Old 10-10-2012, 09:20 PM   #1
Engine: Cummins 5.9
1997 Bluebird TC1000 Alternator
Hello all,
I'm a mechanic but new to buses. I just volunteered to help out with our church bus maintenance. One problem we're having right now is the alternator is putting out only 12 volts and the battery is going dead. The alternator was replaced about a year ago (before I got involved) and it looks like the wrong one was installed. This is on a '97 Bluebird TC1000 with the Cummins 5.9. They also have a '92 TC2000 with the same engine. After comparing the two it looks like the alternator they put in the '97 is a three wire and the wrong one. The chassis harness is a four wire, they just didn't connect the tach wire. I'm trying to figure out what the correct alternator is to be installed. I'm going to try to get some numbers from the alternator in the '92 when I get a chance, but all I can do is assume that is the correct alternator. Any assistance in figuring out the correct alternator for the '97 would be greatly appreciated.
Thanks for your time.
Gollum86 is offline   Reply With Quote
Old 10-11-2012, 09:06 AM   #2
Re: 1997 Bluebird TC1000 Alternator
on mine 97 w/5.9 it has some "special" alt. or I was told by bus company I bought it from.
Mine starts on 1/4 of a crank so not much battery is used to start it.
with everything electrical off and engine idling mine reads 12.4/6 or so
It doesn't charge until I put a load on it;if I turn on park lights, or interior lights
It charges at about 13.9 or alittle higher if more load on it, so the more load the more it charges.
Mine has always started no matter what I have done
Not sure if that helps or not, just info
I will look at mine and let you know
99 TC1000 "The Struggle Bus" miniman Skoolie Conversion Projects 43 04-14-2017 10:46 PM
1997 IHC/AmTrans 4x4 bus cowlitzcoach Classifieds | Buy, Sell, Swap 11 01-06-2015 10:12 AM
BB TC1000 owners dond Everything Else | General Skoolie Discussions 2 10-16-2014 04:56 PM
1997 Bluebird TC2000 Turbo 8.3L cazzthespazz Classifieds | Buy, Sell, Swap 3 04-15-2014 12:00 PM
1997 Bluebird Transhuttle drew2222 Skoolie Conversion Projects 3 04-07-2012 06:37 PM
