Old 11-27-2011, 09:34 AM   #1
Chassis: Thomas
Engine: bosch
Rated Cap: 20
what kind of tank?
6 months ago, we bought our first bus, a 1989 Thomas built International. We converted the inside, and are working on our veggie conversion. We have an oil source, and I think all the parts, except a clean tank. Not sure if we should get an unleaded tank or diesel tank. the diesel has a return line hole, so I think that will be easier. Any advice?
Also, the heat worked when we bought it, but I can't seem to get it working now. No owner's manual, of coarse. Any suggestions?
BootsBus2011 is offline   Reply With Quote
Old 11-29-2011, 03:38 PM   #2
Diesel Dan's Avatar
Engine: DT466/AT545
Re: what kind of tank?
I went to a boat scrap yard and got a 125 gallon aluminum diesel tank for my WVO conversion for $200. I suggest you stick to either aluminum or plastic due to problems with the oil polymerizing in reaction to steel combined with heat. And yes, the built-in return line is a bonus on the diesel tanks. You might also consider finding a used saddle tank off an 18-wheeler or other large truck, especially if it comes with the mounting straps. That would be the easiest to deal with I think.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 11-29-2011, 07:56 PM   #3
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Plastic. 2nd choice-plastic. Aluminum if you get it given to you. I found a used plastic tank out of a boat for about $200.(Paid a bit more than I shoulda--but it was the exact size I needed.)
Old 12-04-2011, 10:32 PM   #4
Chassis: Thomas
Engine: bosch
Rated Cap: 20
We found the tank!! A 50 gallon aluminum diesel tank with mounting brackets fresh off a semi. Now, we just need to install it and connect the switch valve, the lines to the filter, the lines to and from the engine, heat element on all lines, and our 130 gallon dirty oil tank. Woohoo!!
What kind of mileage do you get? Steve Conversion General Discussions 193 02-02-2024 08:37 PM
what kind of bus dieselman69 Conversion General Discussions 4 11-15-2008 01:53 PM
No! Not that kind of ga...(BOOOM!) Elliot Naess Everything Else | General Skoolie Discussions 0 10-17-2008 12:38 PM
Striping... and not the fun kind... Fifer Conversion General Discussions 1 03-24-2008 03:37 PM
1 of a kind 1 of a kind Skoolie Conversion Projects 2 09-09-2007 10:11 PM
