Old 04-11-2010, 12:42 AM   #1
cheezypsnookle's Avatar
Coachwork: Bluebird tc2000
Chassis: 3401-3502 ???
Engine: cummins 5.9
plastic tank question
would a fresh water tank work as a vegtank ?
the plastic is thinish
and heat will only make that worse
cheezypsnookle is offline   Reply With Quote
Old 04-11-2010, 01:01 PM   #2
lornaschinske's Avatar
Year: 1986
Rated Cap: 89
Re: plastic tank question
I wouldn't risk one of the poly tanks (the translucent white ones). Ever leave one out in the hot summer sun?
Fulltime since 2006
Old 04-11-2010, 08:54 PM   #3
Engine: cummins 5.9
yeah thats what i thought also ,but i can get them cheaply
Old 04-11-2010, 11:32 PM   #4
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Remember-you dont have to go crazy keeping you tank heated-it only has to be warm enuff to flow to your filter-THERE you can crank the heat to it.
Old 04-12-2010, 11:24 AM   #5
Stuff's Avatar
A plastic 55 gal would be definitely durable enough!
Old 04-12-2010, 09:17 PM   #6
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
I've started on my WVO conversion this. My plan is to mount everything underneath-and have both solinoids-veg filter + remote fuel filter mounted on a slide out-so i dont have to try to jam anything under the hood-or lie on my back to change a filter.
A 52 gallon boat tank
The straps are galvanized 14 gauge strips 2" wide-its thin enough to bend in a vice with some hammering. The rubber is from HD-"shower floor underlay" sold off the roll.
Support is from 6 pieces of 3/8ths threaded rod. I went to a bolt specialty place and got a good grade 5 section. Holes drilled into the floor frame crossbracing.
More pics to comes as progress..progresses.
Old 05-12-2010, 09:02 PM   #7
newtoskool's Avatar
any updates?
newtoskool is offline   Reply With Quote
Old 05-13-2010, 05:12 AM   #8
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
viewtopic.php?f=16&t=5937
Its been road tested. I had a small leak from the plate going into the fuel tank (I had too much pitch forward-wvo was always on the plate)-gonna reseal it tonite. Other than that all is well.
Black Tank question SitkaConvert Conversion General Discussions 4 09-23-2014 03:51 PM
Water tank guesstimate and plumbing question tomas_maly Plumbing, Water and Waste 26 11-06-2012 09:14 PM
Black tank question??? dirtygoat Plumbing, Water and Waste 5 10-27-2011 12:59 PM
another propane tank question delbertinie Conversion General Discussions 11 09-12-2007 12:45 PM
Propane tank question! PRyberg Classifieds | Buy, Sell, Swap 11 01-18-2005 06:10 PM
