Old 12-17-2012, 01:18 PM   #1
Brake Pressure Warning buzzer?
1986 bluebird international 7.3 8 cyll.
Electrical brakes.
The batteries were allowed to drain, however upon recharging the Brake Pressure Warning light goes on at intermittent times.
The brake lights are all fine,
What is the Brake Pressure Warning light telling me?
Jaybus is offline   Reply With Quote
Old 12-17-2012, 02:07 PM   #2
GreyEagle's Avatar
Re: Brake Pressure Warning buzzer?
If it has AIR BRAKES.... It's telling you . low air pressure do not drive!!!
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 12-17-2012, 02:53 PM   #3
Its stated on the dash its electrical brakes. Also when I registered it it was not air.
I know what its telling me, but how can I track a short and or how do I deal with a random flickering light.
I know nothing is actually wrong, its flickering like crazy.
Also the bus was sitting for 2 years.
Id at least like some info on how or where to look, im told this is common when the lights are either out or rusty and also a relay can go out often.
I'm no expert and the bus stops fine.
Was wondering if the dash panel should be taken off and checked for corroded wires or where the relay is located?
Thanks.
Old 12-17-2012, 03:52 PM   #4
is it the same light for the parking brake?maybe the release isn't set all the way
Old 12-17-2012, 04:08 PM   #5
GreyEagle's Avatar
Possible wheel brake sensor ....????
I'll just pulling straws and taking wild guesses. here....
GreyEagle
Roll - On...
Old 03-20-2013, 09:11 PM   #6
Moderator
crazycal's Avatar
Chassis: 3800
Engine: DT408, AT545
Rated Cap: 23 500 gvw
You should move this to mechanical section.
I'm hungry!
You Gotta Let Me Fly
Buzzer electrical Six Four Mechanical and Drivetrains 2 05-01-2013 09:58 PM
wheel bearings getting warm ? buzzer going off GoneCamping Mechanical and Drivetrains 3 10-13-2009 11:15 AM
Brake Pressure light.. colliervilledave Conversion General Discussions 6 07-23-2008 10:12 PM
Brake Question Warning Light quizbus Conversion General Discussions 0 03-24-2008 07:49 AM
? BB TC2000 arm rest buzzer Elliot Naess Everything Else | General Skoolie Discussions 6 04-10-2007 12:04 AM
