Old 06-24-2013, 01:56 PM   #1
wmkbailey's Avatar
Engine: 3126
MD 3060 transmission 6th gear
My bus comes with the MD 3060 5 speed. I have read that it can be programed with another OD making it a 6 speed.
Anyone do this and is it worth it? The bus manager says the bus makes 65 mph easily. I did not know if the extra OD would help with gas milage.
William
https://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 06-27-2013, 01:40 PM   #2
JakeC's Avatar
Re: MD 3060 transmission 6th gear
If it were me, I would want the 2nd overdrive. You gain the ability to cruise at a lower rpm and can always downshift if needed. I would think you would gain some economy. Also, just checked out your blog. Good luck with the auctions...exciting!!!
Brutus
Old 06-27-2013, 02:26 PM   #3
wmkbailey's Avatar
Engine: 3126
Thanks JakeC,
I'm hunting down an Allison Certified mech in the area to see what it would require and cost.
Edit
Just talked to an Allison Certified Mechanic and they said that the transmission is setup and geared for the weight of the bus, matched to the engine and cannot be changed. I think they ment should not be changed. I have been told it can be if you can find someone willing to do it.
Maybe it is better left alone.
William
Old 06-27-2013, 02:34 PM   #4
GreyEagle's Avatar
My last Diesel pusher, 40 ft motorhome with slideout, loaded to the max only got 9-10 MPG on the highway......
It was an MD 3060 six speed. while it will help it won't be a big enough improvement to pay for the upgrade unless you stay on the road.
I have nno idea what you get now....... but just saying...
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 06-27-2013, 02:45 PM   #5
Chassis: Blue Bird
Engine: ISC 8.3
My B300R is similar in that the equipment has a 2nd overdrive ratio, but the control is programmed for only 5-speed operation. With 11R22.5 rubber and 5.38 axle my engine turns around 2500 RPM at 75 MPH. According to The Internet, yours and mine probably have the same OD ratios (0.75 5th and 0.65 6th). My gut feel at the throttle pedal is that my engine may have enough grunt to hold 65+ MPH, at least on flat highway, even in the 2nd OD. With my gearing I'd see ~2170 RPM at 75 MPH or ~1900 RPM at 65 MPH. That would surely pay dividends at the fuel pump!
Per my Allison dealer (Smith Power Products) it's an Allison policy their dealers must not make such changes without written approval from the OEM. I worked through my Blue Bird dealer and made contact with a support engineer (just a week ago) at Blue Bird who incidentally did power train engineering for BB in the past.. Anyway, he couldn't locate any matching already-engineered combination for me (looking for Cummins ISC 8.3, 5.38 axle, B300R 6-speed) and so couldn't give approval.
So.. I guess I'm stuck for now. Maybe some day I'll pursue getting Allison to let me assume the risk and just make the change. Smith told me that, assuming approval could be found, they'd be in the $150 range to change the programming.
Last trip out I did about 9.3 MPG over 220 miles including climbing from 4500 ft to 9650 ft elevation and back down again. More is always welcome of course, but I guess this isn't terrible either. Glad I didn't get a DD 8V92 engine with its estimated 5-6 MPG!
family wagon is offline   Reply With Quote
Old 06-27-2013, 02:53 PM   #6
JakeC's Avatar
Originally Posted by wmkbailey
Thanks JakeC,
Edit
Yeah, some things just aren't worth the hassle, and if Grey Eagle is correct, it may not be that big of a benefit anyway. I wouldn't think about it too much until you've gotten the bus and have a feel for it.
Brutus
Old 06-27-2013, 03:02 PM   #7
wmkbailey's Avatar
Engine: 3126
Thanks family wagon,
I have the same OD ratios (0.75 5th and 0.65 6th). The school maintenance manager said these buses are averaging about 10 mpg. We will see how it goes.
I'm not sure what my top end will be, he said they are governed to 2400 rpms, so maybe 70 mph. I know at 60 mph it is at 2000 rpms, that would put me at 71.5 mph at 2400.
William
Old 07-29-2013, 08:43 PM   #8
Coachwork: Ward Genesis
Engine: DT466/MT643
Wow, that bus is geared for the city! 2500 for an 8.3 Cummins is SCREAMING! Isn't it GOVERNED around there?! You would DEFINITELY benefit from the second OD!
My Genesis has an MT643 (non-OD) and 4.11's...1900RPM at 60.
Jarlaxle
Optimism is a mental disorder.
Jarlaxle is offline   Reply With Quote
Old 07-29-2013, 10:10 PM   #9
opus's Avatar
Chassis: All-American R/E
Mine is governed at 2600. I would terrified at the speed I would be doing at that rpm! Mine is the same as yours, about 62@2000
Old 07-30-2013, 05:42 AM   #10
I think 75 is a little too fast in a bus...have fun stopping in a hurry; it always scares me on interstate seeing big class A's running 70+ 20 feet off the bumper in front of them
Old 07-30-2013, 09:18 AM   #11
wmkbailey's Avatar
Engine: 3126
Me too. I find that the bus runs good between 55 - 60. Speed limit here is 65, so I keep her at 60. I get there in plenty of time.
I hit the govern at abot 67 mph, but I only get there down hill
William
Old 03-27-2018, 04:01 PM   #12
6th gear
I unlock all my 6th gears via a letter from the OEM of the bus. Allison will send a liability release to sign, then release the calibration to the local Allison dealer.
6th kicks in between 49-52mph depending on the engine, and lowers the engine by 300 RPM which is pretty significant.
To debunct these outrageous hypothesis I've read.. The transmission is designed for 6th gear operations. Your engine computer communicates with the transmission computer. It will downshift when necessary and it will not "bog"the engine.
Cost less than $100 bucks to reprogram and you'll recoop the cost that same week in fuel!
jhagan is offline   Reply With Quote
Old 03-27-2018, 04:33 PM   #13
Chassis: Saf-T-Liner ER
Engine: Cummins ISC 8.3 Allison MD3060
I have the MD3060 and my bus came with 6th gear unlocked. The bus will do 80 without a problem. (We did this at night with no traffic because we were curious)
The bus runs much better at 60-65. I was able to get 10mpg. When my buddy was driving he would go up to 70 and his mileage was about 7mpg to 8mpg.
It's just safer and better gas mileage to stay in the right lane and mossy along at a slower speed.
James
JamieJackson is offline   Reply With Quote
Old 03-27-2018, 04:36 PM   #14
I certainly do not advocate speeding.. We strictly unlock ours for fuel economy purposes. We also activate the "economy mode" which must be activated by Allison.
The 6th range will save fuel. It has saved us hundreds of thousands of dollars.
Jeremy
Old 03-27-2018, 05:16 PM   #15
Have you managed this with a Bluebird?
They seem reluctant to send the release letter that Allison requires.
8.3 md 3060 mpgquestion Bus dad Mechanical and Drivetrains 24 04-05-2017 06:26 AM
Allison 3060 won't switch from Neutral to Drive wmkbailey Mechanical and Drivetrains 11 11-13-2013 09:21 AM
Low Gear Conversion morriskelly Mechanical and Drivetrains 9 01-01-2011 04:49 PM
Top Gear: Bus Jump Steve Everything Else | General Skoolie Discussions 5 01-14-2007 05:36 PM
My transmission is slipping/popping out of gear! 66ChevyTailgater Conversion General Discussions 5 11-08-2005 08:41 PM
