View Poll Results: Use an Electric Door Opener or not.
Never 0 0%
Under certain conditions 0 0%
No 1 25.00%
Yes 2 50.00%
Are you crazy? (J/K) 1 25.00%
Voters: 4. You may not vote on this poll
Old 03-30-2013, 08:34 PM   #1
91 Bus Guy's Avatar
Chassis: Chevy G30
Engine: 5.7 V8 TBI GM
Rated Cap: 10
Send a message via MSN to 91 Bus Guy
I need an Electric Door opener for my Bus.
sorry
91 BG
91 Bus Guy is offline   Reply With Quote
Old 03-30-2013, 10:37 PM   #2
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Re: I need an Electric Door opener for my Bus.
I use a linear accuator like this. http://www.ebay.com/itm/Heavy-Duty-10-L ... 073wt_1257
Its mounted it over the door + rigged up to push on the arm between the 2 doors.
Old 03-31-2013, 01:12 AM   #3
91 Bus Guy's Avatar
Chassis: Chevy G30
Rated Cap: 10
OK
91 BG
Old 04-02-2013, 09:04 PM   #4
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Sorry for the delay. I stared at how to make things work for hours-pivots-linkage-all kinks of weird ideas. The the K.I.S.S. principal kicked in. 10 hours of head scratching + 10 minutes to make it.
How things work in my bus (+ I presume most others) The mechanical lever the driver swings pushes a bar to the front door-and another up top goes from the front door to the rear door. The accuator pulls to close-pushes to open mounted to that arm.
The front mount is just 2 small triangles ( in my case roll bar gussets) with a removable hitch pin in case of emergency-or the times you just want to open + close the door quick + often. (the cold weekend we camp out.)
The rear is just a piece of square tubing. You'll notice in the pic from the other post there is a another chunk of metal welded in as a brace-that accuator has alot of power.
Here it is in action.
http://youtu.be/6JSdMjyjxIw
Old 04-02-2013, 10:13 PM   #5
91 Bus Guy's Avatar
Chassis: Chevy G30
Rated Cap: 10
OK2
91 BG
Old 04-03-2013, 05:25 AM   #6
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
The motor end has a lug on it-it just goes into the piece of square tubing. THe gold bolt attaches it-2 bolts vertical attach it to the bus.
You'll notice there is a strap along side of the motor-I had the stock (tiny) screws that hold the acuator to the electric motor blow out one time-this just strengthen things. I presume its made more for its load to push things-to shut the door on mine it pulls.
Old 04-02-2014, 08:19 PM   #7
91 Bus Guy's Avatar
Chassis: Chevy G30
Rated Cap: 10
Sorry
91 BG
Old 04-02-2014, 09:23 PM   #8
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Boy-only took 1 year--exactly! That a BIG accuator.
Replacing Bus Door with Wooden Exterior Door lornaschinske Conversion Tutorials and How-to's 25 09-28-2017 02:54 PM
Electric key switch for power bus door roach711 Conversion General Discussions 7 01-02-2012 07:08 PM
Running electric and door set up butcher_boy Conversion General Discussions 3 12-29-2011 11:27 AM
Electric door lock somewhereinusa Conversion General Discussions 6 10-27-2011 08:19 AM
Electric back door lock...who posted the pics? Abbott Conversion General Discussions 4 08-11-2008 09:50 PM
