Old 11-29-2011, 10:20 PM   #1
Engine: 6.7 L 3116 CAT V6-Inline
Rated Cap: 60
Selecting the correct alternator?? Any opinions?
After perusing the forum here, i am now beginning to consider installing a 2nd alternator to run the auxillary power system on.
Here way my orignal plan:
Connect isolator to alternator
Connect batter bank on (3) 8D batteries to part B of isolator
Wire alll three together
Run post wire to a 3000 watt Wagan inverter (Do i need any higher)
Run post wire from output of inverter to interior fuse box #4 wire
Run 5 receptacles from fuse box with #12 wire
All to power a few lamps, flatt screen tv, fridge, microwave, small heater, and a coffee maker.
So i suppose my question is, would one alternator on a 6.9 L DT in a GMC be sufficient for this load
0r
should i consider having a secondary alternator? if so here is the one i was considering.
http://www.elreg.com/search?page=shop.product_details&flypage=flypage.t pl&product_id=2280&category_id=558
Thanks!
telluriders is offline   Reply With Quote
Old 11-29-2011, 11:49 PM   #2
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
Re: Selecting the correct alternator?? Any opinions?
Sorry, this won't answer your alternator question, but have you looked at your electrical system with regard to the other systems or are you just starting to assemble systems by duplicating what's in your house?
It would take me 3 weeks to get 3-8D batteries down to 50% charge and I don't do anything different than when I lived in an apartment, I just do them a different way.
From your list of electrical stuff mine is only different from yours in three things -
1) Electric coffee maker - I use a Melita coffee maker, just boil water on the stove and pour it through, instead of the electric pot cycling all the time to keep the coffee warm, you just light the stove when you want another cup, heat it up and turn off the stove - unlike an electric pot, it's not 'on' all the time anticipating that you'll want another cup and wasting electricity.
2) Electric heater - I use a propane 'Buddy' heater. I've tried a 1500 watt heater in here before and it doesn't even start to warm the joint up. Propane keeps the inside about 35 degrees above the outside on 'low' and runs me about 12 bucks a week and I use it for cooking as well, I doubt if 3 gallons of gasoline could be turned into enough electricity to do that.
3) Microwave - i usually heat/cook things on the stove. I run my generator about an hour and a half a day to charge the batteries and run it about dinner time if I want to use the microwave. Anything that needs big AC gets done at that time (vacuuming, etc.)
That gets you down to some lights, TV and refrigerator - and of course, now, some propane.
Just some thought in case you want to save a buck or two on that monster inverter and those batteries - wow 6 cubic feet and 500 pounds of batteries!
I have a 700 watt inverter, but haven't turned it on in about 2 years - I normally get by with a 75 watt'er I picked up for 15 bucks in the drugstore. The only thing I run on AC are two lamps - rarely. The LCD TV was powered by a 12 volt wall wart, so I tossed that and just plug it into 12 volts, got a car charger for my laptop, runs off 12 volts.
Sorry I didn't answer your question - there are others here that can answer that one better than me - but I see so many people who 'plan' their systems by just cloning their home systems, when with a little thought and some minor changes in the activities of daily living resources could be deployed a little more, at least in my opinion, effectively.
Seems most of our behavior is shaped by our homes, which are build 'standard', converting your bus gives you the chance to do it the other way around - shape the systems to your behavior.
I don't know anything about how you plan to use your rig - mostly driving, live-aboard or what or anything about your other systems, so this may be helpful or it may be just rambling drivel, so if some helps - good, if not well, never mind
Tom
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 11-30-2011, 06:19 AM   #3
Rated Cap: 60
Certainly not! That was very helpful, i negleted the Hank Hill in me to think about using propane. And i dont mind modifying what i use, because yea, i dont want to have to buy 3 batteries..... or a Frankenstein inverter. However, i do want to do what it takes to have at least 4 receptacles in the bus (part of the fufillment of RV codes and just because its "homy" haha.) But yeah, were taking her out to Colorado in june and wont be using the electrical much when we get to the festival, just mainly on trip out there to keep my friends entertained.
So the buddy heater is fairly efficient versus the small mr. heater (blower style)?
And thank you for your input!
Old 11-30-2011, 03:21 PM   #4
wtd
wtd's Avatar
Year: 1982
Yup, I'm with ya' on the receptacles - I've got them all over, they're called 'convenience outlets' for a reason .
Of course I'll probably not have electric frying pans plugged into them all at the same time either.
