Old 10-24-2013, 02:39 PM   #1
Coach Work combination
Would like to hear opinions on the concept of combining two bodies.
Concept is to take rear 3rd of body off of a rear engine bus and place it on a front engine bus.
Thus allowing for huge amounts of outside storage and gaining a side exit.
Is this possible? I am thinking that as long as the buses were from the same manufacturer and year the wall height and ceiling curvature should match.
KyTireKicker is offline   Reply With Quote
Old 10-24-2013, 09:31 PM   #2
Re: Coach Work combination
I must not be seeing something. If you want a dog nose with more space then buy a longer dog nose?????
Old 10-24-2013, 09:47 PM   #3
I have been trying to see what I am missing here as well.... I don't get either.../shrug
Malkieri is offline   Reply With Quote
Old 10-25-2013, 08:08 AM   #4
The idea is to create some rear storage similar to the old crown mid engines. I am not trying to add length.
Old 10-25-2013, 08:38 AM   #5
I am trying to create a storage area similar to the crown midengine body. Really not wanting to extend length.
Old 10-25-2013, 06:23 PM   #6
Wouldn't it be a TON easier to just build a box inside and seal the top half of the rear door? You could even lower the floor between the frame rails if you wanted to get crazy. I would think trying to combine 2 buses would be WAY more work and effort and $$.
Old 10-27-2013, 08:38 AM   #7
I dont know that it would be any easier. That's part of the overall question. Would be doing a roof raise anyway. Once the grinder and welder are involved I am not a good judge of what is the "easiest way". I like the full width window across the rear bedroom wall. Need a firewall of some sort between a large battery array for the solar and the interior anyway. If the batteries go in a belly box then I have large under bed / bedroom storage for the bikes (4 pedal type + a tandem). Just looking for someone who has chopped a body or reworked the rear end of a body for advice. Don't want to reinvent the wheel. Hoping to cover the bases before choosing a bus. Of course if any one knows a good supply of the Crown's please speak up. Local diesel mecanic shop has acess to crated rebuild that fits well.
Old 10-27-2013, 04:39 PM   #8
Moderator
crazycal's Avatar
Chassis: 3800
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Mixing drugs is a bad thing. Haha, just kidding. Anything is possible with enough time and money.
I'm hungry!
You Gotta Let Me Fly
Old 10-28-2013, 07:58 AM   #9
bikes take up a lot more room than you would think, the more you take them apart the less you will ride them
with front tires removed and handlebars turned the pedals are the widest part and 2 bikes will need 30 inches x about 60 inches for storage (this is one reason we are looking at different options to get them out of the garage/bedroom
possible be on back porch area with spare tire
4 bikes and a tandem is a lot of space
Old 10-28-2013, 08:36 AM   #10
Bikes
Yes the bikes are a lot of space. We usually remove pedals and turn the stem. I don't like removing tires beacuse it means adjust the brakes. Back on topic. Has anyone done major alterations to a body other than a roof raise and door relocation?
Old 10-28-2013, 08:54 AM   #11
not on a bus...body work is body work (a bus just has a lot more of it)
cut roofs off cars to chop and off trucks to build cages etc
measure cut and reattach lots of big chunks to move around
if bodies are from same manufacture and same year and same factory build outside will be similar
JUST REMEBER THIS:
dog noses will have a body on a frame, take bolts loose and body can come off (you have a 40' frame)
a rear engine normally doesn't have a "frame rail" all the way back like a FE bus
so it will be 100% custom frame setup from wheels back..........the outside body work would be a breeze compared to that headache
Old 10-28-2013, 08:48 PM   #12
Yup, I have.
Old 03-03-2014, 06:40 AM   #13
That is a very interesting idea. I like the concept.
Is sectioning a body in your skill set? I think sectioning of same make bodies would easier than building storage, as long as you are comfortable with your skills to do so. Full frame buses make sectioning a body pretty easy work if you know how to do the attaching and final body filler work.
Have you made any further decisions on this?
Deezl Smoke is offline   Reply With Quote
Old 03-21-2014, 01:57 AM   #14
Coachwork: ElDorado
Chassis: Chevy P30
Engine: 7.4 liter 454 Chevy
Rated Cap: 24
If you have money Lots of it by the pound go for it. It would be cheaper to get a 72 passenger bus and swap in a larger engine..
I am also curious why you need 2000lbs. of torque to climb passes?
I used to drive a Freight liner with a big Cat in it and could pull a pass at any speed I wanted; BUT you could and some did burn the tread off of the tires from the torque with a full 80,000lb. load.
Bullwhacker007 is offline   Reply With Quote
Combination Package Alaska Stepvan Conversion General Discussions 9 03-29-2014 09:56 PM
coach-net gbstewart Everything Else | General Skoolie Discussions 4 03-18-2013 07:35 PM
DIY combination potty/shower? Jaybus Plumbing, Water and Waste 2 08-09-2012 10:39 PM
Coach Seats 64BPoquonock Conversion General Discussions 0 06-07-2011 08:19 PM
questions about your coach work? delbertinie Everything Else | General Skoolie Discussions 0 09-06-2007 06:35 PM
