Old 07-24-2014, 12:14 PM   #1
Repleace Rear Axle Seal, Bluebird
Hello! Can anyone chime in about how difficult it is to change out a rear axle seal on a bus? Our 1992 Bluebird TC2000 is leaking from the left rear wheel. The shop quoted us $400 including an inner and outer bearing. I am wondering if it is a job I can do myself. I am fairly good mechanically... but don't know if it's something that requires special tools, etc. I have never worked on anything as big as the bus
Follow our conversion:
Two Birds - 1992 Bluebird TC2000
WVO Powered!
viewtopic.php?f=9&t=467346
www.LiveLoveTravelDream.com
White99z is offline   Reply With Quote
Old 07-24-2014, 02:20 PM   #2
opus's Avatar
Chassis: All-American R/E
Re: Repleace Rear Axle Seal, Bluebird
I'd pay the $400, unless you have a way to pull the wheels off and the hub, etc. I can do it and I'd probably still pay the $400.
Old 07-24-2014, 03:28 PM   #3
Chassis: International 1753
Engine: 6.9 International
I doubt you'll want to do it yourself. Replacing a wheel seal is a fairly straightforward, uncomplicated job but you'll need to have a socket that is big enough(like 4-5 inches big) to remove the axle nut that holds the bearings on. You'll also need a dial indicator and a torque wrench to set bearing preload and I would highly recommend using the proper seal installer unless you want to do it multiple times. All of those things are stuff the average joe won't have. You'll also have to remove the brake shoes which isn't something most people could do. If it's someone you trust just pay the guy the money that way you know it's all done right, it's not something you want to take a chance on.
My build: The Silver Bullet https://www.skoolie.net/forums/f11/p...llet-9266.html
Booyah45828 is offline   Reply With Quote
Old 07-28-2014, 03:50 PM   #4
We are having the shop do it while they do our injection pump. Thanks for the tips!
WVO Powered!
Old 09-08-2014, 11:54 PM   #5
Will's Avatar
Engine: DTA 360, Fuller 6-speed
Rated Cap: 53
It's big, but very simple. The truck repair guys have to make a living too, so I don't find fault in taking something like that to them.
My bus conversion
Will is offline   Reply With Quote
Old 09-09-2014, 08:17 AM   #6
Ended up taking it to the shop and happy I did!
WVO Powered!
Rear axle gear ratio. To change or not to change. slade Conversion General Discussions 15 04-24-2017 02:33 PM
2,000lbs behind the rear axle? Diesel Dan Conversion General Discussions 6 08-10-2011 06:57 PM
rear axle assembly for sale accurides adamanderr Conversion General Discussions 0 07-08-2008 07:08 PM
Eaton Rear axle lubricant reccomendations? JonCBrand Conversion General Discussions 1 07-13-2007 10:09 PM
Rear axle or 2 speed axle hoser Everything Else | General Skoolie Discussions 7 09-10-2006 09:56 AM