Since our routines are more constant than we'd like to think, it may be of some value to stop from time to time and think on just how much power you're using right now and how much did I use in the last little while to get me here (am I actually using those three light or did I just not turn them off)?
Sorry, I'm not a 'greenie' type - I just don't like to waste stuff - anything I waste is something I could use somewhere else and another buck I don't have to make to pay for it and the longer my 'occasional' retirements last (too much Travis McGee when I was young ...).
Actually I can even make a tortuous argument that I use 'wind power' (chuckle) - Because of the current green energy frenzy I sold a pretty much otherwise worthless parcel of land I owned out in the desert to the wind farm next door for 4 times what I paid for it (their blind offer, not mine) which'll pay for gasoline for my generator and push the current 'retirement' out another coupla years. Thank you fellow taxpayers ...I'm all for green power, just wish I had more land to sell ... Sorry - got off in the weeds there ...
Anyhow, with most systems I start small and get bigger as demand requires - just a personal preference.
Just the thought behind it -
Given the choices - $300 for a 3000 watt inverter, $40 for a 200 watt inverter. (um, just to eliminate confusion, these numbers are just to illuistrate the point, not shopping tips).
Two ways to do this -
1 - buy a big inverter, find out it winds up being way more capacity than you use and either live with it or take tgreat satisfaction in the fact that if you suddenly have a desire, while boondocking, to blow dry your hair while making popcorn in the electric popper, while watch the big screen TV while the stereo blasting out the latest hits, while you fry pork chops in the electric frying pan while the potatoes are baking in the microwave - all lit up light an operating room and a friend in an iron lung drops by - you can power it all! Thank Gawd for that inverter huh?
But anyhow, most of time, if not all the time you have 260 bucks (the amount you spent - the amount you needed to spend) sitting there twiddling it's thumbs that coulda taken you shopping and bought you a nice present..
- OR -
2 - Buy the 200 watt inverter for forty bucks and take the other $260 to Walmart or Costco or wherever you prefer and get a couple deep cycle batteries. If you find out you need more power later, or that friend in the iron lung drops by, go buy the 3000 watter and you're only down forty bucks and a trip to the store and you have a backup inverter to throw in a compartment.
Also, as a side note, inverters have an 'overhead' load, just to power themselves - my 700 watt inverter uses 1.2A just to turn it on - seems like a waste when I power a light that only draws 800 mA. My 75 watt'er drraws only 50 mA for itself.
Sorry, got kinda windy there - enjoy your bus -
Oh, as to the heater, just made a post on the conversion thread
http://www.skoolie.net/forum/viewtopic.php?f=9&t=11157
Hope that works - never posted a link to my own thread before ...
Tom
Where DIY meets WTF
Old 11-30-2011, 09:40 PM   #5
Rated Cap: 60
Thats so helpful...not long winded at all...i like indepth background stories! So land out west ayy? Whereabouts? sounds like a sound investment i'd say. And so youre saying even with a 200 watter i could rig the receptacles?? Im just concerned that #4 wire running from a small inverter to the breaker box sounds wimpy...but then again im an emerging in the electical dept. But after hearing what you've said, realistically, i would be powering a tv, a few phone chargers, lights, stereo, and mabey some other small things. Not at the same time of course. And thanks for the link...ill checker out!
Old 12-01-2011, 02:34 AM   #6
wtd
wtd's Avatar
Year: 1982
About 50 miles southeast of Bakersfield, 80 miles north of LA, 50 miles west of Barstow - and of course everyone knows where Barstow is! Home of the World's Largest Thermometer!
EDIT: Silly me everybody knows the World's Largest Thermometer isn't in Barstow - it's in Baker, which is of course 60 miles east of the 'NEXT GAS 60 MILES' sign just outside of Barstow! Hope nobody left before I edited this ...
Don't follow this ... that's on the AC side and unless you plan on becoming an itinerant executioner with your own electric chair you won't need anything that big for AC.
Using this pretty basic electrical system -
If you use a hulking inverter it would look different than this.
For the 12 volt stuff the wires are sized by how long they are and how much current they carry.
Here's a calculator for that -
http://www.freesunpower.com/wire_calc.php
It's made for solar panels, but it's the most straight forward one I've found - ignore the labels and for step 2 put in the load on your circuit and step 3 put in the length of the wire.
So before you go deciding on wire sizes you need to come up with a general layout of the components, so you know the wiring lengths, then, using the loads you've calculated for each circuit and the wire lengths of the corcuits calculate the wire size using the calculator.
