old 06-11-2014, 01:16 PM   #1
Chassis: B3800 Short bus
Rated Cap: 36
Installing a different tank mount and/or fuel tank
Insane.. Simply insane. For the kids sake I'm happy that the school bus manufacturers build such a tough cage around the fuel tanks, but for what we're using these buses for it is definitely overkill.
I dropped my tank the other day so I could undercoat the floor above it. Now I feel the need to rid myself of the additional 300lbs that is the tank mount/cage. Is it worth it? What are the other mounting options? I'm thinking of strapping it to the frame rail like you might see on light/medium duty box trucks.
Old 06-11-2014, 01:22 PM   #2
opus's Avatar
Chassis: All-American R/E
Re: Installing a different tank mount and/or fuel tank
Not worth the effort. Safe is safe whether its for you, kids, or the person the plows into you. My opinion only....
Old 06-11-2014, 01:42 PM   #3
wmkbailey's Avatar
Engine: 3126
x2
William
https://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 06-11-2014, 01:53 PM   #4
Rated Cap: 36
Demoting the tank from maximum security to normal security doesn't bother me. The time it takes to do the work and the cost are the big factors at play. Without the cage I should be able to fit a 60-65 gallon tank instead of the current 40 gallon. That's appealing.
Old 06-11-2014, 02:37 PM   #5
Rated Cap: 36
This is way too low, but I like the simplicity of the design:
From http://geektrap.com/bill/01205761106 (nice conversion, by the way)
Do you think those brackets could be mounted upside down and the tank hung from them with metal straps? That would make removing the tank much easier. I also like the additional triangle support piece welded on the corner. I reckon that'd be plenty strong.
Old 06-11-2014, 09:09 PM   #6
Rated Cap: 36
The cage on mine is also what the tank mounts to. Was your B700 the same? If so, how did you mount the tank after getting rid of the cage?
Old 06-16-2014, 05:01 PM   #7
Rated Cap: 36
Alright. I dug the tank out from behind my Mother's shed. She was happy to see it go, I'm sure.
This is the new tank. It's sitting on top of the 7 ton tank cage.
As you can see, I've been using it as a table for spray painting.
Here is the new 73 US gallon tank sitting next to the old 39 US gallon tank.
And here's the best part. You can see from this angle that the new tank - though almost twice the size of the old tank - will take up the same amount of space as the old tank+cage! The tank is actually an inch or two shorter than the cage, it's just the angle makes it look the opposite.
Looks like I'll have to relocate the fill spout on the new tank. I'm sure I'll re-use the old tank under the bus eventually, but the bigger tank is much better use of that undercarriage space.
Now, how do I mount it?
Here's an initial idea.
I'd like to be able to drop the tank without removing the brackets from the frame. That'd be nice.
Old 06-16-2014, 08:53 PM   #8
Rated Cap: 36
Too perfect:
Geez.. I just got done heaving that cage around again. I swear, that old tank full of fuel + the cage can't weigh much different than this new one full of fuel, but this new one can provide almost twice as much diesel.
Old 07-12-2014, 07:51 PM   #9
sojourner's Avatar
Engine: DT408
I'm working on the same kind of thing on my 40'er. I want to put twin 100 gallon fuel tanks. Planning on using mobile home straps to secure it into place with overhead hangers (they're rated at 3200lbs). My son (an engineer at a local metal fab co.) ran the deflection on 2x2x3/16 tubing at a length of 28". Here's the message from him:
.266” of deflection with a 1500lb point load on the end. Or .0999” with an evenly distributed load along the 28” arm.
Needless to say, 4 arms over the tank should hold it very nicely. I'm planning on bridging the frame to the other side and tying in the two brackets. to counter the weight of each with possible tie bar under the frame rails for extra strength. I'll be building my own tanks as well here. Gonna be cool having over 2000 mile range on this thing. Makes it nice for finding the best fuel prices and fully taking advantage of the savings.
Travis
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 08-27-2014, 11:53 PM   #10
Chassis: TC2000 RE
Engine: 8.3l Cummins
Is that static deflection? What sort of loading happens in a dynamic situation, like say a speed bump or a pavement transition at speed?
Travis
aaronsb is offline   Reply With Quote
Old 08-28-2014, 08:23 AM   #11
Rated Cap: 36
I'm not familiar with mobile home straps. Would you have a picture, or a link to the product? I haven't made much headway with this part of the project. I'm gathering ideas. Overhead hangers are still the most appealing direction to make it easier to drop the tank if the need arises.
Could you elaborate? I'm not sure I understand this. If it's worthwhile then I may do the same!
Old 09-01-2014, 02:12 PM   #12
sojourner's Avatar
Engine: DT408
That's at 2ft. drop.
Old 09-01-2014, 02:17 PM   #13
sojourner's Avatar
Engine: DT408
Here ya go:
http://mobilehomedepotmi.com/mh_cata...or-straps.html
You can see what I decided to do. I just uploaded pics this morning.
http://www.skoolie.net/forum/viewtop...6658&start=120
Trav.
Old 09-08-2014, 02:01 PM   #14
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
What is that tank out of? Any idea?
I see no real issue removing the armor, even if you do bet tboned and the tank ruptures, have you actually tried to get diesel to burn? It takes some work. Now if it was a gas bus on the other hand......
Anyone ever used saddle tanks for a tractor trailer? Not sure they'd fit under the skirting.
Ponyracer is offline   Reply With Quote
Old 09-08-2014, 03:00 PM   #15
Rated Cap: 36
I believe it was pulled from a boat. It has 3 baffles (I can tell since the metal on the top pinches downward a bit where they were welded in).
Indeed I have tried to get diesel to burn! You need a bloody hot fire already burning. Tractor's don't worry about a tank cage. Neither will I.
I have one of those as well. It's a cylindrical, aluminum tank. I think it's somewhere around 90 U.S. gallons. I was originally planning on using it, but it would end up being the lowest hanging object on the bus, aside from the differential. The rectangular tank makes much better use of the available space.
I'll probably end up using the aluminum tank as a stationary veggie oil storage tank when the time comes...
Old 09-11-2014, 07:19 PM   #16
sojourner's Avatar
Engine: DT408
I decided to make mine out of steel. Much less expensive and easier for fabrication. Even the steel tanks I've built in the past that held gasoline lasted over 20 years with no paint. As long as you keep them dry, they'll last a very long time. I agree square tanks make much more sense when conserving space. Mine will hold about 80 gallons each.
Old 09-15-2014, 05:42 PM   #17
sojourner's Avatar
Engine: DT408
Scroll to the bottom of this page to see where I'm at with the fuel tank mounts. The cross bars re clearly seen in one of the photo's.
Where to mount the propane tank lbranin Alternative Fuels | Electric, Propane, Wood & Biofuels 13 06-13-2018 07:32 PM
If you run the fuel tank dry newbusser Conversion General Discussions 4 05-01-2009 10:08 PM
wvo fuel tank on my bus mike Alternative Fuels | Electric, Propane, Wood & Biofuels 1 01-06-2009 11:16 PM
Fuel Tank Mounting dlor1 Conversion General Discussions 5 05-30-2008 09:48 PM
Propane tank mount & waste tanks installed... GoneCamping Conversion General Discussions 0 11-05-2006 10:30 PM
