Old 05-15-2012, 11:26 AM   #1
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Re: 1992 Bluebird w/ Cummings engine runs on used tranny oil
Running tranny fluid is the same as running waste motor oil (WMO)-only a bit cleaner. "Blenders" as the folks who run WMO are called, usually mix in some other things like cenate booster-diesel clean-etc. I know it can be done-cant give more details though-i'm a veggie oil guy.
Old 05-15-2012, 11:39 AM   #2
a person i know from alabama bought a used 5.9 like a 1999 or so model year that the po had been running veggie oil in it... only to find out a month later that it needed an injection pump.
some people run a mix of oil and diesel also.
from other diesel bbs's i have surmised that just using diesel is probably best...
now... all the wvo people will comment..
i would like to hear from people using wvo who have racked up like 500,000 mi on it..and had the same diesel truck or bus with similar mileage to compare maint costs...
Old 05-15-2012, 07:37 PM   #3
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
I've never tried to talk anyone into veggie-but have talked many out of it.
Go to www.greasecar.com and look up forum posts from Brian Miller. He has over 350k on 1 7.3 on wvo-over 200k on another. (Its why I picked what I drive now.) Also a genarator to power his house-and a furnace on veggie.
Making your own fuel is like building a bus-makes little sense to most others-lots of time spent learning-sometimes the hard way-lots of figuring things out yourself-lots of trips to Home Depot-and big satisfaction with the finished product.
Me? Tried it as an experiment on a 92 VW Jetta-now 120k miles on it still working fine. 10k on the bus-3 years on a furnace in the garage.
Old 05-16-2012, 09:08 AM   #4
a few people add engine or trans oil to their diesel.. it isnt reccomended for a 2 stroke detroit..
Old 05-16-2012, 04:01 PM   #5
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
uknow we use two run 2qts of tranny in 500 gals of diesel the winter months up north keeping it from gelling up..
keith is offline   Reply With Quote
Old 05-16-2012, 08:54 PM   #6
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
http://biodiesel.infopop.cc/eve/forums/ ... 6947009143
Dunno if I would use it as the last word--but its a place to start looking around.
Old 09-16-2012, 07:54 PM   #7
Coachwork: Crown by Carpenter
Chassis: Ford B-800
Engine: 5.9L Cummins
Rated Cap: 55
A friend of mine has been trying to get used transmission fluid from transmission shops, since it's less of a commodity than restaurant grease seems to be (around here, recyclers PAY restaurants for grease, anywhere up to $0.40/gal). Even at a strictly transmission shop (where large volumes can be found), the fluid was contaminated with brake fluid, engine oil, etc and that (when heated together) causes severe performance problems, from what my friend said. He is trying to filter it using a centrifuge, but seems not so practical for a bus on-the-go.
tomas_maly is offline   Reply With Quote
Old 11-18-2012, 04:04 PM   #8
Coachwork: Corbeil
I was wondering about this myself. I would think, which means I really don'y know what I'm talking about, that tranny oil and engine oil has the raod tax included when it was originally purchased. If this is true, then it should be legit to use as a fuel would it not?
If you get dipped and you have black diesel, do you get fined the same way as if you have dyed diesel or WVO?
TourTech is offline   Reply With Quote
1992 BlueBird in Missouri Accordion Classifieds | Buy, Sell, Swap 2 10-31-2012 04:42 PM
Top RPM for a cummings 5.9 24 valve engine funbus63 Cummins Drivetrain 5 12-19-2010 09:24 PM
short-bus advice on engine, tranny etc Ray_WA Short-Bus Conversion Projects 23 02-27-2009 08:53 PM
Our 1992 B-700 Bluebird project wtom24 Skoolie Conversion Projects 6 11-08-2007 02:44 PM
1986 IHC 6.9L v8 non turbo Diesel engine tranny combo 4sale andybus9 Classifieds | Buy, Sell, Swap 0 05-14-2006 11:10 AM
