Old 10-06-2014, 02:25 AM   #1
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
Wheel choice
Has anyone swapped their steel 22.5's for some take off aluminum semi 24.5's? Found a guy local that has a set with new tires reasonably priced. Any issues?
Ponyracer is offline   Reply With Quote
Old 10-06-2014, 08:05 AM   #2
Chassis: B3800 Short bus
Rated Cap: 36
Re: Wheel choice
The difference will ultimately depend on what tire you put on those rims. An 11r22.5 tire is similar in size to a 24.5 low-profile tire, I believe. If you were to swap one for the other you probably won't notice much difference. If you go from an 11r22.5 to a 11r24.5 you will change the driveline gearing by a bit. You will be doing lower RPM at the same speed, but won't have as much power. Depending on the size of the engine this may not even be noticeable. Anyone else have some input?
Old 10-06-2014, 08:08 AM   #3
Rated Cap: 36
Re: Wheel choice
Oh, and I think 22.5 is a more common rim size than 24.5, thus 22.5 tires will be cheaper.
Old 10-06-2014, 09:11 AM   #4
r_w
Re: Wheel choice
Look at tire prices (I haven't, don't have a clue how they compare). You have mountain gears, so the change in gearing is good for you. I would be more worried about the change in braking power. Measure your wheel wells, most look like there would be room, but you never know.
I would consider it, too.
r_w is offline   Reply With Quote
Old 10-06-2014, 10:58 AM   #5
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
Re: Wheel choice
I can def stand to kill some gear, the best choice is a tranny swap so I can keep my mtn gears for pulling etc, and that will happen eventually.
10r=40"=55 mph at 2500rpm
12r=42.6"=59 mph at 2500rpm
Just need to see if I can fit the extra inches.
Since I need tires anyway and would like to swap to nice alcoas this might be a good time. We'll see what tires cost for replacement etc. The good thing is, there are plenty of semi's around here selling wheels/tires from wrecked trucks.
Old 10-06-2014, 12:00 PM   #6
Re: Wheel choice
you have a 545 auto right?
If so you will kill it if you increase dia diameter by a couple inches, if you don't have 2200/2400 input rpm into trans it will slip ALL the time
Old 10-07-2014, 10:44 AM   #7
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
Re: Wheel choice
Hmmmmmm good catch. That blows, didn't think about that. So on the 545 you have to SPIN it to get it to "lock up". That ought to help fuel mileage lol. Looks like the tranny swap is working its way to the top of the list.
Old 10-07-2014, 11:10 AM   #8
Re: Wheel choice
by lock up, it means max fluid pressure on bands and even then it's making heat because of the convertor
Old 10-07-2014, 12:40 PM   #9
r_w
Re: Wheel choice
You can still do it as long as you keep engine RPM up, so yeah. If your bus tops out at 55 and you want to always drive 60, no problem. If you have to drive X mph and that used to be 2200 but now is 2000, you have a problem.
Old 10-07-2014, 12:47 PM   #10
Re: Wheel choice
For me
3rd gear 2200/2400 rpm is 45 to 50 dependent on grade
4th gear on flat ground 2200 is 60/65 (don't remember, worried about other idiots on I85 and I40 ) and 2400 is 72 mph
I know it seems strange with such a small jump in rpm's makes a big difference
I drive 95% in 3rd gear and 50-ish, I'm getting older so I am practicing
Old 10-07-2014, 01:33 PM   #11
r_w
Re: Wheel choice
That is kind of proof it is slipping, now isn't it
Old 10-08-2014, 06:45 AM   #12
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
Re: Wheel choice
Any way to tell if you have hub or stud pilot wheels? I have pics of the wheels, they have "lips" on the hub so the wheel rests on them to center but they also have raised sections at the lug holes that looks like it's there for a tapered lug.
Old 10-08-2014, 08:29 AM   #13
Re: Wheel choice
I think I read somewhere if you go from steel to aluminum rims you have to change studs due to aluminum having thicker lips, something to keep in mind
Old 10-08-2014, 10:47 AM   #14
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
Re: Wheel choice
Ya I believe its the rear.
Window choice pros and cons bapos Conversion General Discussions 19 07-24-2012 11:53 AM
366 BB Carb Choice Gyva GM | Chevrolet Drivetrain 7 09-19-2010 08:57 AM
Narrowed Down my Bus Choice - Need advice zamfir Conversion General Discussions 3 06-30-2009 11:50 PM
Bus Choice Vern1 Conversion General Discussions 5 06-13-2009 12:04 PM
It Seems a TC 2000 is a good choice? britishroamer Classifieds | Buy, Sell, Swap 4 11-28-2007 06:36 AM
