Old 05-12-2010, 08:45 PM   #1
newtoskool's Avatar
3 stage WVO in bus
How realalistic is it to be able to have a 3 stage/ tank system in a bus? When I say 3 stage I mena raw used oil, Filtered oil, tank for using. Will I be able to do the whole process in the bus or will I need a shop to do the work filtering the oil?
newtoskool is offline   Reply With Quote
Old 05-13-2010, 01:47 PM   #2
lapeer20m's Avatar
Re: 3 stage WVO in bus
doing it all on board is the most logical method.
move oil at high speed from grease dumpster into "dirty" oil tank
heat dirty oil
pump with high pressure low volume pump into the "clean" oil tank.
That is the system i prefer to use.
Old 05-13-2010, 08:52 PM   #3
newtoskool's Avatar
ya i was thinkin have the old used oil up over the clean oil. run a line with a filter and pump from the dirty to the clean oil tank. As the oil passes thru the filter/s it will fill the clean tank. the clean tank will essentially just be another storage tank as i will have some sort of system to draw oil from the clean tank to the "fuel" tank. Whats a good use for the wasted durty oil?
Three Stage Battery Chargers crazycal Electrical, Charging and Solar 0 05-16-2010 09:57 AM
Decent, cheap, automatic 2-stage charger josetann Electrical, Charging and Solar 2 07-21-2009 03:37 AM
requirements for a stage bus? TikiBus Everything Else | General Skoolie Discussions 1 12-08-2008 02:01 PM
Monkey Bus-iness got 1st stage painted today... nyrockingchairs Skoolie Conversion Projects 5 06-05-2007 12:29 PM
