Old 05-01-2012, 10:34 AM   #1
Engine: B700 7.3L
Safest way to strap tanks
Hey we have 55 gal barrels to strap under our bus, what is the safest, most secure way to do this??? Rachett straps, or metal strapping, what is the max weight, and/or what kind of metal should we be looking for, or where to find good scrap metal to use. Thanks
Harmony and Xavier
harmony427 is offline   Reply With Quote
Old 05-03-2012, 10:49 AM   #2
Re: Safest way to strap tanks
while i wouldnt use a strap for a 55 gallon drum, if i were going to do so, i would use metal straps for gas tanks - something like wide banding material... and put a strip of rubber between the strap and the tank so that the strap wont cut in to the tank..
I would build a angle iron frame work, and strap the tank to its floor...
Old 05-16-2012, 09:22 AM   #3
the problem with old bed frames is the exact same problem with car springs... ya can weld them, but the weld will break...
bolted bed frame rails are fine, but never welded.
btw. same steel as in old car bumper supports...
Old 09-17-2012, 11:36 PM   #4
Year: 90
Chassis: Alister
Engine: Cummings
I used 3" wide ratchet straps I got for 17$ at six states truck supply in Portland Oregon for my 55 gal drum and have driven over 10k miles with no trouble. The trick for me was to mount it up against the frame so if I stop or go it hits the metal frame of my bus. If you aren't so lucky with placement I would to cut a notch in your drum wide enough for the ratchet strap and brace it back to front. Make sure your notch is smooth so it doesn't cut yo strizzap.
Www.lovebuscommunity.com
j12784 is offline   Reply With Quote
Holding tanks GreyEagle Plumbing, Water and Waste 19 06-22-2019 07:42 AM
Looking at some tanks rex_1_mn Plumbing, Water and Waste 3 09-26-2012 04:41 AM
Tanks a lot Jarlaxle Conversion General Discussions 2 09-03-2010 03:36 PM
lp tanks colliervilledave Classifieds | Buy, Sell, Swap 4 05-16-2009 02:07 AM
Two tanks v. one? Branden Conversion General Discussions 5 06-03-2005 11:32 PM