The picture above is essentially the same as my system, no bells or whistles. You can get things from the marine or RV supply stores that put the 12 volt fuses and stuff in en enclosure with the 120 volt stuff and it gets pretty pricey and fancy. I just used an auto accessory fuse block from Autozone for the 12 volt stuff and a breaker box from the hardware store for the 120 volt stuff.
So anyhow, you need to come up with the equipment layout first, if you haven't already.
Then do the same thing for the branch circuits, like this one -
The soffitt lights are on one circuit (6 of them), along with the bathroom light, each one uses 0.8A.
Use a little common sense when you're calc'ing the load and round liberally - I used 1 amp for each light and even when several people are here, I don't sponsor the local embroidery club, so I don't need every light on over every seat at the same time, I figger'd 3 on at any one time and the bathroom light - so 4 amps for this circuit and that's only for as long as the bathroom light's on. The wire run is 35 feet from the fuse block to the furthest light - wire calculator says #11 wire - rounded down to the next smaller standard size, since we're not worried about wire failure, just voltage drop. And bingo - wired it with #12 wire. If you wanted to wallow in trivia (I don't), you could take all this stuff out to several decimal places and tighten everything up, but in practical terms it wouldn't change much.
You'll hear a lot from people telling you to use huge wire sizes and 'better make that one size bigger - just to be safe!
Well, if you just don't know about whether it is or not - give it a whirl and see for yourself about stuff - If you don't know whether a wire will get hot enough to cause a problem with your planned load, like the circuit above, pull out a 35' length of #12 wire, hook a car headlight (5 amps give or take) to the end, put the wire (but not the headlight) in a paper bag and hook it up to a battery and come back in an hour or so and see what happened - nothing. No flaming mass of debris - nothing. And you bus ain't made of paper. There is also enough information on the internet to calculate that the bag wouldn't catch fire as well, but it's easier to test it. Lots of what you hear comes from the fear of the unknown (notice that once we found out what caused earthquakes we stopped sacrificing virgins to appease the gods?) if you don't know if what you hear is right, test it or research it and use common sense. Simple tests like the above can answer a lot of questions, save you money and time.
Anyhow, if we use the picture from above, saying that's a 200 watt inverter figure it'll need about 20 amps max. - again with the liberal rounding - divide the watts by 10 instead of 12 it makes it easier to do in your head and also leaves a little elbow room, as you're calc'd load will be higher than the actual load. If we say the length of the green wire from the fuse box feeding the inverter is at most 10 feet, putting 12 volts, 20 amps and 10 feet into the calculator gives us a #10 wire for the inverter. So as long as we mount the inverter within 10 feet of the fuse block we're good with #10 wire,
You do the AC the same way, just use a different calculator.
Maybe this answered a question or two, maybe you knew all this already, if so - well if people can upload videos of cats playing the piano, I can waste a little bandwidth too, no?
Tom
Where DIY meets WTF
Old 12-01-2011, 06:22 AM   #7
Rated Cap: 60
Mhhh my gosh, i didnt know you were the proud owner of the rolling motel room!!? That is one of my favorites on here...so simple, and very creative ! nice work! And yeah your right about the fear factor, i got the gauge number from my step father whose an engineer at Duke Power. However, this of course seems like the biggest electrical hazard to him, but i'd assume thats because they do not teach "Bus electrical 303" in an engineering major! hahah
But yeah i'll soak this in and do some calculations!
One more question, i have to run the wire from the inverter to a fuse panel then to the fuse box? (I'm a bit slow) And if a converter does no have output terminals for wire do you just plug in a heavy duty drop cord and spilt the other end to wire it accordingly??
Thanks soooooooooooooooo Much ! Big help! and i love your sense of humor!
Old 12-01-2011, 02:54 PM   #8
wtd
wtd's Avatar
Year: 1982
Guessing you mean breaker box (in the basic diagram above) when you say fuse box - no - it goes
Battery -> fuse panel -> inverter -> breaker box.
Um, if you could stick to the labels in the drawing it'd help me a lot. Ex. when you say 'fuse box' and 'fuse panel' I don't know exactly what you're referring to, since neither of those labels are in the drawing. I don't know if you referring to the 12 VDC fuse block or are using another term for 120 VAC breaker box (also known as a fuse box or fuse panel.
