Old 11-21-2014, 11:32 PM   #1
Coachwork: Blue Bird (Short)
Engine: 3800 T444E
Rated Cap: 19
Blank Slate
Hi gang. we just picked up our short, Blue Bird last week and it is something special. Its intended purpose is tail-gates, group day trips, and the occasional kids lacrosse team or birthday party. Might make an RV out of the next one, but im seeing a lot good "RV" ideas that I,d like to apply to this one like insulation, storage, generator use, plumbing, etc. I'm not an engine guy so I may not know how to tell which it has unless you tell me where to look. I think this one is a 2004 or 2006? automatic with 240,000 miles and it rides beautifully compared our last one (1993 International, stick-shift). Plus it has a split AC system and no wheel wells. Anyway, I'm gonna have lots of questions, especially about electrical.
Tailgater 6 is offline   Reply With Quote
Old 11-23-2014, 10:19 PM   #2
Re: Blank Slate
Welcome....nice looking bus. Can't wait to see what you do with it. Remember------> take & post lots & lots of pictures (many of us can't read.....LOL)
The-Breeze is offline   Reply With Quote
Old 11-24-2014, 11:54 AM   #3
Chassis: B3800 Short bus
Rated Cap: 36
Re: Blank Slate
Originally Posted by Tailgater 6
... and no wheel wells.
A flat floor in a conventional?! This is the first I've seen! Would you mind taking pictures around the rear wheel-well? What size are the tires? Very curious!
Old 11-24-2014, 04:44 PM   #4
Engine: 3800 T444E
Rated Cap: 19
Re: Blank Slate
I will gladly take some pics around the wheel wells, but I may not see it in daylight until next weekend though.
I guessed wrong in my last post: it's a 2001. Also was a 19 passenger. The lift and seats were already removed when we got it. So it's just a shell now. We've decided on a rough draft of floor plan. Includes some things that me be hard to get/expensive like four captain's chairs. So we'll see how that goes. When I say "we" I'm referring to the owners which was 6, but is now 8 ex-high school buddies in their forties trying our darnedest to hang on to remnants of our youth.
I'm going to remove existing flooring, put some rigid foam down (not sure of thickness yet because of concern for standing head room - hopefully I can get a halfway decent R-value out of 1/2 inch), add thinnest plywood possible, then likely a nice looking vinyl cuz it's easy to cut and will bend with the floor under the dash. I'd like to insulate the walls up to the windows, but am reluctant to remove the existing metal - all those rivets look like a lot of work for removal of a perfectly good wall. There won't be any full-timing in this thing cuz it's only a tail gater. Am I really giving anything up if I just add 3/4 or 1" inch rigid foam (however far that flange/lip sticks out about 10" off the floor) on top of the existing surface? Then, any suggestions on what finished surface I should use to cover the rigid foam on the wall?
Thanks for the help. I'll try to take lots of pics as we go.
Old 11-25-2014, 09:22 AM   #5
Engine: 3800 T444E
Rated Cap: 19
Re: Blank Slate
I've been kicking around the idea of drilling small holes in the inner layers of the walls below windows, and blowing in polystyrene balls (bean bag filler). This would solve my problem of not wanting to remove all those rivets, be a more efficient use of space, minimize waste, and perhaps give me an R-value of 5 or so, but the fact that this stuff is flammable is a little scary and also I read that it melts at 212 degrees F. Not sure how hot the outer layer can get when baking in the sun on a hot summer day. If that were possible, will I have to worry about toxic fumes or anything like that? I'm out of my league here. Am I worrying too much? Any thoughts?
The only other thing I can think of is using spray foam with the same "hole-drilling" method. Never done this before. So I'd be worried about even distribution, but wouldn't I end up with the same concerns since it's all foam?
Thanks for the help!
Old 11-25-2014, 10:02 AM   #6
Rated Cap: 36
Re: Blank Slate
Have you popped open a panel to investigate the innards? I think most buses have a miserable chunk of fibreglass insulation stuffed in there. I say miserable because when I opened mine I found them to be moldy and poorly fit. Some of them were cut several inches to small all the way around... If they exist in the panels they will obviously interfere with the idea of blowing in insulation.
A note about spray foam: there's no way to properly fill an enclosed space with it. It will grow and harden before it settles into the space, leaving all sorts of gaps. Also, if it has no place to expand to it will remain liquid, which negates all R-value. There are some neat pour-in foams, though. They're harder to find, but you can mix it and pour it into any space and it will fill the void as long as the air above it can escape. http://www.compositescanada.com/prod...yurethane-foam
Now, there's also the question of if it's even worth it if you are just going to keep the metal panels on, which are attached to the metal ribs, which are attached to the outside steel. All those thermal bridges provide a nice means for heat transfer from the outside to the inside and vice versa. If you're serious about insulating, you'll have to insulate OVER the panels, or replace them with something with less conductivity.
