Old 08-01-2014, 11:26 AM   #1
Trim Coil
Hi, I'm about to start my own conversion of a 2000 IH diesel bus. I'm wondering if anyone has ever used trim coil to cover removed windows? Its cheap and fairly strong. If you have, how did you seal it to make sure it didn't leak? Robb
rube2112 is offline   Reply With Quote
Old 08-01-2014, 06:03 PM   #2
Re: Trim Coil
Welcome aboard
Got alink?
Old 08-01-2014, 08:05 PM   #3
Re: Trim Coil
I'm not sure what you mean...? A link to what? Robb
Old 08-01-2014, 09:30 PM   #4
Das Mel's Avatar
Re: Trim Coil
Typed it into google, got this stuff--> http://www.lowes.com/pd_89145-46086-...tId=3045817%20 so it must be some kinda flashing?
Thought about it, actually, yes. Would have to use a good adhesive and I would be dumb and weld it into place somehow. Because I'm weld-happy when I get my hands on an arc welder. Probably a good reason as to why I don't have one anymore.
I'm a shitty welder anyhow.
'Tace
Dog is my copilot. As I have no dog, I have no flight plan.
"If all porkchops were perfect, we wouldn't have hotdogs!" -Steven Universe
Das Mel is offline   Reply With Quote
Old 08-02-2014, 07:23 AM   #5
Re: Trim Coil
It is like flashing but much heavier....but still aluminum. Robb
Old 08-02-2014, 08:54 AM   #6
lornaschinske's Avatar
Year: 1986
Rated Cap: 89
Re: Trim Coil
Trim coil is a plastic flashing.
We used an aluminum metal flashing that we found at the Socorro ACE Hardware. It was heavy for flashing, and BARELY the right height (this is why we ended up using the window frames). We had looked into buying sheet metal to cover the window frames and suffered from sticker shock. Apparently the cost of sheet metal in Socorro was much higher than in other states. To have them cut the sheets to size doubled the price. We bought the flashing for much, much, much less $. We are frugal. And we wanted to keep the look of the windows (but not the windows) with the little awnings over them. These little eyebrow awnings have been used to shield vent covers from rain. We didn't want a smooth sided bus.
Skinning Over The Windows
Fulltime since 2006
Old 08-02-2014, 07:31 PM   #7
Re: Trim Coil
sorry, I was on my phone...thanks Gals
Old 08-03-2014, 04:07 PM   #8
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: Trim Coil
I built a skookie many years ago, if I remember correctly I used something similar, but it was the coil that the seamless gutter guys use. There was one in town that sold me the stuff. I used it to cover the entire side with one piece. Wish I could find pictures of that bus.
RUBBER TRIM,GASKETS ETC bansil Conversion General Discussions 1 05-10-2012 01:49 PM
Cove trim lighting ? Versatile Conversion General Discussions 22 01-17-2012 01:37 PM
What to use as flexible trim around cabinets/walls? Diesel Dan Conversion General Discussions 9 03-26-2010 06:38 PM
looking for headlight trim last thing i need Time Bomb Tattoo Classifieds | Buy, Sell, Swap 1 08-14-2009 10:55 AM
Pull Coil Timer Module on 5,9? Elliot Naess Cummins Drivetrain 22 03-05-2007 08:07 PM
