Old 02-06-2010, 11:41 AM   #1
Re: !Help! My Bus Has No Metal Floor
start with pressure treated plywood, then coat the bottom with rubberized undercoat after you install it.
paul iossi is offline   Reply With Quote
Old 06-15-2010, 06:31 AM   #2
Year: 1985
Coachwork: Nambucca (nsw)
Chassis: Nissan Ud Truck chassis
Engine: FD6T
Rated Cap: 35
Send a message via Yahoo to Bavo76
Not all buses come out with a metal floor mine doesn't its only a ply floor with a rubber flooring its almost 1'' thick so Ive only sprayed mine gloss black under my bus .so how thick is your floor and is it original flooring as it must of passed when new and if you do rip up the floor and replace with metal .you will need a mig welder and its going to be hard going welding while on your back under your bus and getting the panels to meet over a cross member or you are going to have to put more bracing in
Bavo76 is offline   Reply With Quote
Old 06-19-2010, 10:04 PM   #3
Will's Avatar
Engine: DTA 360, Fuller 6-speed
Rated Cap: 53
There is no steel under the plywood? Did you crawl under the bus and verify? My bus has a plywood floor, but the subfloor is steel.
My bus conversion
Will is offline   Reply With Quote
Old 06-20-2010, 12:33 PM   #4
Stuff's Avatar
if you're worried about it rotting id rustoleum the bottom of the bus lol
Old 02-28-2013, 05:19 PM   #5
yugogypsy's Avatar
Year: 1965
Coachwork: Ford/Willock
Engine: Doesn't have one
Rated Cap: 16 passenger
Hi, I am facing the same situation with my "Pit Stop"
At the moment it's "WATCH WHERE YOU STEP!" or you go through parts of the floor.
I have to agree with all the other answers, put in a new floor and coat the underside with some sort of waterproofing.
That's what I plan to do AFTER "Pit Stop" gets cleaned out and stops being a shed
If you haven't read my post on her she's an old Ford skoolie, then logging company "crummy", now minus her front axle she's up on blocks waiting to be my outdoor living/dining area for hot weather
Good Luck with your project
Lois
yugogypsy is offline   Reply With Quote
Old 06-20-2013, 12:02 AM   #6
Chassis: TC2000 FE
Engine: 190hp 5.9 Cummins
No laying on your back is needed. Drill half inch holes through the new metal floor sheeting over the cross members, and simply plug weld.
Mig welder or Tig would be the way to go.
Wood floor is fine as long as the part where you sit while driving is steel. More times than I can count I have had things hit the floorboard under my feet hard enough to punch through a wood floor, but only dent a steel one. One time on my Bronco 2, the drive shaft broke just behind the transmission. Still attached to the rear end, it dug into the road, and blew through the floor board right behind me. Good thing my kids weren't in the back seat.
Nat
Old 06-20-2013, 10:07 AM   #7
Quite a few of the fiberglass bodied units have only ply for flooring. If you want it to last I would suggest investing a few bucks more for "Marine Grade" plywood then putting a heavy layer of spray on rubberized undercoating on the underside. Even "treated" ply will have a short life span due to the type of adhesives used and de-lamination will begin to occur fairly rapidly if exposed to water with any frequency. Marine grade is the only ply rated for wet environments. It is pricey but a whole lot cheaper than having to tear everything out in a few years. Also, using a urethane based glue (like "Gorilla Glue") between all the butt joints will help tremendously. Like the Marine ply, it is the only glue rated for "below waterline" use and is 100% waterproof. Just be sure to use disposable gloves when working with it. The stuff turns your skin black and it does not come off until the skin does!
Tore up floor - How do I seal the metal ? (Holes, etc) rail_hauler Conversion General Discussions 10 05-15-2020 07:18 PM
Searching for sheet metal M1031 Classifieds | Buy, Sell, Swap 1 04-11-2011 04:00 PM
Insulating a metal floor in Double Decker Ob1 Conversion General Discussions 1 12-18-2010 01:37 PM
rusty metal floor - what product to use?? ramairws601 Conversion General Discussions 2 10-03-2009 12:11 PM
metal floor Lea Skoolie Conversion Projects 3 07-26-2005 11:44 PM
