Old 03-15-2012, 09:26 PM   #1
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
Re: DEAD BUS?
I would take a multimeter and keep checking voltage tracing the wiring until you find where it stops. At least then you can narrow down the location. Check your ground.
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 03-16-2012, 12:15 AM   #2
Stuff's Avatar
Re: DEAD BUS?
my bet is on the second battery. probably dead to
Old 03-16-2012, 10:40 AM   #3
syke's Avatar
Chassis: All American RE
Re: DEAD BUS?
What stuff said....
11.7 volts is roughly 35% state of charge. Either replace the other battery or charge them both. Try using a quality 3 stage charger.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 03-16-2012, 11:09 AM   #4
Re: DEAD BUS?
i guess first you should tell us if you have any other power on the bus. if other stuff works good like the lights, for example, then maybe it is in the starting circuit.
Old 03-17-2012, 10:51 AM   #5
Re: DEAD BUS?
After a while you ARE a bus mechanic...
Old 03-17-2012, 02:19 PM   #6
syke's Avatar
Re: DEAD BUS?
Glad you got it figured out.
Ryan
Old 03-17-2012, 02:26 PM   #7
Stuff's Avatar
Re: DEAD BUS?
with tandem batteries it always seems to be both are the problem. never one makes i more expensive lol
Dead battery Raw Slaw Conversion Tutorials and How-to's 25 05-22-2016 09:27 PM
Not to beat a dead horse..... Sojakai Conversion General Discussions 3 08-13-2009 08:57 AM
SO Bummed out! Bus is dead..... GoneCamping Conversion General Discussions 91 08-07-2009 04:27 PM
Am I dead? temp Forum Admin | Account Help | Suggestion Box 1 06-20-2007 03:57 PM
Off to a Dead Start davido Skoolie Conversion Projects 6 08-21-2006 11:15 PM
