Old 08-11-2012, 05:41 PM   #1
Chassis: international
2000 international
I have a 2000 international 3400 with a 7.3 liter i want to put a cummins in it, anyone know of anything that will prevent this from happening, i haul a race car trailer and need more power. thanks
vgearhead is offline   Reply With Quote
Old 08-11-2012, 06:54 PM   #2
Moderator
crazycal's Avatar
Chassis: 3800
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Re: 2000 international
Yes, how much you want to spend.
I'm hungry!
You Gotta Let Me Fly
Old 08-11-2012, 07:51 PM   #3
As little as possible, we have the motor to put in to it. They both are automatics also. what do i need that expensive
Old 08-12-2012, 03:37 AM   #4
Moderator
crazycal's Avatar
Chassis: 3800
Do you have the correct motor mounts, linkages, plumbing, trans adapter? Will the trans have to be moved back to fit the engine? If yes, the driveshaft will need to be shortened. If you have the parts already, it shouldn't be too bad. If you need to buy parts, it adds up quick.
I'm hungry!
Old 08-13-2012, 10:27 AM   #5
Motor mounts and trans mounts can be easily fabbed, and even driveshafts built if ya phase them correct and check the balance. I have found that it often takes as much time to mount oil coolers and/or build a new core support for a larger radiator, than making mounts.
Also the exhaust pipes have to be mig welded, fuel lines run, etc.
Changing a diesel engine i think, is easier than putting in a modern drive train in an old car.
I am not an expert on that either, since it was like 1966 when i built my first car frame, etc for the drags.
ol Trunt is the expert...
Old 08-13-2012, 11:34 AM   #6
We are a full service repair shop and junk yard, so we have access to alot of parts, lol lol, we build our own race cars so if we have to fab something up it should be no problem. We just didnt know what the major road block would be, our 7.3 is getting tired, and the cummins is barely broke in. Thanks for any help and advice
Old 08-13-2012, 11:36 AM   #7
So that answers alot...yes it will work go for it.
Worst case maybe have to push motor back to keep it out of the radiator....
Make sure to post pics
Old 02-02-2013, 12:11 PM   #8
I rember reading about a kit u can get to swap out 7.3 out of a f250 and replace it with a 5.9 cum-a-part motor
google it you should find it.
Old 08-29-2013, 07:13 PM   #9
Coachwork: ElDorado
Chassis: Chevy P30
Engine: 7.4 liter 454 Chevy
Rated Cap: 24
Reason there is some dislike for the 5.9 is what is called the "dowel pin of Death"...
Before a mod was done a dowel pin in the timing gear area would come out and eat the gears and bust the timing cover.
Bullwhacker007 is offline   Reply With Quote
Old 09-06-2013, 01:21 AM   #10
Moderator
crazycal's Avatar
Chassis: 3800
More cubes is better.
I'm hungry!
Old 09-06-2013, 07:34 AM   #11
JakeC's Avatar
I love my setup, but an 8.3 and an MD3060 would be my dream combo
Brutus
Old 09-06-2013, 08:29 AM   #12
wmkbailey's Avatar
Engine: 3126
Here, here, but I had to settle for a 7.2 and a MD3060
William
https://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 09-06-2013, 11:35 PM   #13
JakeC's Avatar
So jealous of your transmission, lol... Someday I may swap mine out. But probably not
Brutus
Old 09-12-2019, 09:31 PM   #14
PatrickBaptist's Avatar
Coachwork: IC/AMTRANS RE
Engine: T444E 7.3 w/ MD3060
Rated Cap: 36000lbs / 78pass / 39'
If you are going through all that hassle you will be let down if you throw a 5.9 in there, better make it the good ol 8.3 Cummins. OTHERWISE just throw some money at that 7.3 and it will make you happy, some fuel sticks and turbo upgrade will make plenty of long term power. Make sure you keep that trans cool and if it's an AT545 then you might want to consider a trans swap more than the engine swap since you are pulling weight, something like a Allison B300 or MD3060....
If you would like to check out my website that has all sort of information especially for the T444E/7.3PSD engines check out www.PatrickTheSalvageGuy.com I've got helpful downloads and articles as well as a link to my YT for other how to videos mainly on the F series trucks.
PatrickBaptist is offline   Reply With Quote
Old 09-13-2019, 04:13 PM   #15
Mine too
Old 09-13-2019, 04:18 PM   #16
If you want a bus with a 5.9 you can buy a whole bus with a 5.9 already in it for less than the cost of swapping engines.
I generally agree with the comment above regarding displacement in this case I would take the 5.9 over the 7.3. I have a strong preference for I6's over V8's.
2000 international w/7.3 diesel beaver Skoolie Conversion Projects 10 06-09-2013 06:55 PM
1993 International Blue Bird $2000 Castro Classifieds | Buy, Sell, Swap 3 09-03-2009 09:44 PM
TC-2000 AND ALL AMERICAN 1993bluebird Everything Else | General Skoolie Discussions 1 04-22-2008 09:54 AM
TC 2000 dlor1 Classifieds | Buy, Sell, Swap 0 07-03-2007 12:15 PM
Pablo TC 2000 captainkf Skoolie Conversion Projects 9 03-26-2007 08:23 AM
