Old 08-13-2014, 11:09 AM   #1
120/240V household water heater installed and working
What I want is a 30/50 gallon water heater that uses 2 120v elements (say 2000wt) so I can have plenty of hot water when on 50 amp hook up
So only waters heaters I am finding are 3500/4500, + dual elements and 220/240v
So If I can find a water heater with 2 element holes can 1 thermastate be used to control 2 120 elements?
Make since ?
I really don';t want propane heater...just might have to tho'
UPDATE 9/14/14 the 240v side is awesome and works great, we had hot water in about 1/2hr...and plenty of it
RedBear...again thank you
Old 08-13-2014, 11:25 AM   #2
Re: water heater electrical re-wire question
I found a 12 gallon electric one, it's small but I think it'll be fine for dishes and 2 showers
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
So 2 of these mounted on top of each other will give us 24 gallons of 145* water, that should fill the 100 gallon tub with a body and warm water
http://www.tractorsupply.com/en/stor...-gal--capacity
keep ideas coming if you have any
We can start with one heater this next trip just for dish washing, then this winter add the 2nd one....might work
.and 3 are only about 78 inches high or set sideways under the counter or under the bus...my head hurts
Old 08-13-2014, 11:43 AM   #3
turf's Avatar
i went with a small 6 gallon 120v. i hope the small size means the recovery is fast enough that i never run out.
i should be getting my plumbing finished this weekend so hoping to find out.
Turfmobile Build Thread
Old 08-13-2014, 11:50 AM   #4
wife wants to enjoy a Friday or Saturday night bath with wine, chocolate etc
so I need lots of water......
how much cold water say 50* would it take to bring 20 gallons of 145* water to say 100* ??????????????
Old 08-13-2014, 12:17 PM   #5
turf's Avatar
have you considered a big point of use heater?
i think lorna blogged about using one and i was intrigued..... theirs was too small if i remember.
but their advantage is the more you use the better they work.
Old 08-13-2014, 01:17 PM   #6
the couple I saw that had 3 and 4 gpm were over 1k
Old 08-13-2014, 06:03 PM   #7
Remember, a 50-amp hookup does have 240 volts present, providing 12,000 watts. The issue would be when you have a 30-amp 120-volt shoreline, with only 3600 watts provided.
What about just running the two 240-volt elements at 120 volts? Heaters are resistors, and resistors don't care about under-voltage. 4500 watt element at 240 volts draws 18.75 amps. The resistor would be 12.8 ohms. At half the voltage, that resistor would pass half the current, which would be 1/2 x 1/2 = one quarter the wattage.
A water heater that gives 4500+4500 = 9000 watts at 240 volts would give 1125 + 1125 = 2250 watts connected to 120 volts. Isn't that what you are looking for? Or did you want 2000 + 2000 = 4000 watts total?
As long as the controls are the standard mechanical thermostats and not an electronic circuit board, there should be no issue at all.
Old 08-13-2014, 06:23 PM   #8
lornaschinske's Avatar
Year: 1986
Rated Cap: 89
We have a 10 gallon GE electric heater with a single 2000 watt element (110vAC). We have it on a switch to turn it on/off as needed. We turn it on 15 minutes before we need it. I can take a 15 to 20 minute very hot shower in the winter. I do not do "navy showers". We have a 2.5gpm standard house type hand held (American Standard brand). Takes about 30 minutes to recuperate. It cannot keep up with the washing machine (super large capacity top loader) but we tend to wash in cold water anyway so no big deal. For a tub, you may want to have a dedicated water heater.
Fulltime since 2006
Old 08-14-2014, 06:23 AM   #9
Redbear great info I didn't realize that the heaters would work like resistors....now I'm, like dugh
Lorna, that is good info for the timing of shower and recovery time
Old 08-14-2014, 07:04 PM   #10
Das Mel's Avatar
BWAHAHAHAHAHAHHAHAHAHAHAHAHAHAHAHAHAHAno. Got one of those. Recovery is not fast enough by a long shot. I typically turn mine on for at LEAST half an hour before I crawl into the shower. Sometimes longer, depending on if I get sucked into an article or something. With the hot water at a near trickle and cold water making up the rest of the pressure I can stretch a shower to 30 minutes. Otherwise if I want a hot shower it's a ten minute in and out and that's NOT including washing my hair.
Heck, it's an all day job to wash dishes with a heater this small (but then I use near scalding hot to wash dishes anyhow). This is why I want a dishwasher AND a little point-of-use in the kitchen with a separate heater for the shower/washing machine.
