Old 11-13-2014, 07:46 PM   #1
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
the front door latch
My bus has a manual door opener. There's a latch that drops when the door is closed. It looks as though it would be useful to rig some way of lifting that latch when entry is desired.
How have others managed? Im sure a handle on the outside of the door would allow me to close and lock it from the outside.
Zephod_beeblebrox2 is offline   Reply With Quote
Old 11-16-2014, 03:29 PM   #2
timbrass's Avatar
Location: Henley-on-Thames, United Kingdom of Great Britain and Northern Ireland
Rated Cap: 29
Re: the front door latch
I am in same position. When the handle goes back to the closed position the latch clicks behind a small plate. I'm going to cut a 2cm piece of tube to hold the latch up - the door would stilt be locked. I still need a way to pull the bar towards the front and was going to drill a hole into the engine compartment. I'm also going to fit a Yale lock on back door but am going to put a bed across the back so would only use as a door in emergency.
On the manual door question I was wondering if I could rig up a remote control unit to pull the bar back.
My Build site is https://schoolbusconversion.net
timbrass is offline   Reply With Quote
Old 11-17-2014, 11:12 AM   #3
Year: 1994
Engine: 466dt
Rated Cap: 59
I noticed I can simply slam the front door to lock it. I wonder whether it would be possible to feed bowden cable through a sleeve akin to bicycle brake cables and to attach that to a lock so that by "locking" the lock, the latch can be opened.
Old 11-20-2014, 09:51 PM   #4
Chassis: B3800 Short bus
Rated Cap: 36
I'm not sure about Bluebirds and Carpenter bodies, but my Thomas conventional had a latch to the right of the door, under the front windshield that would operate that latch mechanism with a cable.
Old 11-21-2014, 02:37 PM   #5
Not sure excatly what you are looking at but I used a Solenoid on one of my sailboats to unlach the door with a hidden switch . I buy things of that nature from several places but this one has assorted items that may work .
Code:
http://www.sciplus.com/s/c_7/sf_65
. look around the site they have powered seat motors ,actuators and dc motors
Code:
http://www.sciplus.com/s/c_15/sf_138
. So far in the last 6 years have been satified with my purchases from them .
Progress doesn't come from early risers — progress is made by lazy men looking for easier ways to do things.
mad_wolf is offline   Reply With Quote
Old 11-22-2014, 11:02 AM   #6
Chassis: All American Rear Engine
Engine: C-8.3-300 Cummins MD3060
Rated Cap: 40 Prisoners
In the mid-Eighties Ford on their pickups had a hood release handle with a key lock in the handle which prevented
the hood from being opened without first inserting the key and unlocking the handle. You could use the handle and
cable to achieve your desired results. When wrenching on one of these we would pull the handle out partially and
re-lock the handle which kept it in the unlocked position for ease of service as well.
Dragonpop is offline   Reply With Quote
Replacing the front door Zephod_beeblebrox2 Conversion General Discussions 13 09-14-2022 11:19 AM
Deadbolt on front door? lornaschinske Conversion General Discussions 31 08-25-2014 10:35 PM
side / rear door latch wanted snonbos Classifieds | Buy, Sell, Swap 3 05-14-2010 09:44 AM
NEED front door hinges millertyme Classifieds | Buy, Sell, Swap 1 09-20-2009 11:43 AM
Bus front door question soused moose Conversion General Discussions 3 04-22-2004 08:32 PM