SInce many of these devices have a bunch of different terms used for them - for example the breaker box shown in the diagram above is also sometimes known as a fuse box or as a fuse panel - so's the 12 VDC fuse block, so when they're in the same picture I don't know which one you're talking about. SInce I embraced senility at an early age I'm also easily confused - which doesn't help much but I'm sure it'll add something to the highlight reel in the end. .
Also a mite confusing to me -
And if a converter does no have output ...
Um, again with the diagram - what converter?
There actually is such a thing on most RV's, just don't know as that's what you're referring to, since we haven't gotten to that part yet, or if you mean something else. If you plan to use a converter it's aways off yet. #4 below.
It kinda goes like this -
1) Develop DC power circuits and some way to power them
2) Develop AC power cirsuits and some way to power them.
3) Connect 1 & 2 together.
4) Find some way to get external power into the system to 'refill' it.
I've added a converter/charger section to the 'basic diagram' -
It's a lot easier to take it a step at a time or you start getting all kinds of information that really has no value at present and your research will be pretty helter-skelter. I'd stick to one system at a time, get it set-up (not built and not necessarily set in stone, but at least a good handle on what you want to do and how you want to do it) and move on to the next one.
Anyhow, I've just always found it easier to break big things down into smaller things if I can and solve them a piece at a time. It's hard with systems like this, since you're hit with all the information at once and it's hard to get your head around all at once just wading in.
Just to put a 'real' face on the diagram above - here's what I used for the 12 volt fuse block -
As mentioned before, these things can get much more snazzy and pricey, but this works for me. In the picture battery comes in on the right and individual circuits come off the individual crews near the center, obviously fuses go in between. I have no idea what the brass strip on the left side is for.
Breaker box (this ain't pretty - brace yourself) -
Power comes in at the bottom and goes out the left side to the two outlets there.
i 'bout got decapitated by trying to hold the engine room door open taking this picture a little bit ago - winds here currently 25 mph, gusting to 55.
Well, I'd answer your questions if I knew what the hell you were talking about
Pitch 'em again, I'll take another swing ...
Thanks for the kind words on the bus.
Tom
Where DIY meets WTF
Old 12-01-2011, 05:11 PM   #9
lornaschinske's Avatar
Year: 1986
Rated Cap: 89
Intellipower "Mighty Mini"
But what do I know?
Oh and this thing has a "smart charger" built into it... whatever that means.
Fulltime since 2006
Old 12-01-2011, 07:31 PM   #10
bus-bro's Avatar
Engine: 3208 na boat anchor
You can also use Square D QO panel and breakers for 12 volts dc. An inverter would need a seperate fuse.
bus-bro is offline   Reply With Quote
Old 12-01-2011, 08:43 PM   #11
wtd
wtd's Avatar
Year: 1982
Not exactly so.
An inverter is just like any other device - if it draws more current than the fuse block and fuse (or breaker) is rated for then you need a separate fuse. If the draw falls within the rating of the block and you use an appropriately sized fuse (or breaker) you can run it through the block like any other device. Doesn't need a separate fuse just because it's an inverter. There are many inverters made that'll just plug into your car's cigarette lighter, no separate fuse.
It just happens that many inverters have large current draws requiring a separate fuse because the draw exceeds the rating of any available block or breaker and that's what most people are used to seeing. That point was made way back in one of the posts. We've been yammering about a 200 watt inverter which falls well within the range of a 25 amp fuse and an appropriate fuse block and should require no separate fuse.
On the other hand - maybe I'm missing something? I've done it before, will probably do it again ....
Tom
Where DIY meets WTF
Old 12-01-2011, 09:22 PM   #12
bus-bro's Avatar
I was thinking of a 2000 plus watt inverter-charger. Something on the order of a 200 to 300 amp fuse.
Old 12-01-2011, 09:31 PM   #13
Rated Cap: 60
wtd: dood...you crack me up and you're right, im sure me not not being consitent is not helping the cause...Let me try again.
The diagrams you made make things so much more sense. The question i meant to ask about it was, why is the fuse block necessary (as opposed to running a line from the battery to inverter?
As for the output question, on most inverter the only output is through a AC outlet. However some have wire post terminal to attach the gauged wire to. But after seeing your set up, i assume you can just plug a heavy duty drop cord in and cut and split the opposite end to wire up with the fuse box??
And sorry about the winds...that sounds like some Blizard of OZ weather hahaha. Thanks man!
Lorna: Yes i came across that niffty little guy the other night. Seems like it knocks it all out. So does the intillipower reallyy charge, or is it a false claim like some other inveters use?? Thanks!
