Old 07-02-2014, 08:35 AM   #1
Coachwork: ward
Chassis: international
Engine: dt360a
body/chassis flex
curious about how stiff school bus body is. im sure they will flex a bit over rough roads, but how much? if using styrofoam as insulation, has anyone ever had it squeek or crack from flexing? how about flooring popping loose or self tapping screwss coming loose?
thanks
claydbal is offline   Reply With Quote
Old 07-02-2014, 10:59 AM   #2
opus's Avatar
Chassis: All-American R/E
Re: body/chassis flex
Most leave the floor floating. I have one squeak when I walk on one spot on the floor, no big deal.
Old 07-03-2014, 12:43 PM   #3
roach711's Avatar
Rated Cap: 19
Either use tongue and groove plywood or leave a slight gap at the edges of your sheets. If the edges move against each other they'll squeak like mad.
The Roach Motel
Old 07-03-2014, 01:33 PM   #4
Coachwork: ward
Engine: dt360a
thanks guys, so it does sound like some body flex is gonna happen. would this be a good reason NOT to use styrofoam for insulation? please bear with me on all the questions, only time i have ever been on a bus was in 69 and i wasnt paying attention ! lol
Old 07-03-2014, 01:34 PM   #5
opus's Avatar
Nope...use it. I used 1.5" blue board on my floor.
Old 08-10-2014, 06:58 AM   #6
Coachwork: ward
Engine: dt360a
ok, got some celotex sheets for the floor. will cover that with plywood and caulk all the way around. should insulate and help deaden sound too! am i screwing up herre! any reason to not use celotex on top of the steel flooor?
thanks again
Chassis ID imfree Cummins Drivetrain 5 12-11-2011 09:13 AM
flex rock form home hardware gbstewart Conversion General Discussions 2 03-19-2011 06:01 PM
BB on IHC chassis frank-id Classifieds | Buy, Sell, Swap 4 04-05-2008 08:32 AM
1990 Bluebird Body, GMC chassis 72 Pass. Bus. behappystupi Classifieds | Buy, Sell, Swap 12 08-20-2007 12:20 PM
Flex Watt heat tape..... Heated floors / tanks cheap & e KC10Chief Conversion General Discussions 0 12-30-2006 02:45 PM