Old 11-25-2014, 01:55 PM   #7
Engine: 3800 T444E
Rated Cap: 19
Re: Blank Slate
Thank you Jazty, for such a coherent response. I no longer even care what's behind those panels. I will be insulating OVER them now.
With confidence, I can promise that will NOT be my last dumb question.
Generator question: I've been pondering where to put my Honda E3000 (I think) generator. I got it a few years back for our first bus because it seemed to have the best power at such a low decibel rating. With our first bus, we would carry this generator with us to the site and then unload it, run the wires, try to cover it for rain or if the site had "No Non-RV Generator Rules" (I felt as quiet as mine was, it did not fit into this group and we never had a complaint), fire it up, and then have to put it all away when we were done.
I always dreamed of having it stowed away in its own vented compartment that had maybe a heavy duty drawer/platform where we could slide it out to start it/gas it up/check the oil, and then just slide it back into place and lock the door. I've seen them under the bus, but I dropped $1800 for this one, it's not exactly weatherproof, and I would rather not see it subjected to that kind of abuse. Unless there is a better idea out there, I think my only/best option is to cut an exterior access to a box built for this purpose in the interior of the cabin. I have no welding capabilities, but I'm in HVAC with access to a metal shop. So I'm thinking of building a well-sealed, plywood box with some form of inner, metal layer to act as a heat shield. I've never done this before. So any advice is welcome.
One of my big questions is how to make a door out of the cut-away piece of bus shell.
Many thanks for any help!
Old 11-25-2014, 02:22 PM   #8
Re: Blank Slate
I put my Yamaha EF3000iSEB genny in a pull out drawer for the same reasons you want to. You will find that you will need to extend the muffler to a remote location or it will overheat the genny to the point where it will shut down--doesn't take long either. You will also have to have a fan to push cool air through the box. I also added a puller fan which kicks on when the temp in the genny box reaches 60 degrees C. While plywood is easy to work with, it will actually act as a noise enhancer and make your genny sound noisier than an Onan I suggest you read up on sound attenuation on the internet--you'll be surprised at what you learn. You will also get a good laugh out of what some folks have done to try to quiet a genny (Utube). Hope this helps. Jack
Old 11-25-2014, 04:08 PM   #9
Engine: 3800 T444E
Rated Cap: 19
Re: Blank Slate
Hmmm. Very interesting ol trunt. I was concerned about venting it properly, but had no idea the right way was to duct out the exhaust. I may have to rethink this and start looking under the bus again for options. Maybe I make a weather-proof box, with a removable cap, that can swing out or something. This genny's got an elongated grill for exhaust that comes out the top of the unit. So I'd have to fabricate something to catch all of the fumes, and with too-long-a-run I'd worry about stifling it with back-pressure (I'm no expert on this, but I would assume it was not designed to push its exhaust through a long duct). All this talk of possibly over heating & increased noise has taken the wind out of my sails on that idea. Thank you for the advice which has likely saved me a lot of work and perhaps a little embarrassment. Back to the drawing board.
Old 11-28-2014, 10:01 AM   #10
Engine: 3800 T444E
Rated Cap: 19
Re: Blank Slate
First, I never provided our bus location: It splits time between New Market & Damascus, MD. Anyone in the area?
Second, too all those, like me, who prefer pics over words,
I intend to spend some quality time with our new bus this weekend. Our plan is still under development. So most of this time will be a search for inspiration through the simple act of looking at it (and likely tearing the rubber floor up). I will also be doing a photo-shoot to post on here. Can those of you that catch this post provide some ideas for useful, photo, subject matter or just things that you or others may be curious about?
I've already had a request for close-ups of around the wheels, since there are no wheel-wells, and tire sizes. I will also try to remember to get pics of the following:
-Info plates (I only know of two plates that are on the interior - are there others I should look for?)
-wiring/breaker compartment and guide on back of door
-fuse compartment and guide
-pics of underbelly (if ground is not too wet still)
-heaters, heater lines
-under the hood
-driver area/controls
-buttons and switches I can't explain like "econo mode" and what looks like cruise control (but seems almost out of reach of driver)
-things slated to be removed
Anything else I'm not thinking of that either you would like to see or that might be useful as a reference during the conversion process?
Thank you for the help!