Old 12-01-2011, 10:52 PM   #14
bus-bro's Avatar
You're supposed to have a main fuse close to the battery bank for all circuits. IIRC it's less than 3 feet. As far as the AC side of things, you're in the NEC code book. At least get a Wiring Simplified booklet. Extension cord as fixed wiring is not Code, fwiw. Just make sure your wires are fused/breakered to the correct current, and your grounds and neutrals are correct. That stuff can kill.
Old 12-01-2011, 11:00 PM   #15
wtd
wtd's Avatar
Year: 1982
Because everything that comes off the battery must be fused. Even if the inverter was a big one like bus-bro mentioned and required it's own separate fuse, you'd still need a fuse block (or breakers)to provide protection for the other DC circuits - lights, pumps and whatnot.
Yup, you'd just run wire one end of a cable to the breaker box and put a plug on the other. That way, you're running off of the inverter when plugged into it and if you want to connect to shore power or a generator just unplug from the inverter and plug into the other power source. It's simple, but it has one outstanding benefit - idiot proofness - no way to connect to two AC sources at the same time or to connect them to each other. Nothing like connecting the output of a 5000 watt generator to the output of a 700 watt inverter to brighten up an otherwise dull evening.
Mine's a little more complicated, I built a transfer switch that automatically switches the AC circuits from the inverter to the generator when I start the generator and switches back when I shut the generator down. But if I use shore power, I just do the unplug thing.
I've never seen one like this, but if you had one you'd just wire it in instead of using the plug. You'd have to figure out some other way to provide the inverter/shore power option tho', since the plug would be gone. I'd imagine the device itself would provide some means for that.
If the wind knocks down some tomorrow I'll get out and get a coupla decent pictures and do the 'Alice's Restaurant Littering Trial' thing them with circles and arrows and everythin' else and put 'em up to 'splain some more about the AC stuff. I didn't get everything in the shot I took today that I needed to make a good explanation.
Tom
Where DIY meets WTF
Old 12-02-2011, 11:57 PM   #16
Rated Cap: 60
For me??? You're too kind!
Old 12-03-2011, 09:29 PM   #17
wtd
wtd's Avatar
Year: 1982
Pour tu -
This is my lash-up
Power comes into the box on the bottom from the generator - over to the breaker box.
From there, there's 2 circuits - the lower one (#2) is just for the water heater, it pulls ten amps.
Everything else is powered from one 15 amp circuit. The top box - AC zips out of there to the transfer switch thence into the bus, where it's distributed to 7 outlets spread all over the place.
If you're a person looking for a code or regulation to follow - but if you're gonna read it, but read the whole thing - including this -
From page 2 of the code -
"In issuing and making this document available, the NFPA is not undertaking to render professional or other services
for or on behalf of any person or entity. Nor is the NFPA undertaking to perform any duty owed by any person or entity
to someone else. Anyone using this document should rely on his or her own independent judgment or, as appropriate,
seek the advice of a competent professional in determining the exercise of reasonable care in any given circumstances."
"The NFPA has no power, nor does it undertake, to police or enforce compliance with the contents of this document.
Nor does the NFPA list, certify, test or inspect products, designs, or installations for compliance with this document.
Any certification or other statement of compliance with the requirements of this document shall not be attributable to
the NFPA and is solely the responsibility of the certifier or maker of the statement."
They pretty much urge you to use some judgement in applying this code rather than just blindly following it. There lotsa things to take into consideration, the NEC is just one of them. For example, I have 7 15 amp duplex outlets on one 15 amp branch circuit - this probably is way than than the code 'allows' - I don't know, I've never checked - but I'll never overload them, I understand the limitations and won't exceed them. Yes, it is possible that while I'm passed out drunk on the couch that some maniac with an obsession for omelets and curly hair may sneak in with a duffel bag of electric frying pans and curling irons, plug them all in and fry and curl us into a pile of ashes - I'll take the risk.NOthinhg wrong with the NEC, it's something to consider.
The portion specific to RV's is Article 551.
Well, so much for my ramblngs on the NEC - everybody's got their own point of view I reckon.
If you look at my system, complies with the NEC in some places. Here's a few 'fer instance's
Looking at the wiring from the generator to the receptacle box -
NEC Article 551.30
(E) Supply Conductors. The supply conductors from the engine generator to the first termination on the vehicle shall
be of the stranded type and be installed in listed flexible conduit or listed liquidtight flexible conduit. The point of
first termination shall be in one of the following:
(1) Panelboard
(2) Junction box with a blank cover
(3) Junction box with a receptacle
(4) Enclosed transfer switch
(5) Receptacle assembly listed in conjunction with the
generator
Swing and a miss on the conduit. Outta the park on the termination, 551.30(e)(3).
