Old 08-29-2014, 05:27 PM   #1
Chassis: International Amtram Genesis
Rated Cap: 87
Anti vandal lock rear door alarm gets stuck.. ON!
I have an 1997 international dt466 Amtram Genesis that I'm converting. I picked it up a week ago and it seems there is a problem with the loud obnoxious alarm getting stuck in the on position.
The alarm box is right beside the door and when the handle is pushed down it depresses a switch that extends into the box. On more than one occasion it's gotten stuck and I've had to listen to the alarm for an hour before it stops.
Anybody have any experience with this?
Theresa
"Great Spirits Often Encounter Violent Opposition from Mediocre Minds" -- Einstien
My Conversion Thread: viewtopic.php?f=9&t=467774
My Facebook Blog: https://www.facebook.com/sliceoflifeRv
missingTexas is offline   Reply With Quote
Old 08-29-2014, 08:46 PM   #2
Re: Anti vandal lock rear door alarm gets stuck.. ON!
Hmm, never heard of such a thing but then we don't need them in California as there are no vandals in our fair state. I'd probably just snip the final wire leading to the noise maker and call it fixed. I like to follow the KISS philosophy as much as possible . Jack
Old 08-30-2014, 09:52 AM   #3
lornaschinske's Avatar
Year: 1986
Rated Cap: 89
The switch is faulty. Might just need the contacts cleaned. The alarm is to let the driver know if one of the little beasties riding the bus has opened the back door. Somewhere else you mentioned that you wanted to keep the alarm to let you know if the door was opened. They have those. Look for a security door/window alarm (either wired or wireless) or one of those door bells that stores and some homes use to let them know when the door opens. The loud buzzing noise ours made was very irritating mostly to me. If David was up towards the front of the stripped out bus, he couldn't hear it. That's why ours was disconnected and tossed. But we can fairly easily get to our rear door. David says if we have to get out of the back end of the bus in a hurry, he would not be able to crawl out of either of the two emergency windows we kept, nor would he want to. Says he would break something (and not too sure he would fit thru the opening). He would rather crawl over the bed's headboard and out the rear emergency door. Shorter drop to the ground.
Fulltime since 2006
Old 09-04-2014, 10:26 PM   #4
Moderator
crazycal's Avatar
Chassis: 3800
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Do you have a picture?
Some locks can't be engaged with the bus running.
I'm hungry!
You Gotta Let Me Fly
Old 09-29-2014, 06:37 PM   #5
Rated Cap: 87
We just rewired it so it never goes off now
Theresa
Door alarm...buzzzzzzzzzz!!! telluriders Alternative Fuels | Electric, Propane, Wood & Biofuels 2 03-07-2012 10:16 AM
this is how I lock my door on the bus lornaschinske Conversion General Discussions 5 12-26-2010 02:20 PM
Rear Door Alarm and Ignition cut-off busdriver_phil Conversion Tutorials and How-to's 0 04-20-2010 06:53 AM
Rear door lock Kirbystud Conversion General Discussions 22 08-16-2005 03:47 AM
Door lock ideas Branden Conversion General Discussions 12 05-02-2005 06:47 PM
