Old 03-01-2012, 02:39 PM   #1
Chassis: Genesis
Engine: Dt40
Help: Need a wiring diagram
I need to charge the main bus batteries (2) and a deep cycle in the rear from the bus alternators or from a gas powered 12vd generator I put together with a honda motor and an alternator. Here's how it should work:
- When bus is running: alternator should charge both front and rear batteries
- When Generator is running: it should charge the batteries
- If generator nor bus running: isolator should protect main batteries from being run down.
I am unsure what needs to go to chassis ground, vs negative battery terminal, etc. Can someone connect the dots for me?
Here's the manual for the battery isolator: http://www.abt.com/documents/39744/PAC200_manual.pdf
And here is the diagram for the stereo system, if anyone needs to see that:
Thanks in advance. I was hoping to finish this wiring tonight.
bhays is offline   Reply With Quote
Old 03-01-2012, 03:47 PM   #2
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
Re: Help: Need a wiring diagram
Assuming the alternator and generator would play well together, I would set it up like the schematic below. If there is an issue with the generator not being isolated from the alternator, you would need another isolator.
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 03-01-2012, 04:13 PM   #3
Here is another route,lots of ways to use solinoids some controlled by oil pressure switch etchttp://www.expeditionportal.com/foru...r-installation
Old 03-02-2012, 03:52 AM   #4
don't forget you can buy normally ON soliniods as well.
Old 03-02-2012, 07:04 AM   #5
Chassis: Genesis
Engine: Dt40
[quote="TheRainbowBoxer"]Assuming the alternator and generator would play well together, I would set it up like the schematic below. If there is an issue with the generator not being isolated from the alternator, you would need another isolator.[/quote
Do you see any problem wherein the generator would backfeed or cause problems with the alternator? (in reality it's just two alternators. One is on the bus engine, the other on a small gas engine)
Also, the switch you show on the ground side of the isolator, is that necessary? My intent was that any time the generator or bus alternator was providing power, the system would be open to all 3 batteries.
Thanks!!
Old 03-02-2012, 07:57 AM   #6
The problem with setting up the system so it intelligently knows the alt or gen is running will require a way to isolate this input from the batteries' voltage. This will involve more components (2 diodes) then you listed and be more complicated. In the setup below you would need to take the switch out of the ground side of the relay and hook the "relay disconnect" lead from the alt and gen to the other side of the isolator's relay.
*Edited to add* I can't think of any reason the alternators would not work together... but I have never set something like that up, so YMMV.
-Dan
adjective
Old 03-02-2012, 09:55 AM   #7
Chassis: Genesis
Engine: Dt40
Any specific value on the diodes?
Old 03-02-2012, 10:18 AM   #8
The information provided for the battery isolator/relay shows that the relay coil pulls less than 1 amp. I would say that a 1 amp diode would probably withstand the power necessary.
-Dan
adjective
Old 03-09-2012, 08:21 AM   #9
I was just re-examining the schematic I posted and saw a backfeed problem... The truck batteries will feed back and keep the isolator connected... Grrr. I think you will need to use a manual disconnect like the first schematic. Sorry for the oversight.
-Dan
adjective
Bluebird Wiring Diagram Tinez Everything Else | General Skoolie Discussions 3 05-25-2019 10:42 PM
wiring diagram source? syke Conversion General Discussions 3 05-13-2014 08:09 AM
Wiring Diagram El Mastodonte Conversion General Discussions 0 07-25-2010 12:45 PM
Wiring Diagram 1981 IH school bus jerhutch Conversion General Discussions 4 08-20-2008 09:45 AM
Need wiring diagram or source for same frank-id Classifieds | Buy, Sell, Swap 1 11-18-2007 10:41 PM
