08-11-2012, 05:41 PM
Chassis: international
2000 international
I have a 2000 international 3400 with a 7.3 liter i want to put a cummins in it, anyone know of anything that will prevent this from happening, i haul a race car trailer and need more power. thanks
08-11-2012, 06:54 PM
Moderator
Chassis: 3800
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Re: 2000 international
Yes, how much you want to spend.
08-11-2012, 07:51 PM
As little as possible, we have the motor to put in to it. They both are automatics also. what do i need that expensive
08-12-2012, 03:37 AM
Moderator
Chassis: 3800
Do you have the correct motor mounts, linkages, plumbing, trans adapter? Will the trans have to be moved back to fit the engine? If yes, the driveshaft will need to be shortened. If you have the parts already, it shouldn't be too bad. If you need to buy parts, it adds up quick.
08-13-2012, 10:27 AM
Motor mounts and trans mounts can be easily fabbed, and even driveshafts built if ya phase them correct and check the balance. I have found that it often takes as much time to mount oil coolers and/or build a new core support for a larger radiator, than making mounts.
Also the exhaust pipes have to be mig welded, fuel lines run, etc.
Changing a diesel engine i think, is easier than putting in a modern drive train in an old car.
I am not an expert on that either, since it was like 1966 when i built my first car frame, etc for the drags.
ol Trunt is the expert...
08-13-2012, 11:34 AM
We are a full service repair shop and junk yard, so we have access to alot of parts, lol lol, we build our own race cars so if we have to fab something up it should be no problem. We just didnt know what the major road block would be, our 7.3 is getting tired, and the cummins is barely broke in. Thanks for any help and advice
08-13-2012, 11:36 AM
So that answers alot...yes it will work go for it.
Worst case maybe have to push motor back to keep it out of the radiator....
Make sure to post pics
02-02-2013, 12:11 PM
I rember reading about a kit u can get to swap out 7.3 out of a f250 and replace it with a 5.9 cum-a-part motor
google it you should find it.
08-29-2013, 07:13 PM
Coachwork: ElDorado
Chassis: Chevy P30
Engine: 7.4 liter 454 Chevy
Rated Cap: 24
Reason there is some dislike for the 5.9 is what is called the "dowel pin of Death"...
Before a mod was done a dowel pin in the timing gear area would come out and eat the gears and bust the timing cover.
09-06-2013, 01:21 AM
Moderator
Chassis: 3800
More cubes is better.
09-06-2013, 07:34 AM
I love my setup, but an 8.3 and an MD3060 would be my dream combo
Brutus
09-06-2013, 08:29 AM
Engine: 3126
Here, here, but I had to settle for a 7.2 and a MD3060
09-06-2013, 11:35 PM
So jealous of your transmission, lol... Someday I may swap mine out. But probably not
Brutus
09-12-2019, 09:31 PM
Coachwork: IC/AMTRANS RE
Engine: T444E 7.3 w/ MD3060
Rated Cap: 36000lbs / 78pass / 39'
If you are going through all that hassle you will be let down if you throw a 5.9 in there, better make it the good ol 8.3 Cummins. OTHERWISE just throw some money at that 7.3 and it will make you happy, some fuel sticks and turbo upgrade will make plenty of long term power. Make sure you keep that trans cool and if it's an AT545 then you might want to consider a trans swap more than the engine swap since you are pulling weight, something like a Allison B300 or MD3060....
If you would like to check out my website that has all sort of information especially for the T444E/7.3PSD engines check out www.PatrickTheSalvageGuy.com I've got helpful downloads and articles as well as a link to my YT for other how to videos mainly on the F series trucks.
09-13-2019, 04:13 PM
Mine too
09-13-2019, 04:18 PM
If you want a bus with a 5.9 you can buy a whole bus with a 5.9 already in it for less than the cost of swapping engines.
I generally agree with the comment above regarding displacement in this case I would take the 5.9 over the 7.3. I have a strong preference for I6's over V8's.