For the supply from the generator termination to the breaker box (panelboard in the NEC) ,. we fail miserably - because it's assembled improperly or inadequately?
551.46 Means for Connecting to Power Supply.
(A) Assembly. The power-supply assembly or assemblies shall be factory supplied or factory installed and be of one
of the types specified herein.
(1) Separable. Where a separable power-supply assembly consisting of a cord with a female connector and molded
attachment plug cap is provided, the vehicle shall be equipped with a permanently mounted, flanged surface inlet
(male, recessed-type motor-base attachment plug) wired directly to the distribution panelboard by an approved wiring
method. The attachment plug cap shall be of a listed type.
(2) Permanently Connected. Each power-supply assembly shall be connected directly to the terminals of the distribution
panelboard or conductors within a junction box and provided with means to prevent strain from being
transmitted to the terminals. The ampacity of the conductors between each junction box and the terminals of each
distribution panelboard shall be at least equal to the ampacity of the power-supply cord. The supply end of the assembly
shall be equipped with an attachment plug of the type described in 551.46(C). Where the cord passes through the
walls or floors, it shall be protected by means of conduit and bushings or equivalent. The cord assembly shall have
permanent provisions for protection against corrosion and mechanical damage while the vehicle is in transit.
No - we hit 551.46(2) like a ton of bricks (except our plug doesn't look like their picture), but we fail on 551.46(A), I made the cable - it's not "factory supplied or factory installed " So for goodness sakes, don't go making any cables out there!
Anyhow, that's my system as I mentioned I'd post yesterday - won't win andy friends among the code zealots, but ... c'est la vie ...we each have our won bus.
Tom
Where DIY meets WTF
Old 12-03-2011, 11:07 PM   #18
Rated Cap: 60
Originally Posted by wtd
Pour tu -
This is my lash-up
NEC Article 551.30
(1) Panelboard
generator
Tom
Yeah.....nice details.....what a FILE of codes!!! But all of your visuals help me...(as we like to say in the south) "im wunna dem kEn'esthetic lurners." Your advise has helped me to better consolidate out plan and complete it in a orgnaized fashion (something i sometimes fail to employ.) Thanks so much for your help....ill keep you posted once i go do some measurements and calculus!!
And....when are they gonna start making some of you sayings into T-shirts to sell under apparel on Skoolie???/
"Yes, it is possible that while I'm passed out drunk on the couch that some maniac with an obsession for omelets and curly hair may sneak in with a duffel bag of electric frying pans and curling irons, plug them all in and fry and curl us into a pile of ashes "
That shits gold!
Old 12-04-2011, 10:44 AM   #19
Year: 1986
Rated Cap: 89
... So does the intillipower reallyy charge, or is it a false claim like some other inveters use?? Thanks!
Yes, it really works. And it's a smart charger, so we won't fry the batteries. The Intelli-power outfit (Progressive Dynamics) makes decent inverter, chargers, etc. But do your own research before you take my word on it. Be a smart consumer, ALWAYS research before you buy. We did a break down on the pricing and decided that it is cheaper to buy the Mighty Mini than everything separately . Plus everything is in one neat box and since I am putting the panel box inside the living quarters of the bus, that was also a plus.
Fulltime since 2006
Old 01-31-2012, 10:05 PM   #20
Rated Cap: 60
Hi Lorna!
I was perusing our inverter discussion, after doing some frame work on the bus, and have decided to use the intelli power system. Thus, i was curious as to what type and number of batteries you were using in your system (Basically you set up) ? As i read some horror stories about certain batteries not taking kindly to the intelli power's charging cap. Any info would be great!
thanks,
-jake
Need opinions on two potential bus's topfrog007 Conversion General Discussions 2 05-24-2011 10:58 AM
Opinions on bus, please Seeria Conversion General Discussions 2 12-05-2010 10:41 AM
Opinions on a bus kwest48 Conversion General Discussions 14 08-16-2010 09:06 PM
Your opinions? paul iossi Conversion General Discussions 15 07-23-2009 08:34 AM
Correct Oil Pressure cooter Everything Else | General Skoolie Discussions 6 01-09-2007 01:10 PM
