09-23-2014, 08:44 AM
Coachwork: ward
Chassis: international
Engine: dt360a
rounded door
ok, most of my walls are done as is subfllor. next is the entrance door. the door(s) on my 88 ward is a typical bi-fold but is not square. the front top corner is rounded. anyone ever istalled a house or rv style door on one of these? if so, how? i was given a house door that is metal on outsides with glass in center, but the top right corner will have to be modified. all ideas welcome!
09-23-2014, 09:20 AM
Chassis: AARE
Engine: 3116 Cat 250hp
Re: rounded door
How about a picture so we can see what you have to work with?
09-23-2014, 10:46 AM
Coachwork: ward
Engine: dt360a
Re: rounded door
thanks somewhere. will try to put one up.
09-23-2014, 12:36 PM
Coachwork: ward
Engine: dt360a
Re: rounded door
09-23-2014, 12:37 PM
Coachwork: ward
Engine: dt360a
Re: rounded door
09-23-2014, 12:38 PM
Coachwork: ward
Engine: dt360a
Re: rounded door
09-23-2014, 01:40 PM
Chassis: AARE
Re: rounded door
How wide is the door, how tall is the door? How wide is the door opening at the widest part? How tall is the door opening?
Are you a welder?
09-23-2014, 01:46 PM
Re: rounded door
I don't think that door will work, looks like you would be cutting into glass.
If you had a solid door (no glass) you could cut it to fit and then add a smaller glass window later, OR... you could square off the opening and use a narrower door--the door is smaller but the opening will be about the same as what you have now with the bifold in inside the doorway.
09-23-2014, 02:16 PM
Re: rounded door
you might try the door upside down..... glass on bottom.....and trim the solid portion of the door. maybe install another window in it.
a metal wrap door isnt the easiest to work with..... something will have to cover your new cut edge.
09-23-2014, 08:49 PM
Re: rounded door
Weld the door pieces together and re hinge it.
09-24-2014, 08:26 AM
Coachwork: ward
Engine: dt360a
Re: rounded door
Are you a welder?
door and opening are 32". dont remember but the height of door is around 4" taller than opening, i am not a welder, but can weld and have access to nice welding rig mounted on a trailer.
thanks
09-24-2014, 08:28 AM
Coachwork: ward
Engine: dt360a
Re: rounded door
thats what my buddt suggested, but i was looking for less work and less welding.
09-24-2014, 08:30 AM
Coachwork: ward
Engine: dt360a
Re: rounded door
thought about that, also thought about filling window with wood or sheet metal. how would one cut the door? what tool would work best?
09-24-2014, 08:32 AM
Coachwork: ward
Engine: dt360a
Re: rounded door
are you talking about reusing the original door?
this would work lots better if i knew how to multi quote!
thanks yall.
09-24-2014, 10:54 AM
Re: rounded door
yes that's what he ment, lorna,me and several others have done this
09-25-2014, 07:53 AM
Coachwork: ward
Engine: dt360a
Re: rounded door
thanks, no problem with that much weight hanging and bouncing? what type hinges? how did yall do the lock and knob?
09-25-2014, 08:10 AM
Chassis: AARE
Re: rounded door
I think you'll find that the original front hing can be turned around so that the door opens out. I would think something like this
http://www.morehandles.co.uk/scotch-rim-lock.html could be adapted for a latch. Although a quick search only found new ones in UK. You
can find plenty of older used ones, but only have a skeleton key.
