Old 10-21-2010, 07:07 PM   #1
Engine: 5.9 Cummings
Rated Cap: 24
The uprising of the "Green Machine"
My name is Kurt from Hartford WI and I bought my first bus a couple of months ago. It's a 1999 24 passenger flat nose Blue Bird with 24 valve 5.9 Cummins diesel with Allison tranny. So far I removed the seats, stop sign and other red school lights and painted it. In the spring I will finish the black trim portions of the buss. My fuel tank sprung a pin hole leak shortly after I had it.I'm in the process of getting that fixed. I have a couple of sheets of plywood pulled up from the floor. I plan on fixing the rust spots, probably painting the floor with a coat of Rustoleum and then maybe a coat of undercoating then new 3/4" plywood.I will have questions about the correct ways to do certain things on the bus. ( heat, power, etc.) It's great to look at the gallery to get ideas.
http://www.skoolie.net/gallery2/v/Skooli ... 2.jpg.html
funbus63 is offline   Reply With Quote
Old 10-21-2010, 08:55 PM   #2
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: The uprising of the "Shagg'n Wagon"
Reminds me of the lime green gremlin that was on tv commercials a while back. Good start to it, keep the pics and progress coming....
see my conversion at https://www.skoolie.net/gallery/v/Skoolies/Putters+Bus/
putterspitt is offline   Reply With Quote
Old 10-22-2010, 12:37 PM   #3
Diesel Dan's Avatar
Engine: DT466/AT545
Wow. That is an eye-catching color you chose. The lack of wheel well humps will give you a lot of flexibility in your interior design. I think those wheels must be smaller than typical bus wheels, right? Do you have a high roof on that bus? Like maybe 6'6"? Welcome to the skoolie site!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 10-22-2010, 01:52 PM   #4
Rated Cap: 24
Re: The uprising of the "Green Machine"
I'm not sure on the wheel size. As far as the inside height goes,I'm 6' and I have room above. I never measured it. I guess now I will have to..... I can't wait to get the flood ripped up, holes patched and the new 3/4" plywood down. Then comes the fun of deciding what and where to put it.
Old 10-22-2010, 01:56 PM   #5
Rated Cap: 24
Old 10-22-2010, 05:10 PM   #6
lornaschinske's Avatar
Nickelodeon fan? Even my daughter thinks it looks like "Slime Green"
Fulltime since 2006
Old 10-22-2010, 07:20 PM   #7
Rated Cap: 24
It must some disease I have. Years ago I had a ultra light airplane and I painted that the same color.I guess everyone has their "thing".
Old 10-23-2010, 04:17 PM   #8
Rated Cap: 24
Today was a very productive day. All the old plywood is out of the bus. Time to patch holes and start putting it back together.
Old 10-23-2010, 07:47 PM   #9
Engine: DTA360
Rated Cap: 16
WOW!!!
That thing is more green than mine...
dirtygoat is offline   Reply With Quote
Old 02-18-2011, 11:14 AM   #10
Rated Cap: 24
Finally got back to doing some work on the bus. I had all new brake hoses made and am replacing the entire brake line system. I couldn't find a way to get to the fittings on the master cylinder so I made a access hole which will be the new location for the brake reservoir.
replaced the entire brake line system including hoses from the master cylinder back
Old 02-18-2011, 12:59 PM   #11
Rated Cap: 24
This is the bus at bus co. in northern
http://i1190.photobucket.com/albums/z45 ... G_1444.jpg
Bus after paint. I still need to do the black stripes etc.
[img]http://i1190.photobucket.com/albums/z459/funbus63/The%20Green%20Machine/IMG_1481.jpg[img]
Getting started on the floor
Old 04-21-2011, 06:31 AM   #12
Rated Cap: 24
This is the Mico brake that came with my bus. I'm not sure if it works of not but I'm going to try to get it hooked up. It works with the main brake system to lock the rear tire when energized. It has it's own pump and brake line the pumps fluid into an actuator to put pressure on the main brake system to work calipers.
Old 05-15-2011, 07:57 AM   #13
Rated Cap: 24
Cut outs in the front for the stereo and front speakers.
finished product. I also make a little storage area behind the board.
Old 05-15-2011, 08:03 AM   #14
Rated Cap: 24
addition of rope lights on a dimmer
Old 05-15-2011, 08:06 AM   #15
Rated Cap: 24
windows out for "skinning"
one side completed
inside view
Old 05-15-2011, 08:08 AM   #16
Rated Cap: 24
new drivers seat mount
new captains chair
Old 05-15-2011, 08:10 AM   #17
Rated Cap: 24
new control panel. Switches have red led pilots. Dimmer installed for the rope lights.
Old 05-15-2011, 08:13 AM   #18
Rated Cap: 24
My three helpers on the project so far.I'm not sure which one did the most work......(no offense Pam)
Old 05-15-2011, 08:14 AM   #19
Rated Cap: 24
The new 12 volt fuse panel
Old 05-15-2011, 08:17 AM   #20
Rated Cap: 24
The Mico brake that came with the bus. I'm going to install it that when you push the E brake the Mico automatically engages.It will lock up the rear calipers.
pump mouted under bus
Questions about "green" insulation for bus Redbear Conversion General Discussions 12 07-01-2021 01:57 AM
My 1987 IH/Carpenter "Simple Green" charles_m Skoolie Conversion Projects 9 09-15-2013 07:48 PM
The Green Machine Six Four Short-Bus Conversion Projects 3 03-15-2011 11:47 AM
up for auction!! 1972 GMC "New Look" "Fishbowl" Coachbus35ft Stuff Classifieds | Buy, Sell, Swap 0 01-18-2011 10:39 AM
"Tutorial" and "How To" internal error dunnwright Conversion General Discussions 6 11-16-2010 07:02 AM
