Old 10-26-2013, 04:38 PM   #1
Henukaw's Avatar
Coachwork: Ward Volunteer
Chassis: GMC 6000
Engine: 366 V8 (6.0 L)
Rated Cap: 71
The smell of fuel...
I have had an issue with my bus I'd like to get some advice/help with.
Every time the heat rises, say 80's, I smell gas vapors escaping from the fuel tank. I am not sure exactly where to begin looking, but I suspect my vapor recovery system may be faulty. I have no fuel leak, and no major loss of fuel from this issue. It's more of a nuisance-safety-preventive measure I'd like to fix, but have no clue what I'm looking for.
The lines look good. No other visible issues. I don't "top off", the gas tank looks fine, gas cap is in good order.
Any ideas where to begin?
“Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off
the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover." Mark Twain
Henukaw is offline   Reply With Quote
Old 10-27-2013, 10:35 AM   #2
bapos's Avatar
Engine: DT466E/MD3060
Re: The smell of fuel...
I think your right on track with your reasoning. I would not go by the "look" of hoses. I have dealt with plenty of old cars where the fuel hoses looked fine but they are not. I would disconnect one like and plug one end and hit it with some high pressure air to see if it leaks or not. Depending on the cost I would just go ahead and replace them. Sooner or later you will need to.
Just food for thought.
Hope it helps
Armageddon: the smell of airborne rust jazty Short-Bus Conversion Projects 327 03-21-2024 01:03 PM
The smell of fuel... Henukaw Mechanical and Drivetrains 7 10-29-2013 06:38 PM
Got Fuel? I don't lapeer20m Detroit Diesel Drivetrain 13 06-24-2011 10:58 AM
DSE fuel lornaschinske Alternative Fuels | Electric, Propane, Wood & Biofuels 2 05-03-2011 11:59 AM
Service records a thing of the past? Bad smell here. putterspitt Conversion General Discussions 3 02-21-2011 09:51 AM
