Closed Thread
Old 04-18-2011, 01:32 PM   #1
'46 Chevy Shorty
Hello All --- Well, I finally got a look at this darlin' up close & personal. And I am very happy to say, it is in better shape than I had even hoped for! Sure, , it needs a ton (or in this case...a ton & a half, since that's the chassis it's on) of work, but it is a great little starter platform. Very little rust with only a couple of small replacement patches needed next to the front fenders and one "wrinkle" next to the entry door. The latex house paint is peeling, but that's coming off anyway. Mechanically it is surprisingly solid. Recent brake rebuild, working parking brake (a big deal, actually) and a snazzy new custom, aluminum radiator. The 1980's vintage 350 motor runs great but will be (hopefully) replaced with a Cummins 4BTAA. The original 4-speed tranny sounds good but hoping for an Allison auto with 5 speeds. And speaking of speed, as with nearly all these old hill climbers and house movers, tops is maybe 55. If the Allison gears won't bring that up enough, then a new rearend will be in order.
And BTW...I am in the process of looking for a reliable transport service to get it from Utah to Houston, so if anyone here has any recommendations, experience, horror stories...please...pass them along. That business is so BS intensive that it's as scary as it is annoying, so a personal reference will go a long ways with me.
I have just started laying out the interior as well as a couple of exterior mods. As you can see in the pix, it has already undergone some degree of conversion so I have a bit of a head-start there. Not much space to work with, but hey, not that much to build out either! If I can figure out how to do the drawings in Google Sketch, I'll post as I go.
Grill is straight & ready for chrome. Even has near perfect stainless side trim on the hood.
A new door is definitely in order (damn Hippies). And that smoke stack is indeed hooked to a wood stove.
The shortest body Wayne ever made...21 feet bumper-to-bumper.
A study in the "KISS" principal. And yep...that handle on the left rolls down the driver's window! Cool.
Just a couple of benches and some carpet to tear out.
At 7-1/2' across inside, it's almost as wide as it is long.
I figure this project will easily take a year or two, but I'd like to get the engine/tranny worked out asap. If anyone has experience with 4BT swaps, I'll buy the coffee to chat.
Many, many thanks to the Skoolie Board Builders and all the wonderful folks here who make this site so great. You all played a big part in my decision to go ahead with this little fantasy. And as most of you already know...Dreams are far more important than reality.
More (much more) to follow. Onward!
Tango is offline
Old 04-18-2011, 02:23 PM   #2
Engine: DTA360
Rated Cap: 16
Re: '46 Chevy Shorty
I like it...
Good luck with transport...
dirtygoat is offline
Old 04-18-2011, 07:45 PM   #3
Diesel Dan's Avatar
Engine: DT466/AT545
What a cool old bus! Great project you got there.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Diesel Dan is offline
Old 04-18-2011, 09:46 PM   #4
RevBill's Avatar
Coachwork: - Still Shopping -
Chassis: - Going Medium/Large -
Engine: - DT466 Desired -
.. awesome .. awesome .. awesome .. looking forward to following your conversion/upgrade .. what a great find to build on ..
Chance favors the prepared mind. - L Pasteur
Luck is the residue of good planning. - B. Rickey
Travel is fatal to prejudice, bigotry, and narrow-mindedness ... - M. Twain
RevBill is offline
Old 04-19-2011, 06:00 AM   #5
Seeria's Avatar
Has to be the coolest looking classic shorty I've seen yet.
Don't know any transport but you might try calling the local (where you bought it) bus and fleet shops and sales lots and ask them for a few numbers.
Seeria is offline
Old 04-19-2011, 10:37 AM   #6
opus's Avatar
Chassis: All-American R/E
Awww...dude, find the original engine for that thing!
opus is offline
Old 04-19-2011, 04:51 PM   #7
Coachwork: ?
Chassis: chevrolet
Engine: 292L 6
Rated Cap: ?
Keep the engine you have! The original 235 oil dipper's these came with are slow, have little power, and are a royal pain to maintain. The 4 speed trany has to bo double clutched in every gear(it is an old truck). On the bright side mine has a disk brake on the shaft; it's nice to have an emergency brake that really works. Stovebolt forums are good information sites.
Good luck, looks like a really cool bus
oldschool
oldschool is offline
Old 04-20-2011, 10:43 AM   #8
Thanks for the support and feed back. And yeah, it does seem to have a bit of a "Brinks Truck" look around the windshield, doesn't it. But probably one that would be more attractive to Bonnie & Clyde than any present day outlaws. The entry door is a home made wooden affair that is about to come apart and is the first thing that will get replaced. Mostly for security reasons. The floor plan will include a small living area in the front with a minimal kitchen (cook-top, sink, fridge), a bed and a toilet/shower combo. The rear will be left pretty much open to serve as a mobile shop and storage area. An almost full-length roof rack is also being considered.
I used to have a 21' Toyota-based Odyssey camper that was about the same interior size and realized that the shower took up a lot of otherwise valuable space when not being used, so for this unit, I plan to put it to work. I have designed a shower door that when closed has drawers and shelving that will occupy all that open space inside the shower and swings out to form a privacy door when in the open position. Frankly, I'm surprised that I haven't seen such an arrangement before since coach makers work so hard at using every other square inch.
