Old 09-23-2014, 08:44 AM   #1
Coachwork: ward
Chassis: international
Engine: dt360a
rounded door
ok, most of my walls are done as is subfllor. next is the entrance door. the door(s) on my 88 ward is a typical bi-fold but is not square. the front top corner is rounded. anyone ever istalled a house or rv style door on one of these? if so, how? i was given a house door that is metal on outsides with glass in center, but the top right corner will have to be modified. all ideas welcome!
claydbal is offline   Reply With Quote
Old 09-23-2014, 09:20 AM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: rounded door
How about a picture so we can see what you have to work with?
Old 09-23-2014, 10:46 AM   #3
Coachwork: ward
Engine: dt360a
Re: rounded door
thanks somewhere. will try to put one up.
Old 09-23-2014, 12:36 PM   #4
Coachwork: ward
Engine: dt360a
Re: rounded door
Old 09-23-2014, 12:37 PM   #5
Coachwork: ward
Engine: dt360a
Re: rounded door
Old 09-23-2014, 12:38 PM   #6
Coachwork: ward
Engine: dt360a
Re: rounded door
Old 09-23-2014, 01:40 PM   #7
Chassis: AARE
Re: rounded door
How wide is the door, how tall is the door? How wide is the door opening at the widest part? How tall is the door opening?
Are you a welder?
Old 09-23-2014, 01:46 PM   #8
r_w
Re: rounded door
I don't think that door will work, looks like you would be cutting into glass.
If you had a solid door (no glass) you could cut it to fit and then add a smaller glass window later, OR... you could square off the opening and use a narrower door--the door is smaller but the opening will be about the same as what you have now with the bifold in inside the doorway.
r_w is offline   Reply With Quote
Old 09-23-2014, 02:16 PM   #9
turf's Avatar
Re: rounded door
you might try the door upside down..... glass on bottom.....and trim the solid portion of the door. maybe install another window in it.
a metal wrap door isnt the easiest to work with..... something will have to cover your new cut edge.
Turfmobile Build Thread
Old 09-23-2014, 08:49 PM   #10
Re: rounded door
Weld the door pieces together and re hinge it.
Old 09-24-2014, 08:26 AM   #11
Coachwork: ward
Engine: dt360a
Re: rounded door
Are you a welder?
door and opening are 32". dont remember but the height of door is around 4" taller than opening, i am not a welder, but can weld and have access to nice welding rig mounted on a trailer.
thanks
Old 09-24-2014, 08:28 AM   #12
Coachwork: ward
Engine: dt360a
Re: rounded door
thats what my buddt suggested, but i was looking for less work and less welding.
Old 09-24-2014, 08:30 AM   #13
Coachwork: ward
Engine: dt360a
Re: rounded door
thought about that, also thought about filling window with wood or sheet metal. how would one cut the door? what tool would work best?
Old 09-24-2014, 08:32 AM   #14
Coachwork: ward
Engine: dt360a
Re: rounded door
are you talking about reusing the original door?
this would work lots better if i knew how to multi quote!
thanks yall.
Old 09-24-2014, 10:54 AM   #15
Re: rounded door
yes that's what he ment, lorna,me and several others have done this
Old 09-25-2014, 07:53 AM   #16
Coachwork: ward
Engine: dt360a
Re: rounded door
thanks, no problem with that much weight hanging and bouncing? what type hinges? how did yall do the lock and knob?
Old 09-25-2014, 08:10 AM   #17
Chassis: AARE
Re: rounded door
I think you'll find that the original front hing can be turned around so that the door opens out. I would think something like this
http://www.morehandles.co.uk/scotch-rim-lock.html could be adapted for a latch. Although a quick search only found new ones in UK. You
can find plenty of older used ones, but only have a skeleton key.
Replacing Bus Door with Wooden Exterior Door lornaschinske Conversion Tutorials and How-to's 25 09-28-2017 02:54 PM
Replacing bus door with storm door??? leadsled01 Short-Bus Conversion Projects 13 03-18-2014 07:31 AM
Replacing the door with ext house door? jkronmiller Conversion General Discussions 2 06-10-2013 02:05 PM
Side door/ Rear door SeanF Conversion General Discussions 6 05-24-2009 11:56 AM
Anyone ever used the bifold door as camper door ? RichardRWatson Conversion General Discussions 6 07-04-2007 09:27 PM
