Old 11-10-2013, 08:03 PM   #1
wmkbailey's Avatar
Engine: 3126
Allison 3060 won't switch from Neutral to Drive
My first mechanical issue with the bus. It started this week. Sometimes it wont go into drive. Reverse works great. After playing with it some more today, it will eventually go to drive. Sometimes it works right from the start other times I have to work the button some before it goes.
Prokchop found this article for me. http://forum.bacrallies.com/m-1304866747
It maybe the transmission touch pad. I will talk to the maintenance manager that I bought my bus from and see what he says. If it is, find out where they get them from.
William
https://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 11-11-2013, 06:08 PM   #2
wmkbailey's Avatar
Engine: 3126
Re: Allison 3060 won't switch from Neutral to Drive
I got a surprise from the maintenance depot I bought the bus from. I stopped by today to ask about this problem and they gave me a new switch assembly.
William
Old 11-12-2013, 05:33 AM   #3
wow good score....did it fix it?
Old 11-12-2013, 07:54 AM   #4
wmkbailey's Avatar
Engine: 3126
He told me a work around that is working for now. When you push in the button, wiggle your finger around until it makes contact. This will do me until the weekend, then I will have time to replace it. Since his work around is working, it is pointing to the switch as being bad. I don't think the ECU cares if you wiggle your finger or not.
William
Old 11-12-2013, 09:26 AM   #5
JakeC's Avatar
I bet this is in the ecu...
if bFingerWiggled then
bPutBusInDrive := True ;
elsif
bFailAndLeaveStranded := True ;
end_if
Brutus
Old 11-12-2013, 10:45 AM   #6
elsif
end_if
Is that pre ASCII ?
Old 11-12-2013, 10:56 AM   #7
wmkbailey's Avatar
Engine: 3126
elsif
end_if
You know I think I did see that line of code in there.
William
Old 11-12-2013, 10:33 PM   #8
Chassis: Blue Bird
Engine: ISC 8.3
elsif
end_if
What is that awful stuff, Visual Basic or somethin'?
My Allison pad feels like it has dome switches under the plastic sheet. I guess it makes sense that the dome could oxidize or otherwise develop a poor contact. That's awesome that the maintenance guy gave you a repair kit. I wish I knew anybody at a bus depot 'round here to go and pester with my questions from time to time..
family wagon is offline   Reply With Quote
Old 11-13-2013, 06:21 AM   #9
wmkbailey's Avatar
Engine: 3126
Before I bought the bus from them, I just stopped by and told them what I planned to do with the bus. They were very receptive and answered any question I had.
William
Old 11-13-2013, 08:12 AM   #10
JakeC's Avatar
elsif
end_if
Is that pre ASCII ?
elsif
end_if
Haha... It's structured text, which is a machine programming language. It's actually pretty easy, which is good, because it's what I work with all the time. I just saw I had an error, though. "Elsif" should have just been "else", since there was no other "if" statement
Brutus
Old 11-13-2013, 09:13 AM   #11
wmkbailey's Avatar
Engine: 3126
elsif
end_if
Thanks Jake, I corrected the elsif satement to an else in my ecu and now it is working better.
William
Old 11-13-2013, 09:21 AM   #12
JakeC's Avatar
Yes!!!
Brutus
school bus neutral safety switch keith Classifieds | Buy, Sell, Swap 5 12-21-2020 12:23 PM
MD 3060 transmission 6th gear wmkbailey Mechanical and Drivetrains 14 03-27-2018 05:16 PM
8.3 md 3060 mpgquestion Bus dad Mechanical and Drivetrains 24 04-05-2017 06:26 AM
Mystery Switch timmygyu Short-Bus Conversion Projects 7 03-07-2013 10:03 PM
Switch from Allison 643 to Allison 545 the_experience03 Conversion General Discussions 3 02-13-2008 08:44 PM