As for power, the Chevy is a great running engine, but barely gets 8 mpg. I need something that will take me further on less fuel. The stock 6 just doesn't have the grunt to pull much of a load and really isn't all that great on fuel either. I started out looking at the 5-cylinder Mercedes diesels in the new Sprinter vans that get about 22, but a little homework exposed a lot of problems with such a transplant. They require a couple of dozen computers and even more sensors all working in harmony to pull it off and are a nightmare to try and reprogram to any other vehicle. Turns out, the tried & true Cummins 4B series are about as bullet-proof as engines get and can be tuned not only to pull a house with torque to spare, but get 24 to 30 mpg doing it with just 2 wires to connect and not a single computer anywhere. Funny thing is, with a little tweaking, the same little engine can be set up to produce anything from 80 to as much as 600 horsepower. I'm planning on the 130 hp tune. And because there are so many of them around, parts and service are easily available just about anywhere. The only electronics issues involved may be those associated with mating it to a 5 or 6 speed Allison automatic, but at least there are kits available that make it doable. The combination should be one that will provide plenty of pull, outstanding mileage, long life and ease of maintenance. At least, that's what I'm shooting for.
I'm working out some floor plans and will post some sketches as soon as I am close to something workable.
Tango is offline
Old 04-20-2011, 11:02 AM   #9
opus's Avatar
I was thinking the original engine just for the coolness factor. Sure, it wont get the mileage but I wasnt sure how much traveling you would do. How about a 5.9 or would it be too long? You could buy a whole wrecked truck and take the whole drivetrain.
You'll probably have $6k into the Cummins job, I would guess. Lots of power options for you.
opus is offline
Old 04-20-2011, 01:37 PM   #10
lornaschinske's Avatar
Year: 1986
Rated Cap: 89
There is a similar looking bus not far from here. Looks like it was converted at one time. It's at a Bee Chama Honey farm in Lemitar. I keep meaning to get a pic as we barrel down the interstate. Perhaps I can get one today when we drive up (yet again) to Albuquerque.
Fulltime since 2006
lornaschinske is offline
Old 04-21-2011, 05:01 PM   #11
Funny you should ask. The "Name Thing" has been a topic of discussion and it has evolved into a peculiar moniker. I was leaning towards a name & paint scheme that gives the impression of an old, art deco period tour bus. My business in Houston has long gone by a name with the initials "H-T". And being a pilot and ex-Navy, I often use the military phonetic for those letters which works out to "Hotel Tango". A name I like the sound of and have always wanted to use on something anyway. But then, I got stuck on the old line..."It seemed like a good idea at the time". Then I realized that the initials for that line spell out..."Isla Giatt". So most likely, the old girl will have "Hotel Tango de Isla Giatt Scenic Tours" painted down the side in a hard core deco typeface. Hey...if that doesn't throw people for a loop, nothing will.
A good Cuban cigar and a Mojito will always be on board to make the image complete.
Tango is offline
Old 04-23-2011, 01:48 PM   #12
What with my current workload, I have decided to wait until mid-June before bringing the baby home. Did find a transporter that was recommended by another bus owner he hauled for. Choice Carrier Corp. Will let you all know how it goes. Meanwhile, back to doodling floorplans & paint schemes.
Tango is offline
Old 04-23-2011, 03:31 PM   #13
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Hey Tango,
Going to be in Pasadena Monday, then on to Richie Bros in Humble going back to Lima, OH
Dick
somewhereinusa is offline
Old 04-24-2011, 10:03 AM   #14
Hey Somewhere --- Welcome to Texas! I have booked the move for my '46 Chevy bus with Steve at CCC. Can't do it until mid-June though, too much work going on here and bouncing in & out of town. Making me crazy not having it here to work on. Bit like the first half of your Bird story. Man, that is one sweet Bird too! Fantastic units and while the engine might not have been your first choice, it is light-years ahead of the 6-53, supercharged "Screamer" that was in the 40-footer I had a few years back. You are also way, way ahead of me with SketchUp. Great job on the layout. I'm just now beginning to work with it and not making a lot of progress so far. Back to the tutorials.
Meanwhile, I gotta' ask, are you shopping or hauling at Ritchie Bros? I just put them on my watch list for a Cummins engine and other parts, maybe a whole P30 if I can find the right set-up.
Tango is offline
Old 04-24-2011, 12:13 PM   #15
Chassis: AARE
Sketchup gets way easier as you go along.
Picking up two trucks going to Ohio.
Old 04-24-2011, 12:56 PM   #16
Have a safe trip. Blues skies and shiny side up all the way.
Tango is offline
Old 05-02-2011, 02:25 AM   #17
Started working with Google SketchUp and had fits for a while. Finally got a couple of layouts for the interior though. Mind you, this is one very small bus, so the plan is definitely "minimalist". You can only cram so much into a 1946 16-seater bus. The total interior space is about 15' by 7 1/2'.
Sink, cooktop, small fridge, jackknife sofa/bed and combo shower/toilet. The backend will be for hauling my shop & gear. Like I said, minimalist.
The "box" on the inside of the shower door is an idea for some extra shelves and drawers. A way to use all that space when you're not in it for other business. The idea is to use a swing out door that will close off the space to the front when it's in the open position. Still have a few details to work out, but it's a start.
Tango is offline
Old 05-02-2011, 12:23 PM   #18
Here's one more view...you can see the shower door/extra shelves/drawer space a little better...
Tango is offline
Old 05-03-2011, 09:41 AM   #19
Having WAY too much fun with SketchUp! Here's an update with a few more details. Now you can see how the shower door shelves intrude into that otherwise lost space.
Tango is offline
Old 05-20-2011, 01:11 PM   #20
Howdy All --- I just snagged a clean YOM (year of manufacture) Texas license plate for my '46. Hoo-yah! And I only need one. It seems Texas only issued single plates during WWII to save on metal.
Tango is offline
Closed Thread
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 07:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 09:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 08:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 02:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-24-2007 11:58 PM
