Old 10-15-2013, 11:49 AM   #1
Chassis: Ford B800
Engine: Cummins 5.9L I6
Need help identifying brake system components [95 Ford B800]
Hey y'all.
My bus is leaking (pouring) out brake fluid, so right now it's not really safely drivable.
A shop quoted me approximately $1700 for the job, saying I needed new
-rear brake shoes
-axle seals
-wheel cylinders
-backing plate assembly(?)
I don't really trust the motives nor competence of the shop, they didn't mention anything about my brake lines, which I did my own investigation and found that was the largest leak in the system. The bus sat in the weather for years before my purchase and the brake lines are all rusty and I believe need to be replaced entirely. In fact, I think maybe I need to replace everything but my master cylinder. I'm not a mechanic though, and while a friend who is a mechanic said he'd help me do the brake job itself, he also said to call him when I have all the parts. So now that's what I'm working on.
So first question, this thing.
http://imgur.com/t3ocI5f
I cleaned off a little section that had a number printed under it.
http://imgur.com/nl9nDkl
I then searched that number online. I found this on ebay.
http://www.ebay.com/itm/Maxibrake-341A1 ... 48&vxp=mtr
Is that the same thing?
Is that just for the parking brake, which appears to be working fine? It also appears to be leaking brake fluid, though slowly - you can see in the first picture that it's covered in moisture. That moisture is brake fluid.
Please edumacate, and thank you for your time.
Valerie is offline   Reply With Quote
Old 10-15-2013, 03:38 PM   #2
Chassis: TE2000 FE
Engine: 5.9L Cummins
Re: Need help identifying brake system components [95 Ford B
From what I remember maxibrakes were air brakes so I dont think they are the same thing. JMHO
Chuck
Old 10-16-2013, 08:07 AM   #3
Chassis: Ford B800
Hey chuck, thanks for the reply.
My braking system is definitely hydraulic. I do not have air brakes.
Old 10-16-2013, 08:23 AM   #4
Chassis: TE2000 FE
If the shop was talking a complete rebuild on the brake system then that would be a fair price but it doesnt sound that way. Have you looked for a service manual for your bus? If you can get one they normally have diagrams of the brkes and you friend should be able to indicate what parts are needed.
chuck
Old 10-16-2013, 08:27 AM   #5
a few links
I think you have the lucas girling system
some pics
https://www.google.com/search?q=luca...w=1684&bih=847
free manuals
http://www.gobookee.org/lucas-girlin...-system-parts/
http://www.schoolbusfleet.com/forum/...TOPIC_ID=21510
not sure this is what you have but probably
Old 10-16-2013, 08:31 AM   #6
Chassis: Ford B800
I've searched for a manual for my bus to no avail (1995 Ford B800 Body with Amtran Chassis).
Those other links look super useful to me! I am also pretty sure I have the Lucas Girling braking system. Thank you so much!
Old 10-22-2013, 06:02 PM   #7
Chassis: Ford B800
Found out that those canisters are in fact my parking brakes...
One leaks fluid, very slowly. It's damp. The other is actually not leaking.
These are on a separate hydraulic system from my primary brakes.
Going to replace my broken lines for starters, and see if I actually need anything else.
1997 Ford B800 for sale, solar panels, wood stove, $8500 tomas_maly Classifieds | Buy, Sell, Swap 0 06-14-2014 10:12 AM
Bus (MDT) Non Air Brake system diagrams. nat_ster Cummins Drivetrain 0 04-05-2014 02:10 AM
Fuel Return Line/Tube, 1995 Ford B800 5.9L Cummins JankyBarge Mechanical and Drivetrains 5 08-14-2013 07:05 PM
Ford brake system jkindt Ford Drivetrain 8 05-25-2010 10:18 AM
Wanted/needed telma brake system frank-id Classifieds | Buy, Sell, Swap 7 11-03-2008 09:34 PM
