Old 10-13-2013, 10:15 AM   #1
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
RPM's on a Cummings
Hello all, Got a question I just bought a 1988 Crown Pusher with a Cummings motor & Allison 4 speed auto, now it's been 30 yrs since driving Tractor trailers but my RPM's at 55 were 4000 rpm took it up to 67mph a couple times & it was 4500rpm, is this normal & also are used supposed to manual shift the Alison automatic ? I know it sounds silly but theres a placard telling what maximum speeds to downshift at.
Stu & Filo. T is offline   Reply With Quote
Old 10-13-2013, 12:12 PM   #2
frank-id's Avatar
Cummings engine speed
The top engine speed on most diesel engine is 2250RPM. The engine fuel pump sets this speed. My Crown is a 1968 with a Cummins. You now have a great bus. Check to notice if tach is cable or electric. Some times the dash unit goes wild. ost diesel tachs have a 3500 max number on the tach. Gas cars have tachs top rpm at 6000- 8500 rpm. Maybe someone changed the tach.
Call me and we can talk. Frank in Idaho 208 423 5969 frank.id.crownatgmail.com
frank-id is offline   Reply With Quote
Old 10-13-2013, 03:51 PM   #3
Year: 1977
Coachwork: Chevy
Chassis: C/60
Engine: 350 V8
Rated Cap: 54
Re: RPM's on a Cummings
I know it's farm machinary but we have a 2144 Case combine with a 5.9l cummins (same as the cummins you all know in the Dodge Pickups) and it runs at a jolly 2850 when wide open. This is on the electronic display in the cab but we aslo installed a mech tac back by the engine itself and it reads near 2900 when it's wide open.
There's no way that engine is spinning at 4500 rpm's, it would run away long before that ....
Passes everything but gas stations.
bamper is offline   Reply With Quote
Old 10-13-2013, 04:44 PM   #4
Thats what I figured it just been so many yrs since I delt with a Diesel I wasn't sure if things had changed think I'll get an extra tack & hook it up at the motor because evan at Idle it show 1600 rpm
Old 10-14-2013, 02:19 PM   #5
wmkbailey's Avatar
Engine: 3126
I guess when you put it in gear, your bus pops a wheelie, cool.
William
https://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 10-14-2013, 02:41 PM   #6
look at back of the tach, maybe it is an adjustable one and is on the wrong setting?
Old 10-16-2013, 02:18 PM   #7
Moderator
crazycal's Avatar
Chassis: 3800
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Redline on that thing is at least 5800 RPMs...NOT! Better slow down those RPMs.
I'm hungry!
You Gotta Let Me Fly
Old 10-18-2013, 07:01 PM   #8
Chassis: TC2000 FE
Engine: 190hp 5.9 Cummins
They sell after market tachometers for the cummins engines. I will look up the link if your interested.
Nat
Old 10-20-2013, 01:02 PM   #9
Nat
Yes please thank you I've been looking thru summit & Jegs
Old 10-20-2013, 09:22 PM   #10
Chassis: TC2000 FE
Here is one. This one takes pulses from the injector lines.
http://tinytach.com/
Some use the sensor in the bell housing
Some use pulses from the alternator, but they need to be calibrated.
This one installs at the front of the engine, reading the revaluations off the magnets you epoxy to the dampener. It is a issopro.
http://www.dieselpowerproducts.com//p-7 ... Qgod928AmA
That's the sensor. With that you can use any Issopro tach.
And a nice right up on installing it on a first gen dodge truck.
http://www.dieselbombers.com/dodge-dies ... mount.html
Nat
Old 10-21-2013, 07:55 PM   #11
Thanks Nat I'll take a look, mine runs off the alternator
Old 11-12-2013, 11:23 AM   #12
Finally found time to open up the dash theres a black screw on the tach that when I turned it was able to bring the rpms at idle showing 900rpm and when holding the pedal down 3500 rpm, does anyone know what the idle rpm should read I'm thinking around 500rpm's but going to start researching
Old 11-20-2013, 12:57 AM   #13
Chassis: IH
Engine: 466
Rated Cap: 64
The 5.9L and the 6.7L Cummins in the Dodge pickups like to idle at about 600RPM and hit the redline at about 2800 rpm.
Which Cummins do you have in the bus? I have the 855 CID 250 hp Cummins in two of my x-military trucks, and they do not want to go over about 2200 RPM max at factory redline or you better bring a big box to put the parts in!
dburt is offline   Reply With Quote
Old 12-04-2013, 10:12 AM   #14
I have the Cummins 6CTA8.3 250hp, at least thats what the build sheet says, I was giving everything the school was giving when they bought the bus including blueprints, this thing even has a binder that list every single part & who manufactured it that went into the bus
Old 12-04-2013, 01:48 PM   #15
Chassis: TE2000 FE
Engine: 5.9L Cummins
if you get the engine serial number I can get that infomation for you.
Chuck
Old 12-13-2013, 12:16 PM   #16
Chuck
Thanks, I have a line on a couple of 1988 Crowns that are going to be crushed in a few weeks, their close by so it sounds like I can get a Tach & altenator pickup off them & try that first, I'll let you know, Stuart
Rpm's on a Cummings Stu & Filo. T Conversion General Discussions 11 12-27-2013 12:46 PM
1992 Bluebird w/ Cummings engine runs on used tranny oil??? sdwarf36 Alternative Fuels | Electric, Propane, Wood & Biofuels 7 11-18-2012 04:04 PM
Top RPM for a cummings 5.9 24 valve engine funbus63 Cummins Drivetrain 5 12-19-2010 09:24 PM
WTB - cummings diesel bus? mrbisset Classifieds | Buy, Sell, Swap 3 05-23-2006 11:25 PM