'Tace
Dog is my copilot. As I have no dog, I have no flight plan.
"If all porkchops were perfect, we wouldn't have hotdogs!" -Steven Universe
Das Mel is offline   Reply With Quote
Old 08-15-2014, 07:28 AM   #11
turf's Avatar
durn it!!
i never considered long term living in the bus while planning it. my concern was only weekend use, a 30 minutes shower would be close to exceeding my water supply. i do have a space limited short bus, my tank capacity is only about 50g with the water heater. i never installed a city water connection, just my tank.
hoping this weekend to get mine all plumbed and i'll find out. i suppose if its inadequate, another heater will be on the shopping list.
Old 08-15-2014, 08:28 AM   #12
Das Mel's Avatar
I think a ten gallon tank would do ya better. I don't know the size difference, maybe a couple of inches, maybe a foot, depending on what kinda heater you're able to locate.
'Tace
Old 08-15-2014, 09:20 AM   #13
looking to get a water heater 40 gallons, 1/2 a metric shiat ton of pvc fittings and pipe, blood work for "cumiden dose adjustment" and a 2 hr dose of magnesium...what a fun and wonderful day well damn rounded
reckon solar panels wont go up today...hell I need beer anyways so I will add that to my list also
Old 08-16-2014, 04:25 PM   #14
So I sold my soul once at lowes
Got water heater, some electrical stuff, bags of pvc fittings and 6 pcs of pvc pipe......the fun begins 2morro....we got the2 extra panels up and running....been a hot day
Chow will update this thread with WH stuff and build thread with everything else....
Time to pop a beer, light charcoal and clean bus up some
Old 08-19-2014, 08:03 AM   #15
So I had a few choices to make
and thanks to a member here, he shined the light and opened up doors
so propane was out for me
I could go 120v water heater
pros- 120v
cons- they are small and slow recovery
I could go 240v water heater
pros- faster recovery and larger
cons-need 240v and bigger
OR!!!!!!!!!!!!
I can go with both, depending on what is available power wise 30amp or 50amp
so since water heaters are just resistors
you can wire a 240v like this with only 120v
I am going this route:
I ordered a switch off amazon (locking so it will be deliberate to switch between)
I will update as progress continues
here are a few links
http://waterheatertimer.org/How-to-w...-120-Volt.html
http://waterheatertimer.org/B220C.html
Old 08-19-2014, 08:48 AM   #16
GreyEagle's Avatar
Re: water heater electrical re-wire question w/answers!!!
Camping world at one time had a "small hot water on demand" that ran off on propane. Sale priced at $149.95...
Of course this was a few years back..... Just a thought. Or a small 10 gallon water heater will provide all the hot water you need unless everyone wants to shower at the same time. Most RV's standard size water heater is only 6 gallon.
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 08-19-2014, 09:10 AM   #17
That wont fill a tub with hot water
Old 08-19-2014, 02:34 PM   #18
GreyEagle's Avatar
"Hot water on demand".....
It's heats the water until you turn it off as long as the water's running........ it's heating.
GreyEagle
Roll - On...
Old 08-19-2014, 03:07 PM   #19
Hey Bansil, I did what GE is suggesting although I added a water recirculator so the flow through the heater isn't interrupted if you happen to be taking a navy shower. The unit I chose is the Ecotemp 5 and it seems to get the job done. It does need to get its combustion air from outside the bus as well as exhaust outside--that's why I built the simple enclosure you see in the pic. Jack
Old 08-19-2014, 06:24 PM   #20
I have been very anti propane in the bus due to, things in the past I have seen and witnessed
propane is great for cooking outside (or inside if its portable and can be put back outside)
our 20foot towable we had.....scary...every time the furnace would kick on we both woke up, wondering if we would blow up ...I know it's trivial to 10 million rv-ers out there have no issues
so I know I can take a quick shower and join mama in the room as she soaks for 1/2hr and we share wine, cheese, crackers and...
mama happy= me happy (at the moment)
c-ya'll
Hydronic heater and hot water DaveLind Conversion Tutorials and How-to's 1 08-27-2014 08:39 AM
Rv Fridge and Rv water heater kenny76 Classifieds | Buy, Sell, Swap 6 06-01-2014 11:13 PM
Diesel water heater Luke Conversion General Discussions 5 02-07-2009 10:52 PM
Bus engine as a water heater Steve Conversion General Discussions 20 07-07-2006 01:53 PM
Time to buy a water heater vonslatt Conversion General Discussions 4 03-04-2005 12:01 PM
