Old 05-15-2010, 04:42 PM   #1
Moderator
crazycal's Avatar
Chassis: 3800
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Re: 28 die as bus touches high-voltage wire
I don't understand. I thought that if a power line came down and you were still in the car, you were OK until the power was shut off. Is that wrong?
I'm hungry!
You Gotta Let Me Fly
Old 05-16-2010, 08:30 AM   #2
That is the best advice. Electricity travels on the surface of conductors, so the metal passenger compartment acts as a "Faraday Cage" to pass any electrical current around the passengers. Edit: That is also why you stay in a car during a thunderstorm, rather than get outside.
Rubber tires are only insulators at low voltages. Rubber is full of carbon, and carbon is a conductor, but not a good one like steel or copper. When a high-voltage line falls on a vehicle, I have heard of cases where the tires blow out from the current passing through them. The Faraday Cage can still protect the occupants until the power is shut off, as long as they do not freak out and try to exit the cage.
I don't know what happened in India. Perhaps the passengers had their arms out the windows, and touched the broken wires or the bus skin. The others might have been packed shoulder-to-shoulder, or tried to rescue the others and were shocked by the contact.
Rule number one is: Do not try to rescue someone who is actively being electrocuted until the power is cut off.
Old 05-16-2010, 08:34 AM   #3
AHA! CNN Reporting: . . . As passengers began stepping down while holding the steel railings, the current passed to the ground to cause a jolting electric shock in the bus, Khare said.
Old 05-16-2010, 09:40 AM   #4
Moderator
crazycal's Avatar
Chassis: 3800
So it took 28 people to teach the 29th that getting off was a bad idea.
I'm hungry!
Old 05-18-2010, 06:22 PM   #5
Stuff's Avatar
*holds a sign* here's yar sign
Old 06-15-2010, 07:43 PM   #6
Moderator
crazycal's Avatar
Chassis: 3800
women/goats/chickens/etc go up on the roof.
Where they belong!
I wrote that? I crack myself up sometimes. I kind of a witty guy.
I'm hungry!
Finishing Touches - dark wood?? uswiththebus Conversion General Discussions 2 02-16-2014 08:25 PM
main cab wire harness???? Help please Dub C Alternative Fuels | Electric, Propane, Wood & Biofuels 10 10-17-2012 12:39 PM
Cautions: High Voltage Low Voltage lornaschinske Conversion Tutorials and How-to's 8 02-12-2012 02:17 AM
Voltage regulator help!! Shortbus Nixon Short-Bus Conversion Projects 0 11-19-2010 05:55 PM
Multi Voltage Alternator / Generator / Welder Papabear Conversion General Discussions 1 09-21-2009 01:20 PM
