Old 06-24-2014, 10:00 AM   #1
Chassis: All Canadian FE
loud noise when steering wheel cranked
Clementine doesn't like taking corners too tight - when we have to keep the wheel cranked when parking/maneuvering, she screams at us. We're going to try and replicate the sound for our mechanic the next time he stops by but if anyone has any suggestions on what we should be looking for I'd appreciate it. I'm thinking something to do with the power steering belt... Thoughts?
fly the coop
Fig. to escape; to get out or get away. (Alludes to a chicken escaping from a chicken coop.) I couldn't stand the party, so I flew the coop. The prisoner flew the coop at the first opportunity.
www.flythecoop.ca
pictureLOVE is offline   Reply With Quote
Old 06-24-2014, 10:39 AM   #2
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Re: loud noise when steering wheel cranked
One direction only, or both? Could be a lack of fluid in the reservoir.
Hey! That's not an RV, that's a school bus.
Well thank you for noticing, Captain Obvious
Captain Obvious on deviantArt
Scooternj is offline   Reply With Quote
Old 06-24-2014, 11:56 AM   #3
Moderator
crazycal's Avatar
Chassis: 3800
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Maybe a loose belt. Hopefully nthing more serious than that.
I'm hungry!
You Gotta Let Me Fly
Old 06-24-2014, 01:31 PM   #4
Chassis: TE2000 FE
Engine: 5.9L Cummins
Was it low when you got your bus? If so check for leaks that has allowed air into the system. Air as well as lose belts, bad pressure relief valves and pumps can cause lots of racket when turning the wheel to lock.
Chuck
Need BB steering wheel frank-id Classifieds | Buy, Sell, Swap 1 07-20-2011 12:48 AM
Steering wheel change frank-id Conversion General Discussions 14 01-01-2011 01:26 PM
steering wheel putterspitt Conversion General Discussions 1 10-01-2010 07:29 PM
Power steering noise captainkf Conversion General Discussions 3 09-22-2007 12:50 AM
Steering wheel change frank-id Skoolie Conversion Projects 2 12-31-1969 07:00 PM
