Old 03-26-2014, 10:42 AM   #1
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
Air Brake Pedal Removal
As you can see, my pedal assembly looks freakin gnarly. I want to remove it to sandblast and repaint it, but I can't figure out how to do this with the brake linkage. Does anyone know if the pedal assembly can be removed separate from the air mechanism under the bus? I'd rather not have to undo all the hose connections just to get this pedal assembly out.
The fuel pedal is easy, it is just fly by wire and bolted to the plate I am trying to take out.
Thanks in advance
porkchopsandwiches is offline   Reply With Quote
Old 03-27-2014, 02:27 PM   #2
Chassis: TE2000 FE
Engine: 5.9L Cummins
Re: Air Brake Pedal Removal
What type of air brakes? Most have a pivot pin that needs to be removed. If your talking about the part that's bolted to the floor that's the top of the air valve and yes you have to remove all the air lines.
Good luck
Chuck
Old 03-31-2014, 01:36 PM   #3
wmkbailey's Avatar
Engine: 3126
Hey Prokchop, I have the same issue and could not get my break pedal apart. I was hoping for an easy way to remove.
William
https://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 04-11-2014, 01:03 PM   #4
I ended up just taking off the rubber pedal covers and putting a small wire brush on a die grinder and doing it that way. They look fine now after a slathering of that rust preventative paint and some black oil-based rustoleum.
Old 02-29-2020, 01:48 PM   #5
Engine: Cummins 5.9L 24v
Rated Cap: 82
I have that same style of brake pedal on my 98 BB FE Transit bus. Can these be swapped for traditional style brake pedal? I loath this accelerator style brake pedal.
Thanks
Rumroller is offline   Reply With Quote
moving the air brake pedal bansil Conversion General Discussions 13 05-25-2012 09:10 AM
Air Controlled Gas Pedal mfrederick Mechanical and Drivetrains 7 11-02-2009 09:16 AM
brakes and need pedal. C00LR Classifieds | Buy, Sell, Swap 14 09-14-2009 02:52 PM
Air pressure to the gas pedal WHISPERS Conversion General Discussions 7 11-12-2008 09:52 PM
brake pedal "sticking" w/air brakes? baadpuppy Conversion General Discussions 4 06-12-2008 02:29 PM
