07-19-2013, 12:14 PM
AT545 and Mountain driving
is it just me or maybe tranny needs service.
coming down a big hill, the tranny did a less than stellar job engine braking. now i read that it doesn't lockup...?.? last thing i want to do is replace it.... i was sure glad to be back on flat ground.
any driving/care tips appreciated
07-19-2013, 12:48 PM
Re: AT545 and Mountain driving
viewtopic.php?f=44&t=20024
read that
the tranny needs 2200/2400 rpm input for full band pressure
for me this is 2nd gear 2200 rpm at 30 mph for uphill 8% grades
I cruise in the kinda flats/rolling hills in 3rd gear at 45/50 mph watch tranny gage on mine its at convertor out so it will run at 200/210 normal driving in rolling hills
4th gear is worthless unless I am on flat ground in VA or NC
I drive it a gear low 1st gear in town
do not baby peddle, roll into throttle until you get to 2200 rpm as the tranny shifts into 2nd it chirps..dunno that's what they do
slow down and enjoy the views that's what we do now
down hill is kinda weird...slow,slow...read my above thread any questions ask I will try to help
where you at?
07-19-2013, 01:59 PM
colorado
thanks for the post......good tips to try
going down the hill was scary, long grades and holding back with the air brakes. everything worked fine... but it just put my nerves on end.
i;ll pay more attention to the rpms and gears now. and "driving" instead of coasting...... maybe was a lot of my problem.
07-19-2013, 08:21 PM
Engine: DT466E/MD3060
I think its one thing people over look is a tranny cooler even in daily drivers. You may want to put one on there in no way can it hurt. I was going to use a bobcat hydraulic cooler for my demolition derby car but I need to find a way to put it in the bus. This thing is HUGE....way bigger when than any store bought unit so I don't think cooling will be an issue. I know more tranny issues come from lack of cooling. Just food for thought.
07-21-2013, 02:18 PM
Bapos is correct,I need to do a tranny cooler hopefully this fall
07-21-2013, 08:42 PM
Engine or trans cooler, choice is important
All coolers are not equal units. The old tube and fin is not good anymore. The modern design of stacked plates is very superior. There are lots of good used units available. Some unites have AN fittings attached. Frank
08-02-2013, 10:06 AM
Chassis: Saf-T-Liner MVP
Engine: Cummins 6BT
does your bus not have an electric retarder? i thought all colorado buses had them? at least all the ones I have encountered as conversions that originated here.
08-04-2013, 08:33 AM
no retarder that i know of. i wish it did. what does it look like? maybe it does and i dont know it.
the bus came out of the mountains of arizona.... im a little surprised it does so poorly, but, im a bus now and need to slow down.
08-04-2013, 08:43 AM
I agree with most of what is said here but I also think a added cooler is better than no cooler. I know most stock coolers (usually automatic units use a internal cooler inside the radiator tank) is WAY undersized. I know here in Texas Satan puts us in a death grip during the warm months and most stock units cant keep up. My advice is to get the biggest cooler your walled can afford.
If I do not use my bobcat cooler for demolition derby I will mount it under the bus and attach a fan blowing on it or sucking depending on how its mounted.
Again something is better than nothing and in this case bigger is better but as stated here the old fin and tube design is dated and there are better choices out there but I would get as big of one as you can afford.
08-04-2013, 07:21 PM
The lack of lock-up means your transmission can spin freely of crankshaft speed, within the realms of shearing the transmission fluid in the converter. Since the stator in a torque converter can overspeed, but not underspeed there is little resistance to this. But it really doesn't matter because an engine can only provide engine braking through pumping loses and mechanical friction. Since friction is so low it is pumping loses that need to slow an engine down. Without a throttle blade the pumping loses on a diesel engine are pretty limited. Basically, you need a lock-up converter and some means of causing pumping loses like an exhaust brake or a compression brake which releases the compressed air charge before it can do positive work on the piston.
Your transmission is fine. The key is to just slow down and enjoy life at a slower pace. Remember you are driving a bus, not a sports car.
*edit* A transmission cooler is very important on the way UP the hill, but on the way down I wouldn't worry about it. The transmission cooler is in the radiator which means engine coolant temp ultimately controls transmission fluid temp. Since the engine is pumping nothing but cooling air going down hill it is cooling the coolant rather than heating it and should offset any increase in temp from the transmission. Many modern V-8s use the cooling air effect and cylinder deactivation to allow limited power operation despite a complete cooling system failure.
08-05-2013, 07:50 AM
thanks all!!!!!
hey, i have another question about the tranny, i think.
part of my issue with it, is a noise that comes on for apparently no reason. i'm guessing it is a cooling fan, but idk. when running down the road, more so when hot than not, a "roar" comes on from the engine, and then switches off a few minutes later. no gear change, speed change,..... just a roar.
i totally thought it was the tranny making the noise. but then i stopped on a hot day with motor on fast idle, and it made the noise again, which was my first inkling that it might not be the tranny (i was stopped).
is this roar related to the trans or is it a cooling switch/fan, or...? any ideas appreciated.
08-05-2013, 09:05 AM
probably just cooling fan(engine)
I just came back from running up and down to grandfather mountain, and ran fine using the drive at 2200 rpm attitude, temps good...I did turn on the heaters for a 3 min climb just as precaution (pulling from red light at bottom of a 6% grade)
08-05-2013, 10:38 AM
I would say for sure fan. I used to drive a large straight truck and when the fan clutch engaged it was fairly loud. I could actually feel it bog the engine slightly.
Brutus
08-05-2013, 11:04 AM
thanks for the info
that gives me more confidence than the "oh sh*t" look everyone makes when it goes on
now i can say "its suppose to do that"
08-05-2013, 02:33 PM
Engine: 3126
I have a rear engine and can bearly hear it, but I can hear when the fan kicks in. I bet not as loud as you front engine guys.
08-05-2013, 02:46 PM
the first gen hummers were really loud...not stealthy
08-05-2013, 04:42 PM
fan makes the most sense..... i hope.
i also use to have a straight truck that had an overspeed light.... idk, but that is the only other thing that comes to mind.....antother light i had no idea what it was for.
08-05-2013, 05:39 PM
#19
Chassis: Blue Bird
Engine: ISC 8.3
First time I heard the cooling fan on my front Cummins 5.9 engine (former bus) it rather startled me. It was quite loud, but it didn't stay on long -- it was easy to see the temperature needle moving down while that fan ran. Next time you hear the sound, watch that gauge to see whether it drops.
08-07-2013, 12:02 PM
#20
Engine: Cummins 6BT
a retarder would be hard to miss. there would be a lever on your steering column and some corresponding lights that light up when you move it. when you pull the lever while driving it feels as if you are braking when your not. or maybe you have one and its not hooked up, if there is a BIG wierd magnetic looking coil around your driveshaft somewhere you have one. We just got home from a short camping trip at a high mountain lake about 30 miles from home, we climbed over 3500 feet and today on the way down i didnt have to touch the brakes ONCE, just used the retarder, and mind you, this is a winding, rocky dirt road and the 3500 feet climb happens in about 15 miles, not extremely steep, but long enough and slow enough to make the retarder come in handy.
