Old 06-20-2014, 08:44 AM   #1
Huskie1's Avatar
Year: 1987
Chassis: Unknown
Engine: Ford
Rated Cap: 76
87 Ford/Carpenter Bus Makin Me Hot?
I have temporary custody of an 87 Ford/Carpenter School Bus converted to tailgating machine for our HS Football Boosters. When driving I've noticed the left side puts off quite a bit of heat. Seems to be coming from below the panel with switches for lights, etc. Is this normal? Looked for a switch to see if heater was turned on, but so far haven't found it. There is a pull toggle on that panel that says "power vent" but not sure what it does if anything. Sorry for the simple question, but quickly losing hair on my left leg
Huskie1 is offline   Reply With Quote
Old 06-20-2014, 06:11 PM   #2
Chassis: B3800 Short bus
Rated Cap: 36
Re: 87 Ford/Carpenter Bus Makin Me Hot?
There will likely be a coolant valve down near the base of that heater. Close it to stop flow to the heater core.
If you don't see a valve down there then it is likely under the hood. You'll have to follow the heater hose to find it.
Old 06-23-2014, 08:53 AM   #3
Huskie1's Avatar
Year: 1987
Chassis: Unknown
Engine: Ford
Rated Cap: 76
Thanks jazty. I found the valve!
1987 Ford Carpenter toy hauler Seeria Skoolie Conversion Projects 6 06-09-2011 09:34 AM
1995 ford carpenter 6 cylinder DIESEL for sale ninjabus Classifieds | Buy, Sell, Swap 2 10-10-2010 06:38 PM
FLORA - 1987 Ford Carpenter Redbear Conversion General Discussions 1 07-08-2009 11:25 PM
FLORA - 87 Ford Carpenter TygerCub Skoolie Conversion Projects 2 07-03-2009 10:18 PM
1985 Ford Carpenter, converted recently for sale playoutsidemore Classifieds | Buy, Sell, Swap 2 06-03-2008 11:28 PM
