Old 10-28-2014, 06:17 PM   #1
Coachwork: GMC
Chassis: Vandura
Engine: 3500
weight distribution during conversion
Hey all! I've been visiting this site for the past several months as I convert my shortest of the short buses (1990 GMC Vandura 3500). Thanks all for the great wealth of information! After months of lurking, I've finally run across a conversion question that I haven't been able to answer though searches.
I designed Bessie's build with an even weight distribution in mind, but I'm converting the bus in stages and inadvertently designed it so that the weighted portions of the right side of the bus won't be completed until much later down the road when I install the water holding tanks and fridge. There's a 300-400lb discrepancy between the two sides of the bus and it will be that way for several months to a year. Do I need to be concerned about this amount of weight, or is it a nominal difference? Thanks!
SkoolieSound is offline   Reply With Quote
Old 10-29-2014, 04:22 AM   #2
Re: weight distribution during conversion
I wouldn't worry, that is only 2 people? no biggy
Old 10-29-2014, 07:17 AM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Those were my thoughts, exactly.
Old 11-03-2014, 05:52 PM   #4
Do pay attention to the front-to-rear balance as well as right-to-left. While most Skoolie conversion interiors probably weigh less than a high school football team, you will note that the carrying capacity of a dually rear axle is more than that of the steer axle. You want to have the weight properly distributed, and not all up front or on one tire.
Small planes (and large?) usually have a fixed starting point including installed equipment. The fuel, passengers and baggage for each flight can be added to that at each "station," and calculated so the plane flies neither overloaded, nose-heavy nor tail-heavy. A fixed starting point for a Skoolie who cares could be having the bus weight at each wheel measured after the seats are out, and then adjusting for each item added to the build.
Is there a Charger/inverter/distribution combo? rex_1_mn Conversion General Discussions 6 12-09-2012 01:05 PM
30 amp Portable Distribution Box chev49 Electrical, Charging and Solar 1 06-10-2012 01:02 PM
Simple distribution box Dain Alternative Fuels | Electric, Propane, Wood & Biofuels 1 06-10-2012 03:13 AM
weight of WVO nyrockingchairs Alternative Fuels | Electric, Propane, Wood & Biofuels 1 06-02-2007 03:55 PM
Bus Weight phillip266 Everything Else | General Skoolie Discussions 3 05-26-2005 09:58 AM
