Old 08-31-2014, 07:56 PM   #1
Year: 99
Coachwork: ford
wiring my box truck
Hello there!
For some reason the search bar isn't working for me in the forums, so I'm about to ask questions that I know there are millions of answers to on the site... sorry! I'm having trouble navigating the forum.
I have four t-105s (trojan deep-cycle golf cart batteries). I'm about to begin wiring my dc system, which I feel fairly competent about doing. However I'm stuck on the first step- I don't know what gauge wires to use!
I'm running LED lights, a flojet water pump, a dc outlet to charge my phone, and a small fan that vents the battery box. I have an iota dls-55 converter/charger and a very simple fuse box.
I won't have a refrigerator or microwave or air conditioner... nothing will be running all the time.
Anyways, thanks for your time! The link for photos is below!
http:/boxtruckdreams.wordpress.com
conversionFUN is offline   Reply With Quote
Old 09-02-2014, 02:57 PM   #2
Year: 99
Coachwork: ford
Re: wiring my box truck
I got 12 gauge stranded high heat wire. Should be alright...
Old 09-03-2014, 08:50 AM   #3
Chassis: B3800 Short bus
Rated Cap: 36
This is a great online calculator to determine cable size: http://www.solar-wind.co.uk/cable-sizing-DC-cables.html
I use it all the time. Input the highest amperage (combining possible loads) per wire run and the length of the run and click calculate. You'll want to stay within 1-3% acceptable loss.
My guess is that your pump will be rated at around 5 amps and the phone charger around 1 amp. You'll have to figure out the LED draw and add them together.
Using this tool I was able to calculate all of my runs for an acceptable loss of 1%. This required using 8awg wire.
Old 09-03-2014, 11:33 AM   #4
if you use google you can: skoolie.net + wire , or skoolie.net + wiring
that's how I search web sites...probably a newer way to do it
the leds and fan (assume 12v computer fan), and a charger port wont pull crap for amps (maybe 2 or 3 total) you can use really small wire here
the sureflow will be your biggest draw (5-10 amps guess)
the Iota 55 amp convertor will give you 55 amps of usable 12v when plugged into 120V
why so many batteries, for those loads?
a big invertor for 120v?
Old 09-04-2014, 08:23 AM   #5
Coachwork: International/Thomas
Chassis: 3700
Engine: 7.3
Rated Cap: 73
Are you talking about hooking up the batteries together and with a charger or are you talking about hooking up just lights and other stuff that uses the power.
If possible be sure to use a bus bar for the the batteries, it will help them get equal charge and it is a convenient way to hook up the chargers/inverters/fuse boxes.
When hooking up the batteries I would say find the correct size for a 1% loss then go one bigger if possible.
My conversion thread, viewtopic.php?f=9&t=466746
BUBB is offline   Reply With Quote
Bus as tow truck? stonestatue Conversion General Discussions 13 12-21-2019 10:27 PM
box truck conversion somewhereinusa Conversion General Discussions 22 01-24-2018 08:45 PM
wiring to truck camper ? alwaysFlOoReD Conversion Tutorials and How-to's 1 05-13-2014 03:38 PM
Off topic Big big truck frank-id Everything Else | General Skoolie Discussions 2 03-22-2013 07:33 PM
Towing a 4x4 truck (small truck) 4 down Abbott Everything Else | General Skoolie Discussions 13 12-31-2009 02:05 AM
