Old 08-30-2013, 08:08 PM   #1
Coachwork: Chevy Bluebird
Chassis: p30
Engine: 6.5L Diesel
Rated Cap: 13
Emergency Help Needed
Hey guys, just joined the community. Can't believe it took me this long. I'll cut to the chase.
Here's the issue: My dad owns a 1997 Chevy Bluebird Mini Bus w/ the 6.5 L diesel. He has had it in shop for the last week because it will crank right up but then it will begin to stall as if not getting fuel to the engine. The issue has built over time, at first he stalled once going over a bridge and it was fine after but now it's stalling more frequently.
Fuel pump has just been replaced, fuel tank has been emptied and refilled, and fuel line has been replaced. This is an emergency because we are the staple of our tailgate and first game is tomorrow night. Diesel mechanic is at wits end too. Apparently, I'm the only one whose heard of this little thing called the internet. Please help save the day and give any insight you can provide. I'm dealing with this issue through my dad so please forgive the time it takes for me to filter your questions through him if need be.
Thank you thank you thank you
sbpep is offline   Reply With Quote
Old 08-31-2013, 11:28 AM   #2
Chassis: p30
Engine: 6.5L Diesel
Rated Cap: 13
Re: Emergency Help Needed
Heres a text my dad sent explaining it in more detail.
I drove it wed and seemed fine but I noticed it lost power a couple of times-not cutting off but rpm decrease. Got in back in hood snd stopped to talk. At low rpm, it choked. Bled valve and srove to house. Next day I drove to iop and it died at low rpm. Bled it and limped to golf tourney. Drove home from shrimp n beer-got to iop bridge and it started losing power. Slowed it dowm and gotn to mt p connecter. It died and would not crank-batteries died so had it towed
Old 08-31-2013, 03:19 PM   #3
JakeC's Avatar
Does it have a lift pump?
Brutus
Old 08-31-2013, 04:21 PM   #4
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Almost too simple to mention-fuel filter?
Old 08-31-2013, 06:07 PM   #5
X2 on fuel filter not just the big main one!
Almost all newer ones have a second filter at the engine one about size of small jelly jar
Old 08-31-2013, 08:00 PM   #6
Chassis: p30
Engine: 6.5L Diesel
Rated Cap: 13
Fuel filter is replaced got second opinion and this guy thinks it may be bacteria in tank even though fuel was flushed, thoughts?
Old 08-31-2013, 08:51 PM   #7
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
I knew there was something on 6.5's that need to be relocated-I typed "6.5 relocate" and got 1000's of hits about stalling. Heres one of them.
Old 09-01-2013, 12:47 PM   #8
Chassis: p30
Engine: 6.5L Diesel
Rated Cap: 13
thanks to everyone for all of the input. unfortunately we weren't able to get it tailgate yesterday but I suspect the relocation could be would I need to do because it starts great and then stalls after running awhile which leads me to think it could be heat related w/ that component. I will update everyone once it is pinpointed and fixed. Thanks again and I look forward to getting involved in the community.
AC in the emergency exit? GusGus Conversion General Discussions 1 05-24-2013 12:04 PM
HELP! Emergency starter system help needed: stuck in frost! queenofthemonsters Everything Else | General Skoolie Discussions 3 01-18-2011 05:30 PM
Emergency preparedness. crazycal Everything Else | General Skoolie Discussions 36 06-02-2010 09:24 PM
EMERGENCY Exterior Light Monitor Needed No_Loitering Classifieds | Buy, Sell, Swap 3 12-22-2008 12:54 PM
Emergency Window jterry Classifieds | Buy, Sell, Swap 0 03-31-2007 03:56 PM
