Old 05-04-2009, 04:14 PM   #1
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
1989 GMC Aggie Tailgater
Ok guys, I've been meaning to post my project since last year, but I never got around to it. We got our 1989 6.2L diesel GMC Ward shorty from a Houston area school auction. Paid around $2k for it last year. Seemed like a good deal on a bus with a great service record. Only mechanical work it needed was 2 new tires.
Our plan was as follows:
  • Bathroom[/*:e7p1w2n6]
  • Cooler for keg[/*:e7p1w2n6]
  • Battery bank[/*:e7p1w2n6]
  • Hardwood floor[/*:e7p1w2n6]
  • Rooftop AC[/*:e7p1w2n6]
  • Bumper flagpole mount[/*:e7p1w2n6]
  • Custom maroon/white paint[/*:e7p1w2n6]
Of course, this proved to be too much for year one, and Hurricane Ike made sure we didn't get the bus painted. It will definitely be painted for season two though.
*** Short Aggie Tailgater ***
elspankdog is offline   Reply With Quote
Old 05-04-2009, 04:18 PM   #2
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
Re: 1989 GMC Aggie Tailgater
Couple of pics after the seats were removed. Tried removing the bolts with a wrench and rachet originally, but I quickly went to the angle grinder.
Old 05-04-2009, 04:23 PM   #3
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
Another pic after the plywood and vinyl were ripped out.
Old 05-04-2009, 04:27 PM   #4
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
I wire-wheeled away as much of the rust as I could toward the back of the bus, sprayed some primer, put down the felt paper, and screwed down the 1"x4" grid work. You can see the openings I made for the battery bank. I had to make two compartments since a structural cross member was in the way underneath.
Old 05-04-2009, 04:29 PM   #5
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
Subfloor done! Filled in the grid with foam insulation and put OSB on top.
Old 05-04-2009, 04:34 PM   #6
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
Built a platform over the back right wheel well for the "kegerator" to sit on. This chest freezer works wonderfully. I bought a thermostat power controller from microage that lets you dial in the temp you want it at. When it reaches the desired temp, it cuts off power completely. This helps to save the batteries.
We were so excited that we installed the shank for the tap right away. Unfortunately, we hit a coolant line in the side of the freezer when drilling. Doh!
Old 05-04-2009, 04:39 PM   #7
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
Next, we framed the bathroom. I got a used marine toilet off of ebay for around $20 shipped, and then I bought one of those electric conversion kits off of ebay as well. The throne sits over the wheel well too.
Old 05-04-2009, 04:42 PM   #8
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
The water tank for the toilet sits to the left of the bathroom. Its housing will also serve as a bench. The top will be hinged to allow you to add water. The waste tank will be directly below this and the bathroom.
Old 05-04-2009, 04:45 PM   #9
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
Here's the bench opposite of the bathroom. The cushions are attached with velcro and are easily removed to open the hinged tops. This bench has two compartments: one allows access to the battery bank, and one allows access to the inverter.
Old 05-04-2009, 04:52 PM   #10
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
Got tired of working on the inside so we installed the low profile AC and the aluminum flag pole.
Old 05-04-2009, 06:25 PM   #11
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
Back to the inside - putting the floor in:
Old 05-04-2009, 06:28 PM   #12
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
More of the floor:
Old 05-04-2009, 06:30 PM   #13
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
Inside the little bathroom:
Old 05-04-2009, 06:36 PM   #14
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
One last pic of the back of the bus. This is all we got done last year. Hopefully this summer, we'll get the outside and inside painted, a stereo installed, and the drivers area bedliner coating rolled in.
Old 05-04-2009, 06:38 PM   #15
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
Getting ready for paint. Should be done in a few weeks, and then it is on to finish the inside.
Old 05-04-2009, 06:47 PM   #16
lapeer20m's Avatar
She's Looking Really Good!
Stereo is usually about the first thing i install when i do a bus!
Old 05-05-2009, 01:03 AM   #17
Chassis: Ford B600
Engine: Cummins
Sweet Project! Cant wait to see the paint job.
Tone is offline   Reply With Quote
Old 05-05-2009, 09:33 AM   #18
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
We blew our entertainment budget last year on our TV setup. Not to worry though, the stereo has already been purchased so it will definitely get installed this year.
Old 05-05-2009, 12:28 PM   #19
artistik1n's Avatar
Engine: v8 350
Your bus is looking pretty smooth! I have an 84 GMC shortie, very similar to yours. Where did you get the pull down curtains for the windows, and are they expensive? They look custom. Those would be perfect in my ride.
artistik1n is offline   Reply With Quote
Old 05-05-2009, 01:16 PM   #20
elspankdog's Avatar
Coachwork: Ward
Engine: 6.2L GM
Rated Cap: 19
They're just some pull down solar shades from Lowe's. They'll cut them to whatever length you need. I don't think they were too expensive.
My new tailgater sec234 Short-Bus Conversion Projects 56 01-08-2014 06:58 PM
1951 IHC Aggie Tailgater grz2000 Short-Bus Conversion Projects 78 09-28-2010 07:59 AM
Buckeye Tailgater.... IN PROGRESS baadpuppy Short-Bus Conversion Projects 25 09-27-2010 09:26 AM
Started - Vintage Wayne Tailgater davido Skoolie Conversion Projects 38 09-09-2008 02:59 PM