Old 11-30-2014, 03:05 PM   #11
Coachwork: International/Thomas
Chassis: 3700
Engine: 7.3
Rated Cap: 73
Re: Blank Slate
Have you considered a bumper platform, either a 2ft x 2ft permanent platform where the generator is mounted?
Just remove the cover or open the door when in use.
I would be worried about a 2ft tall box mounted under the bus and how low to the ground it rides.
My conversion thread, viewtopic.php?f=9&t=466746
BUBB is offline   Reply With Quote
Old 11-30-2014, 06:47 PM   #12
Engine: 3800 T444E
Rated Cap: 19
Re: Blank Slate
Funny you say that Bubb. I spotted a pic of a bumper platform a couple days ago (on this site of course), and have been cultivating that idea ever since. Your suggestion just gives me more confidence. I'm pitching a 5 foot long bumper platform to my partners now because we were already looking for a better grilling solution than the small portable grill we used with our last bus. The platform gives us room for a permanent grill/smoker on one side of the back door and a weatherproof genny lock box on the other side of the back door. Put an eight foot wide awning off the back of the bus to make our cooks happy and then we're cooking with gas (actually literally cooking with gas).
Thanks for the post Bubb!
Old 11-30-2014, 08:02 PM   #13
Engine: 3800 T444E
Rated Cap: 19
Re: Blank Slate
Hey Jazty, here are some pics of the wheel wells. It looks like you basically are looking at the underside of the cab floor. Front and back tires are both 255/70 R22.5. Is the tire size in that number somewhere? I never have known how to read those things.
Old 11-30-2014, 08:07 PM   #14
Engine: 3800 T444E
Rated Cap: 19
Re: Blank Slate
New question: in the last pic above, you see a louvered air intake just behind the wheel-well. Right now the whistle coming from that general area is louder than any noise coming from the engine. Does anyone know the purpose of this vent and more importantly, can I close it up?
Old 11-30-2014, 08:46 PM   #15
Rated Cap: 36
Re: Blank Slate
Thanks for the pictures of the wheel well! Judging by how that whole area is put together, I suppose we could all have flat floors if we cared to go with a lower-profile tire.. neat.
That vent is your fresh air intake for the big heater next to the driver, which probably also controls the windshield defrost. There is likely a control of some kind near the driver's left foot that opens a flap allowing fresh air in, or recirculating interior air. If you're hearing a whistle in there while driving I would guess that the flap is somewhere in between open and closed.
Old 12-01-2014, 09:25 PM   #16
Engine: 3800 T444E
Rated Cap: 19
Re: Blank Slate
Took some pics over the weekend. Thought I'd add a few "befores" now because the slow transformation is set to begin on Saturday. I will soon have some "afters!"
As seen below, what is this "econo mode" button? Is the button beside it cruise control? I question only because I can hardly see and reach it from the driver seat.
Old 12-01-2014, 10:04 PM   #17
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Re: Blank Slate
I'm willing to guess .....
Translating Ford 7.3 to IH 444-I have whats called in Ford terms an "AIC-auxillary Idle control." Its a box with lcd red out of the RPM and a few buttons. From what I've read, for cold weather warm ups (like is posted on you dash) and PTO use, they want you to crank up the rpm's. I'm betting the econ mode is made for long times sitting at idle. (Can you picture being the bus driver at an away basketball game at International Falls high school? )
Old 12-02-2014, 08:00 AM   #18
Rated Cap: 36
Re: Blank Slate
Yep, the two black switches above the light switch are definitely idle-speed controls, which - as the sticker suggests - is good for winter starting. They can also be used for cruise control if that function isn't blocked out by the ECM.
I can't remember exactly how the switches work, but the system is not intuitive. It's something like you need to hold the Throttle switch in the ON position while pressing Set, then you can use the Accel button.
No idea about Econo-mode...
Old 12-02-2014, 08:01 AM   #19
Rated Cap: 36
Re: Blank Slate
Have an Allison transmission? This may be the answer to the Econ-mode riddle: http://www.schoolbusfleet.com/forum/...TOPIC_ID=23154
Old 12-02-2014, 11:53 AM   #20
Chassis: 3700
Engine: 7.3
Rated Cap: 73
Re: Blank Slate
i love the idea of a long bumper platform, I looked into a 4ft platform for my bus, I wanted to use it to hold a spare tire, but I had many people talk about how it would drag when I went through a dip, how much wider my rear would swing when turning, my bus is 37ft now and I know yours is not quite that long, and how the weight back there would make the wobble back fourth while driving.
I was thinking more like a generator platform that stuck out 2 or 3 feet with the edges curved in so it will not make it harder to make tight turns.
Just wanted to mention a few things.
